MPI_Comm_spawn_multiple Segment fault
I'm trying to spawn several processes on two node. When the number of child processes is small, it works fine, such as less than 80. However, when I tried to spawn 90+ processes, mpirun told me "Segmentation fault (core dumped)". Is something I did wrong or I didn't do? My MPICH compile command: $ ./configure --prefix=/opt/mpich3 --with-device=ch3:nemesis --with-pm=hydra --enable-fast=none --enable-g=dbg CFLAGS=-fPIC --disable-f77 --disable-fc Here is my source code: #include "mpi.h" #include <stdio.h> #include <stdlib.h> #include <unistd.h> int main( int argc, char *argv[] ) { int HLEN=2; char *host[]={"node1","node2"}; char name[65]; int count; if(argc==2) count=atoi(argv[1]); else count=2; int root=0; char* array_of_commands[count]; int array_of_maxprocs[count]; int errcodes[count]; MPI_Info array_of_info[count]; MPI_Comm parentcomm, intercomm; int i; MPI_Init( &argc, &argv ); for(i=0; i< count; i++){ array_of_commands[i]="/home/mpitest/spawn"; array_of_maxprocs[i]=1; MPI_Info_create(&array_of_info[i]); MPI_Info_set(array_of_info[i],"host",host[i % HLEN]); } MPI_Comm_get_parent( &parentcomm ); if (parentcomm == MPI_COMM_NULL) { MPI_Comm_spawn_multiple( count, array_of_commands, MPI_ARGVS_NULL /*array_of_argv*/, array_of_maxprocs, array_of_info, root, MPI_COMM_WORLD, &intercomm, errcodes ); printf("I'm the parent.\n"); } else { gethostname(name, sizeof(name)); printf("I'm the spawned at %s.\n",name); } fflush(stdout); MPI_Finalize(); return 0; }
participants (1)
myself
