MPI weak symbols and gfortran
18 Jan
18 Jan
'14
7:44 a.m.
Hi, I've overwritten some MPI_* functions in a C library (typically MPI_Init and MPI_Finalize). When I link a C program with this library using gcc, the overwritten symbols are called correctly. However when using a fortran program, it does not work: the original functions are called. When I do "nm myprog" I see that MPI_Init and PMPI_Init have the same address, which is not the case with a C program. I also tried to compile the fortran program into a .o file using gfortran, then use gcc to link it to mpich, but I get the same result? Any workaround? Thanks! Matthieu Dorier PhD student at ENS Rennes http://people.irisa.fr/Matthieu.Dorier
4567
Age (days ago)
4567
Last active (days ago)
0 comments
1 participants
participants (1)
Matthieu Dorier
