Re: [mpich-discuss] MPI_Comm_spawn_multiple Segment fault
You're probably just running out of resources. 90 processes (not threads) on one node is a lot. A common use of MPI is to have one (or a few) processes per node and if you need more local instances, you investigate using additional threads (such as OpenMP). Thanks, Wesley On Sep 26, 2013, at 9:45 PM, myself <[email protected]> wrote:
I'm trying to spawn several processes on two node. When the number of child processes is small, it works fine, such as less than 80. However, when I tried to spawn 90+ processes, mpirun told me "Segmentation fault (core dumped)". Is something I did wrong or I didn't do?
My MPICH compile command:
$ ./configure --prefix=/opt/mpich3 --with-device=ch3:nemesis --with-pm=hydra --enable-fast=none --enable-g=dbg CFLAGS=-fPIC --disable-f77 --disable-fc
Here is my source code:
#include "mpi.h" #include <stdio.h> #include <stdlib.h> #include <unistd.h>
int main( int argc, char *argv[] ) {
int HLEN=2; char *host[]={"node1","node2"}; char name[65];
int count; if(argc==2) count=atoi(argv[1]); else count=2;
int root=0; char* array_of_commands[count]; int array_of_maxprocs[count]; int errcodes[count]; MPI_Info array_of_info[count]; MPI_Comm parentcomm, intercomm;
int i; MPI_Init( &argc, &argv ); for(i=0; i< count; i++){ array_of_commands[i]="/home/mpitest/spawn"; array_of_maxprocs[i]=1; MPI_Info_create(&array_of_info[i]); MPI_Info_set(array_of_info[i],"host",host[i % HLEN]); }
MPI_Comm_get_parent( &parentcomm ); if (parentcomm == MPI_COMM_NULL) { MPI_Comm_spawn_multiple( count, array_of_commands, MPI_ARGVS_NULL /*array_of_argv*/, array_of_maxprocs, array_of_info, root, MPI_COMM_WORLD, &intercomm, errcodes ); printf("I'm the parent.\n"); } else { gethostname(name, sizeof(name)); printf("I'm the spawned at %s.\n",name); } fflush(stdout); MPI_Finalize(); return 0; }
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
