Re: [mpich-discuss] Assembler messages at build ?
Antonio, After compile attempt: $ make 2>&1 | tee m.txt -- m.txt is attached Tks again, Lou ----- Original Message ----- From: "\"Antonio J. Peña\"" <[email protected]> To: [email protected] Sent: Saturday, November 23, 2013 7:33:06 PM Subject: Re: [mpich-discuss] Assembler messages at build ? Lou, Your c.txt file seems to be a configure log. We need the log of your compilation step. There's nothing obviously wrong in your configure logs. Antonio On 11/23/2013 06:14 PM, Lou Picciano wrote: Antonio, Tks for taking a look at this. config.log and c.txt are attached. (Pardon the noob typo error - Duh! Yes, config is with 'CFLAGS' - no, not cross-compiling) Lou ----- Original Message ----- From: "Antonio J. Pena" <[email protected]> To: [email protected] Sent: Saturday, November 23, 2013 1:11:38 PM Subject: Re: [mpich-discuss] Assembler messages at build ? Hi Lou, First, CFLAGFS should be CFLAGS. Anyway, that should be the default in a 32- bit system, so irrelevant unless you're cross-compiling. If that's not the case, please attach config.log and c.txt so that we can take a look. All of our 32-bit test builds compile without problems. Thanks, Antonio On Saturday, November 23, 2013 05:13:28 PM Lou Picciano wrote: mpich Wizards, Trying our first build of mpich-3.0.4, and seeing Assembler messages at build time: (there are clearly a lot of config options to become familiar with; but, as a first pass): Configure is: ./configure --prefix=/usr/local/mpi32 \ CFLAGFS="-m32" FFLAGS="-m32" \ | tee c.txt $ make ... CC src/mpi/attr/attrutil.lo CC src/mpi/attr/dup_fn.lo CC src/mpi/coll/allred_group.lo CC src/mpi/coll/barrier_group.lo CC src/mpi/coll/helper_fns.lo /var/tmp//ccf4aaqC.s: Assembler messages: /var/tmp//ccf4aaqC.s:851: Error: number of operands mismatch for `mov' /var/tmp//ccf4aaqC.s:859: Error: number of operands mismatch for `mov' make[2]: *** [src/mpi/coll/helper_fns.lo] Error 1 make[2]: Leaving directory `<build_path>/mpich-3.0.4' make[1]: *** [all-recursive] Error 1 gcc 4.7.3 Platform is i86 OpenIndiana (Illumos, Solaris-ish) Can anyone point me in the right direction? Lou _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lou Picciano
