Re: [mpich-discuss] Fwd: Make MPICH on Arch Linux
Seems it's just delaying the same behavior. If you check the kernel log, you will probably see the OOM Killer being invoked. Are you building with just 1 thread? i.e. no make -j<num> If it's the case that you can't get through a successful build, I would recommend building on a similar, beefier machine and copying the installation to the RaspberryPi. Ken On 05/23/2014 05:02 PM, Scott O'Malley wrote:
After moving the build folder to my home directory I was able to get the make command to start correctly but it's still crashing out with an error which seems to stem from the gcc compiler, has anyone any advice?
I've attached the new m.txt and c.txt
Scott
On 23 May 2014 19:05, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
I think you may be running into the OOM Killer. Is memory usage high on your machine? Is /tmp a tmpfs and not a real partition? If so, can you try building elsewhere?
Ken
On 05/23/2014 12:54 PM, Scott O'Malley wrote:
Hi Guys
I'm trying to build MPICH for Arch but when I get to the Make section of the user guide 3.1 I get an error, I've looked through the m.txt file as the guide suggests but the error message isn't particularly helpful.
-- - Scott
-- - Scott
_________________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
-- - Scott
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
