Re: [mpich-discuss] Error building mpich-3.1.2 on Solaris 10 withgcc-4.9.0
Thanks, Siegmar. Are you seeing some errors with â?omake t testingâ? or are all tests failing? On some platforms, s some tests take longer and hence show up as â?otimeoutsâ?Â, but they are not really hanging. But the number of such tests should be small.
I see some bus errors on Solaris 10 Sparc. I attached the log files for both Solaris 10 Sparc and x86_64, so that you can see yourself the results.
Kind regards
Siegmar
Can you send the output of:
gcc -v g++ -v gfortran -v
Just want to double check the build configuration so I can match it on my test setup.
Solaris 10 x86_64: ================== sunpc1 root 2 gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/export2/prog/SunOS_x86_64/gcc-4.9.0/bin/../libexec/gcc/i386-pc-solaris2.10/4.9.0/lto-wrapper Target: i386-pc-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gmp=/usr/local --with-mpfr=/usr/local --with-mpc=/usr/local --with-isl=/usr/local --with-cloog=/usr/local --without-gnu-ld --with-ld=/usr/ccs/bin/ld ABI=32 --enable-languages=c,c++,objc,obj-c++,fortran --disable-nls --enable-threads=posix --disable-libgcj --with-system-zlib --enable-shared --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) sunpc1 root 3 g++ -v Using built-in specs. COLLECT_GCC=g++ COLLECT_LTO_WRAPPER=/export2/prog/SunOS_x86_64/gcc-4.9.0/bin/../libexec/gcc/i386-pc-solaris2.10/4.9.0/lto-wrapper Target: i386-pc-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gmp=/usr/local --with-mpfr=/usr/local --with-mpc=/usr/local --with-isl=/usr/local --with-cloog=/usr/local --without-gnu-ld --with-ld=/usr/ccs/bin/ld ABI=32 --enable-languages=c,c++,objc,obj-c++,fortran --disable-nls --enable-threads=posix --disable-libgcj --with-system-zlib --enable-shared --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) sunpc1 root 4 gfortran -v Using built-in specs. COLLECT_GCC=gfortran COLLECT_LTO_WRAPPER=/export2/prog/SunOS_x86_64/gcc-4.9.0/bin/../libexec/gcc/i386-pc-solaris2.10/4.9.0/lto-wrapper Target: i386-pc-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gmp=/usr/local --with-mpfr=/usr/local --with-mpc=/usr/local --with-isl=/usr/local --with-cloog=/usr/local --without-gnu-ld --with-ld=/usr/ccs/bin/ld ABI=32 --enable-languages=c,c++,objc,obj-c++,fortran --disable-nls --enable-threads=posix --disable-libgcj --with-system-zlib --enable-shared --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) sunpc1 root 5 Solaris 10 Sparc: ================= tyr root 2 gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/export2/prog/SunOS_sparc/gcc-4.9.0/bin/../libexec/gcc/sparc-sun-solaris2.10/4.9.0/lto-wrapper Target: sparc-sun-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gnu-as --with-as=/usr/local/bin/as --without-gnu-ld --with-ld=/usr/ccs/bin/ld --enable-nls --with-system-zlib --enable-languages=c,c++,objc,fortran,java --enable-java-gc=boehm --enable-multilib --disable-libgcj --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) tyr root 3 g++ -v Using built-in specs. COLLECT_GCC=g++ COLLECT_LTO_WRAPPER=/export2/prog/SunOS_sparc/gcc-4.9.0/bin/../libexec/gcc/sparc-sun-solaris2.10/4.9.0/lto-wrapper Target: sparc-sun-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gnu-as --with-as=/usr/local/bin/as --without-gnu-ld --with-ld=/usr/ccs/bin/ld --enable-nls --with-system-zlib --enable-languages=c,c++,objc,fortran,java --enable-java-gc=boehm --enable-multilib --disable-libgcj --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) tyr root 4 gfortran -v Using built-in specs. COLLECT_GCC=gfortran COLLECT_LTO_WRAPPER=/export2/prog/SunOS_sparc/gcc-4.9.0/bin/../libexec/gcc/sparc-sun-solaris2.10/4.9.0/lto-wrapper Target: sparc-sun-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gnu-as --with-as=/usr/local/bin/as --without-gnu-ld --with-ld=/usr/ccs/bin/ld --enable-nls --with-system-zlib --enable-languages=c,c++,objc,fortran,java --enable-java-gc=boehm --enable-multilib --disable-libgcj --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) tyr root 5 Kind regards Siegmar
participants (1)
Siegmar Gross
