Re: [mpich-discuss] MPI weak symbols and gfortran
Hi Matthieu, Please let us know the compilers an versions you are using, as well as a minimal code demonstrating the issue. Best, Antonio On 01/18/2014 07:44 AM, Matthieu Dorier wrote:
I've overwritten some MPI_* functions in a C library (typically MPI_Init and MPI_Finalize). When I link a C program with this library using gcc, the overwritten symbols are called correctly. However when using a fortran program, it does not work: the original functions are called. When I do "nm myprog" I see that MPI_Init and PMPI_Init have the same address, which is not the case with a C program. I also tried to compile the fortran program into a .o file using gfortran, then use gcc to link it to mpich, but I get the same result? Any workaround? Thanks!
Matthieu Dorier PhD student at ENS Rennes http://people.irisa.fr/Matthieu.Dorier
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Pe�a Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL 60439-4847 [email protected] www.mcs.anl.gov/~apenya
participants (1)
"Antonio J. Peña"
