Re: [mpich-discuss] determinism in collectives
What about rectangular communicators? Presumably MPI_SUM is optimized even for the MPI_DOUBLE_COMPLEX on a rectangular communicator on BG/Q. ----- Original Message -----
From: "Jeff Hammond" <[email protected]> To: "Pavan Balaji" <[email protected]> Cc: [email protected] Sent: Monday, November 12, 2012 9:47:29 PM Subject: Re: [mpich-discuss] determinism in collectives Yes, what I was saying before is that we know that MPI on Blue Gene/Q drops into the MPICH2 algorithm for MPI_Reduce on for MPI_DOUBLE_COMPLEX with MPI_SUM on irregular communicators and that MPIC_Send and MPIC_Recv do not change their behavior on this machine, so whatever is true of stock MPICH2 1.4 is true for MPI on Blue Gene/Q.
This confirms what we suspected, which is that BGQ-MPI has deterministic reductions in this case because MPICH2 does.
Jeff
On Mon, Nov 12, 2012 at 9:43 PM, Pavan Balaji <[email protected]> wrote:
The default machine-independent implementation of MPICH is deterministic. However, each device can (and most times does) implement its own version of MPI_Reduce. We have no control on them.
-- Pavan
On 11/12/2012 09:40 PM US Central Time, Jeff Hammond wrote:
We are primarily interested in MPICH2, as the motivation for this question relates to a particular supercomputer that uses MPICH2 and, in particular, the MPICH2 implementation of MPI_Reduce for (comm,type,op) of interest to us.
Jeff
On Mon, Nov 12, 2012 at 9:35 PM, Pavan Balaji <[email protected]> wrote:
The MPI standard does not guarantee this. For example, an implementation could use topology-aware reductions or an MPI_ANY_SOURCE while waiting for messages from peers making the order in which the reduction operations are applied different for each run.
-- Pavan
On 11/12/2012 09:00 PM US Central Time, Nichols A. Romero wrote:
I apologize if this has been asked a trillion times, if its documented somewhere just point it out to me online.
Are collective operations, such as sums, using MPI_Reduce deterministic? In other words, if I run MPI_Reduce N times on P tasks, will the sums always occur in the same order. Thus it would be reproducible to the expected precision.
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Nichols A. Romero, Ph.D. Argonne Leadership Computing Facility Argonne National Laboratory Building 240 Room 2-127 9700 South Cass Avenue Argonne, IL 60490 (630) 252-3441
participants (1)
Nichols A. Romero
