Re: [mpich-discuss] MPICH and sudo mpiexec
Hi Daniel, Your environment variables and password-less privileges are likely to not being propagated to applications executed by "sudo" (for example, can you do "sudo ssh" between nodes without being asked for a password?). If you really need that, consider logging in as root and preparing the environment there. Best, Antonio On 06/02/2015 11:21 AM, Thibault, Daniel wrote:
I have a small network of machines all running the same OS (Linaro Ubuntu Linux); they were all cloned from the same disk image and differ only in their machine names (UNIT1 through UNIT4). I can ssh between them at will, trusty has been established and I no longer get asked for a password upon connecting. MPICH is installed from the Ubuntu repository (not quite the latest version: mpiexec reports version OpenRTE 1.8.1, the mpich package is 3.0.4-6ubuntu1), and I can run a demo like cpi with no issues, using a little mpi-run.sh bash script (the default shell is tcsh, however) : (begin script) #!/bin/bash set -e ESDK=${EPIPHANY_HOME} ELIBS=${ESDK}/tools/host/lib:${LD_LIBRARY_PATH} EHDF=${EPIPHANY_HDF} echo "Running cpi on machines.u2.mpi" LD_LIBRARY_PATH=${ELIBS} mpiexec --allow-run-as-root -machinefile /home/linaro/.machines.u2.mpi -n 1 /home/linaro/myMPI/cpi echo "Done!" (end script) .machines.u2.mpi consists of the one line: linaro@UNIT2 From UNIT1, if I do: $ ./mpi-run.sh Running cpi on machines.u2.mpi Process 0 of 1 is on UNIT2 pi is approximately 3.1415926544231341, Error is 0.0000000008333410 wall clock time = 0.001327 Done! If I edit the script to change the mpiexec line like this: sudo -E LD_LIBRARY_PATH=${ELIBS} mpiexec --allow-run-as-root -machinefile /home/linaro/.machines.u2.mpi -n 1 /home/linaro/myMPI/cpi Now I get (edited for brevity): $ ./mpi-run.sh Running cpi on machines.u2.mpi linaro@UNIT2’s password: PATH=/usr/local/bin[…]: Command not found. export: Command not found. LD_LIBRARY_PATH=/usr/local/lib[…]: Command not found. export: Command not found. DYLD_LIBRARY_PATH: Undefined variable. And it just stops there. Note that the LD_LIBRARY_PATH being reported is **not** the one passed in by the script. I don’t think it’s managing to reach the mpi execution stage itself. If the machinefile lists more than one host, the password prompts appear two at a time and interfere with each other such that no login succeeds (although all machines have the same password). Googling around, I’ve seen this series of error outputs in a wide variety of other contexts, including Open MPI but also some completely unrelated application suites and SDKs. My problem is that the mpi binaries I need to run on the hosts absolutely require sudo elevation. Is sudo mpiexec the way to go? What is going on in my example case? Daniel U. Thibault RDDC - Centre de recherches de Valcartier | DRDC - Valcartier Research Centre NAC : _918V QSDJ_ <http://www.travelgis.com/map.asp?addr=918V%20QSDJ><_http://www.travelgis.com/map.asp?addr=918V%20QSDJ_> Gouvernement du Canada | Government of Canada <_http://www.valcartier.drdc-rddc.gc.ca/_>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Peña Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL 60439-4847 [email protected] www.mcs.anl.gov/~apenya _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
"Antonio J. Peña"
