Re: [mpich-discuss] Assembler messages at build ?
Lou, Your c.txt file seems to be a configure log. We need the log of your compilation step. There's nothing obviously wrong in your configure logs. Antonio On 11/23/2013 06:14 PM, Lou Picciano wrote:
Antonio, Tks for taking a look at this. config.log and c.txt are attached.
(Pardon the noob typo error - Duh! Yes, config is with 'CFLAGS' - no, not cross-compiling)
Lou
----- Original Message ----- From: "Antonio J. Pena" <[email protected]> To: [email protected] Sent: Saturday, November 23, 2013 1:11:38 PM Subject: Re: [mpich-discuss] Assembler messages at build ?
Hi Lou,
First, CFLAGFS should be CFLAGS. Anyway, that should be the default in a 32- bit system, so irrelevant unless you're cross-compiling. If that's not the case, please attach config.log and c.txt so that we can take a look. All of our 32-bit test builds compile without problems.
Thanks, Antonio
On Saturday, November 23, 2013 05:13:28 PM Lou Picciano wrote:
mpich Wizards,
Trying our first build of mpich-3.0.4, and seeing Assembler messages at build time: (there are clearly a lot of config options to become familiar with; but, as a first pass):
Configure is: ./configure --prefix=/usr/local/mpi32 \ CFLAGFS="-m32" FFLAGS="-m32" \
| tee c.txt
$ make ... CC src/mpi/attr/attrutil.lo CC src/mpi/attr/dup_fn.lo CC src/mpi/coll/allred_group.lo CC src/mpi/coll/barrier_group.lo CC src/mpi/coll/helper_fns.lo /var/tmp//ccf4aaqC.s: Assembler messages: /var/tmp//ccf4aaqC.s:851: Error: number of operands mismatch for `mov' /var/tmp//ccf4aaqC.s:859: Error: number of operands mismatch for `mov' make[2]: *** [src/mpi/coll/helper_fns.lo] Error 1 make[2]: Leaving directory `<build_path>/mpich-3.0.4' make[1]: *** [all-recursive] Error 1
gcc 4.7.3 Platform is i86 OpenIndiana (Illumos, Solaris-ish)
Can anyone point me in the right direction?
Lou _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
"Antonio J. Peña"
