Re: [mpich-discuss] discuss Digest, Vol 15, Issue 18
plz........anybody know how to implement pub-sub systems using MPI in ubuntu? On 1/16/14, [email protected] <[email protected]> wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. Re: Poor performance of Waitany / Waitsome (Jeff Hammond) 2. Re: Poor performance of Waitany / Waitsome (John Grime) 3. hello everyone....can anyone tell me how to do performance analysis by using mpi and cuda. (bhimashankar dhappadhule) 4. Re: hello everyone....can anyone tell me how to do performance analysis by using mpi and cuda. (Mahesh Doijade) 5. Re: Failed to allocate memory for an unexpected message (Luiz Carlos da Costa Junior)
Message: 1 Date: Wed, 15 Jan 2014 15:26:44 -0600 From: Jeff Hammond <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] Poor performance of Waitany / Waitsome Message-ID: <CAGKz=uJ6-9dDXtforrm3CMemo4JkzbGxE+SeY3fEYuoFaEWhnA@mail.gmail.com> Content-Type: text/plain; charset=UTF-8
Given that you're using shared memory on a bloated OS (anything driving a GUI Window Manager), software overhead is going to be significant. You can only do so much about this. You might want to compile MPICH yourself using all the optimization flags.
For example, I decided that "--enable-static --enable-fast=O3,nochkmsg,notiming,ndebug,nompit --disable-weak-symbols --enable-threads=single" were configure options that someone in search of speed might use. I have not done any systematic testing yet so some MPICH developer might tell me I'm a clueless buffoon for bothering to (de)activate some of these options.
If you were to assume that I was going to rerun your test with different builds of MPICH on my Mac laptop as soon as I get some coffee, you would be correct. Hence, apathy on your part has no impact on the experiments regarding MPICH build variants and speed :-)
Jeff
On Wed, Jan 15, 2014 at 3:10 PM, John Grime <[email protected]> wrote:
Cheers for the help, Jeff!
I just tried to mimic Waitall() using a variety of the ?MPI_Test?? routines (code attached), and the results are not what I would expect:
Although Waitsome() seems to give consistently the worst performance ( Waitall < Waitany < Waitsome ) , Testsome() *appears* to always be faster than Testany(), and for larger numbers of requests the performance order seems to actually reverse.
Now, I may have done something spectacularly dumb here (it would be the 5th such example from today alone), but on the assumption I have not: is this result expected given the underlying implementation?
J.
./time_routines.sh 4 50
nprocs = 4, ntokens = 16, ncycles = 50 Method : Time Relative MPI_Waitall : 1.526000e-03 1.000x MPI_Waitany : 1.435000e-03 0.940x MPI_Waitsome : 3.381000e-03 2.216x MPI_Testall : 3.101000e-03 2.032x MPI_Testany : 8.080000e-03 5.295x MPI_Testsome : 3.037000e-03 1.990x PMPI_Waitall : 1.603000e-03 1.050x PMPI_Waitany : 1.404000e-03 0.920x PMPI_Waitsome : 4.666000e-03 3.058x
nprocs = 4, ntokens = 64, ncycles = 50 Method : Time Relative MPI_Waitall : 3.173000e-03 1.000x MPI_Waitany : 5.362000e-03 1.690x MPI_Waitsome : 1.809100e-02 5.702x MPI_Testall : 1.364200e-02 4.299x MPI_Testany : 2.309300e-02 7.278x MPI_Testsome : 1.469800e-02 4.632x PMPI_Waitall : 2.063000e-03 0.650x PMPI_Waitany : 9.420000e-03 2.969x PMPI_Waitsome : 1.890300e-02 5.957x
nprocs = 4, ntokens = 128, ncycles = 50 Method : Time Relative MPI_Waitall : 4.730000e-03 1.000x MPI_Waitany : 2.691000e-02 5.689x MPI_Waitsome : 4.519000e-02 9.554x MPI_Testall : 4.696900e-02 9.930x MPI_Testany : 7.285200e-02 15.402x MPI_Testsome : 3.773400e-02 7.978x PMPI_Waitall : 5.158000e-03 1.090x PMPI_Waitany : 2.223200e-02 4.700x PMPI_Waitsome : 4.205000e-02 8.890x
nprocs = 4, ntokens = 512, ncycles = 50 Method : Time Relative MPI_Waitall : 1.365900e-02 1.000x MPI_Waitany : 3.261610e-01 23.879x MPI_Waitsome : 3.944020e-01 28.875x MPI_Testall : 5.408010e-01 39.593x MPI_Testany : 4.865990e-01 35.625x MPI_Testsome : 3.067470e-01 22.458x PMPI_Waitall : 1.976100e-02 1.447x PMPI_Waitany : 3.011500e-01 22.048x PMPI_Waitsome : 3.791930e-01 27.761x
nprocs = 4, ntokens = 1024, ncycles = 50 Method : Time Relative MPI_Waitall : 4.087800e-02 1.000x MPI_Waitany : 1.245209e+00 30.462x MPI_Waitsome : 1.704020e+00 41.686x MPI_Testall : 1.940940e+00 47.481x MPI_Testany : 1.618215e+00 39.586x MPI_Testsome : 1.133568e+00 27.731x PMPI_Waitall : 3.970200e-02 0.971x PMPI_Waitany : 1.344188e+00 32.883x PMPI_Waitsome : 1.685816e+00 41.240x
nprocs = 4, ntokens = 2048, ncycles = 50 Method : Time Relative MPI_Waitall : 1.173840e-01 1.000x MPI_Waitany : 4.600552e+00 39.192x MPI_Waitsome : 6.840568e+00 58.275x MPI_Testall : 6.762144e+00 57.607x MPI_Testany : 5.170525e+00 44.048x MPI_Testsome : 4.260335e+00 36.294x PMPI_Waitall : 1.291590e-01 1.100x PMPI_Waitany : 5.161881e+00 43.974x PMPI_Waitsome : 7.388439e+00 62.942x
On Jan 15, 2014, at 2:53 PM, Jeff Hammond <[email protected]> wrote:
On Wed, Jan 15, 2014 at 2:23 PM, John Grime <[email protected]> wrote:
Hi Jeff,
If Waitall wasn't faster than Waitsome or Waitany, then it wouldn't exist since obviously one can implement the former in terms of the latter
I see no reason it wouldn?t exist in such a case, given that it?s an elegant/convenient way to wait for all requests to complete vs. Waitsome / Waitany. It makes sense to me that it would be in the API in any case, much as I appreciate the value of the RISC-y approach you imply.
it shouldn't be surprising that they aren't as efficient.
I would?t expect them to have identical performance - but nor would I have expected a performance difference of ~50x for the same number of outstanding requests, even given that a naive loop over the request array will be O(N). That loop should be pretty cheap after all, even given that you can?t use cache well due to the potential for background state changes in the request object data or whatever (I?m not sure how it?s actually implemented, which is why I?m asking about this issue on the mailing list).
The appropriate question to ask is whether Waitany is implemented optimally or not.
Well, yes. I kinda hoped that question was heavily implied by my original email!
If you find that emulating Waitany using Testall following by a loop, then that's useful information.
I accidentally the whole thing, Jeff! ;)
But that?s a good idea, thanks - I?ll give it a try and report back!
Testall is the wrong semantic here. I thought it would test them all individually but it doesn't. I implemented it anyways and it is the worst of all. I attached your test with my modifications. Because I am an evil bastard, I made a ton of whitespace changes in addition to the nontrivial ones.
Jeff
-- Jeff Hammond [email protected] <nb_ring.c>_______________________________________________
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
Message: 2 Date: Wed, 15 Jan 2014 21:39:33 +0000 From: John Grime <[email protected]> To: "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] Poor performance of Waitany / Waitsome Message-ID: <[email protected]> Content-Type: text/plain; charset="Windows-1252"
Hi Jeff,
Very true - I would not expect these times to be indicative of what MPICH can actually achieve, but nonetheless the general trends seem to be reproducible.
I?m hoping if I can get a good handle on what?s happening, then I can write better MPI code in the general case. The major head scratcher for me is how the MPI_TestX routines seem to be slower than their conjugate MPI_WaitX in most situations, when I would imagine they?d be doing something fairly similar behind the scenes.
The wildcard appears to be MPI_Testsome().
I must be doing something dumb here, so I?ll also caffein-ate and consider!
J.
Jeff
J.
Hi Jeff,
Jeff
-- Jeff Hammond [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
Message: 3 Date: Thu, 16 Jan 2014 11:25:32 +0530 From: bhimashankar dhappadhule <[email protected]> To: discuss <[email protected]> Subject: [mpich-discuss] hello everyone....can anyone tell me how to do performance analysis by using mpi and cuda. Message-ID: <CAL1fN=78MwEiKutf2UyZc5WkCDGvb0yWEq3a0D8aFxUQKhsSDw@mail.gmail.com> Content-Type: text/plain; charset="iso-8859-1"
participants (1)
bhushan sable
