Re: [mpich-discuss] Error building mpich-3.1.2 on Solaris 10 withgcc-4.9.0
6 Sep
6 Sep
'14
6:01 p.m.
On 09/06/2014 05:35 PM, Siegmar Gross wrote:
Thanks, Siegmar. Are you seeing some errors with â?omake t testingâ? or are all tests failing? On some platforms, s some tests take longer and hence show up as â?otimeoutsâ?, but they are not really hanging. But the number of such tests should be small.
I see some bus errors on Solaris 10 Sparc. I attached the log files for both Solaris 10 Sparc and x86_64, so that you can see yourself the results.
Kind regards
Siegmar
Can you send the output of: gcc -v g++ -v gfortran -v Just want to double check the build configuration so I can match it on my test setup. Thanks, Ken
4337
Age (days ago)
4337
Last active (days ago)
0 comments
1 participants
participants (1)
Kenneth Raffenetti
