Re: [mpich-discuss] BLCR kernel module not present
Thanks Pavan Just to be clear, you're saying if I use mvapich with blcr then a running multi-node MPI job when killed (eg out of time) by a batch scheduler can be restarted (from which checkpoint?) presuming it doesn't have open files? Many thanks, M On Fri, 2013-04-26 at 15:12 -0500, Pavan Balaji wrote:
Michael,
BLCR support for mpich should work fine; if something is broken, please let us know.
However, the core BLCR group itself hadn't released updates in a while, primarily because they didn't have direct funding for it. I believe that's fixed now and they are working on newer releases.
-- Pavan
On 04/26/2013 03:07 PM US Central Time, michael wrote:
Hi folks I was wondering what the state of BLCR for mpich/mvapich is? eg how reliably can one presume it to be? Thanks, Michael
On Fri, 2013-04-26 at 14:33 -0500, Wesley Bland wrote:
It looks like you might have missed installing the kernel module for BLCR. What is the output of `lsmod`?
Alternatively, if you installed BLCR by using apt-get in Ubuntu, you should be able to use dkms to manage your kernel modules automatically. Make sure you have the package 'blcr-dkms' installed (you should be able to check this by typing `dims status`.
Do either of those solutions solve your issue?
Wesley
On Apr 26, 2013, at 1:55 PM, basma a.azeem <[email protected] <mailto:[email protected]>> wrote:
Thank you for your help
i installed BLCR 0.8.5 on my ubuntu 12.10 to be used for MPICH -3.0.3 this version of blcr should support to kernels through 3.7.1
when i run the command : basma@basma-Satellite-A500:~$ mpiexec --info
results:
HYDRA build details: Version: 3.0.3 Release Date: Thu Mar 28 16:01:21 CDT 2013 CC: gcc CXX: c++ F77: no F90: no Configure options: '--disable-option-checking' '--prefix=/home/basma/mpich2-install' '--disable-f77' '--disable-fc' '--enable-checkpointing' '--with-hydra-ckpointlib=blcr' '--cache-file=/dev/null' '--srcdir=.' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt -lcr -lpthread ' 'CPPFLAGS= -I/home/basma/libraries/mpich-3.0.3/src/mpl/include -I/home/basma/libraries/mpich-3.0.3/src/mpl/include -I/home/basma/libraries/mpich-3.0.3/src/openpa/src -I/home/basma/libraries/mpich-3.0.3/src/openpa/src -I/home/basma/libraries/mpich-3.0.3/src/mpi/romio/include' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: blcr Demux engines available: poll select
so i thought that every thing is ok but when i try to rum mpiexec it failed:
basma@basma-Satellite-A500:~$ mpiexec -ckpointlib blcr -ckpoint-prefix /home/business/ckpts/app.ckpoint -ckpoint-interval 3600 -n 4 /home/basma/libraries/mpich-3.0.3/examples/cpi
results:
Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
i am a Linux and parallel programming beginner
Thank you
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
michael
