New communicator and MPI_Reduce...
Good morning, I've created a new communicator "first_row_comm" which is the 1st row of a mesh of processes contained in MPI_COMM_WORLD. Everything works fine in the reduction operation involving the processes in the new communicator if I use: MPI_Reduce(&test_newcomm, &sum_newcomm, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD); However, when I want to apply the reduction operation using the new communicator as MPI_Reduce(&test_newcomm, &sum_newcomm, 1, MPI_INT, MPI_SUM, 0, first_row_comm); It compiles fine but throws an execution error: Fatal error in PMPI_Reduce: Invalid communicator, error stack: PMPI_Reduce(1270): MPI_Reduce(sbuf=000000000022FE38, rbuf=000000000022FE30, count=1, MPI_INT, MPI_SUM, root=0, MPI_COMM_NULL) failed PMPI_Reduce(1160): Null communicator But communicator " first_row_comm " is properly create. Is this a bug or I'm doing something wrong with the way I'm passing the new communicator argument in MPI_Reduce, or...?? Thanks for any hints!! Alejandro
participants (1)
Alejandro Allievi
