Re: [mpich-discuss] Fwd: Make MPICH on Arch Linux
After moving the build folder to my home directory I was able to get the make command to start correctly but it's still crashing out with an error which seems to stem from the gcc compiler, has anyone any advice? I've attached the new m.txt and c.txt Scott On 23 May 2014 19:05, Kenneth Raffenetti <[email protected]> wrote:
I think you may be running into the OOM Killer. Is memory usage high on your machine? Is /tmp a tmpfs and not a real partition? If so, can you try building elsewhere?
Ken
On 05/23/2014 12:54 PM, Scott O'Malley wrote:
Hi Guys
I'm trying to build MPICH for Arch but when I get to the Make section of the user guide 3.1 I get an error, I've looked through the m.txt file as the guide suggests but the error message isn't particularly helpful.
-- - Scott
-- - Scott
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- - Scott
participants (1)
Scott O'Malley
