Re: [mpich-discuss] Problems with running make
Hi, Am 02.03.2014 um 22:46 schrieb Gustavo Correa:
Hi Pavan
Many thanks for this clarification. I stand corrected.
Actually I guessed you MPICH developers might have already set something up to allow this kind of "collaborative" or "dialogue" MPI style with different users names/IDs running MPI processes across different computers, for specific uses.
Not trying to hijack Ron's thread (he has more important hurdles to get behind him), I wonder how mpiexec (Hydra), which is launched on one computer under one user name, will trigger additional MPI processes on the other computers under different user names (and how ssh may have to be setup to allow this to happen).
It's necessary to put your public key into the authorized_keys file under the other accounts on the slave machines. I have different accounts at several remote machines and to ease the access, I also put the target account in my ~/.ssh/config like: $ cat ~/.ssh/config Host slave1 User foo Host slave2 User baz Then it will use the specified account automatically. AFAICS it also supports running MPICH applications with different account on a cluster this way without any support by MPICH. == You can also use hostbased authentication, for which I wrote a Howto some time ago: https://arc.liv.ac.uk/SGE/howto/hostbased-ssh.html In case of a different account it must be granted by a setting in ~/.rhosts resp. ~/.shosts in addition. -- Reuti
Cheers, Gus
On Mar 2, 2014, at 12:39 PM, Balaji, Pavan wrote:
Gus,
On Mar 2, 2014, at 10:43 AM, Gustavo Correa <[email protected]> wrote:
Rajeev may correct me if I am wrong, but I think you *must* run MPI as the same user (name and UID) everywhere.
Not necessarily.
http://wiki.mpich.org/mpich/index.php/Using_the_Hydra_Process_Manager#Using_...
But using the same username is definitely easier and safer.
— Pavan
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Reuti
