Re: [mpich-discuss] beginner for remote mem access
1) When you reply to the digest emails, change the subject to that of the thread you care to respond to. That will make it much easier for others to track the thread. 2) MPI_Win_fence is not similar to MPI_Barrier in some cases. The MPICH implementation can turn some calls into no-ops and others into MPI_Reduce_scatter. 3) Regarding "use MPI window as thread level", I really don't understand your thinking at all. MPI RMA is not shared memory nor is MPI a threading model. Jeff On Wed, Jul 3, 2013 at 2:46 PM, Sufeng Niu <[email protected]> wrote:
Thanks a lot for your guys reply. I should initial b array, I figure out the MPI_Win_fence should be called by all processes, which will solve the assertion failed issue.
it seems that MPI_Win_fence is very similar to MPI_Barrier, Can I say MPI_Win_fence is the RMA version of MPI_Barrier?
sorry about so many questions. Can I use MPI window as thread level? let's say I have 4 processes, each process has 8 threads. if only one thread is used to create mem access window, other process copy it and internal 8 threads use shared memory to perform some operations. Is that ok?
Thanks a lot!
On Wed, Jul 3, 2013 at 1:28 PM, <[email protected]> wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. beginner for remote mem access (Sufeng Niu) 2. Re: beginner for remote mem access (Yi Gu) 3. Re: beginner for remote mem access (Yi Gu) 4. Re: beginner for remote mem access (Jeff Hammond)
Message: 1 Date: Wed, 3 Jul 2013 13:12:46 -0500 From: Sufeng Niu <[email protected]> To: [email protected] Subject: [mpich-discuss] beginner for remote mem access Message-ID:
<CAFNNHkwxqXUB_+b8_tZ=L5K7VcDVhsz4ZMDDMGF55v-FAhgeqg@mail.gmail.com> Content-Type: text/plain; charset="iso-8859-1"
I am a beginner and just try to use remote memory access, and I wrote a simple program to test it:
#include "mpi.h" #include <stdio.h> #define SIZE 8
int main(int argc, char *argv[]) { int numtasks, rank, source=0, dest, tag=1, i; float a[64] = { 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, }; float b[SIZE];
MPI_Status stat;
MPI_Init(&argc,&argv); MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &numtasks);
MPI_Win win;
// check processor rank char processor_name[MPI_MAX_PROCESSOR_NAME]; int name_len; MPI_Get_processor_name(processor_name, &name_len); printf("-- processor %s, rank %d out of %d processors\n", processor_name, rank, numtasks);
MPI_Barrier(MPI_COMM_WORLD);
if (numtasks == 4) { if (rank == 0) { printf("create window \n"); MPI_Win_create(a, 8*sizeof(float), sizeof(float), MPI_INFO_NULL, MPI_COMM_WORLD, &win);
} else { MPI_Win_create(MPI_BOTTOM, 0, sizeof(float), MPI_INFO_NULL, MPI_COMM_WORLD, &win); }
MPI_Win_fence(0, win);
if (rank == 1){ MPI_Get(b, SIZE, MPI_FLOAT, 0, 8, SIZE, MPI_FLOAT, win);
MPI_Win_fence(0, win); }
printf("rank= %d b= %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f\n", rank,b[0],b[1],b[2],b[3],b[4],b[5],b[6],b[7]); } else printf("Must specify %d processors. Terminating.\n",SIZE);
MPI_Win_free(&win); MPI_Finalize(); }
However the terminal gives some odd results: rank= 0 b= 0.0 0.0 0.0 0.0 0.0 0.0 -71847793475452928.0 0.0 rank= 2 b= 0.0 0.0 0.0 0.0 0.0 0.0 222086852849451401216.0 0.0 rank= 3 b= 0.0 0.0 0.0 0.0 0.0 0.0 -74882.4 0.0 rank= 1 b= 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 the rank 1 is correct results, but others should be all zero. terminal also give some comments: "Assertion failed in file src/mpid/ch3/src/ch3u_rma_sync.c at line 5061: win_ptr->my_counter >= 0 internal ABORT - process 0"
another question is if I use remote memory access. all process which does not create window for share must add additional line: MPI_Win_create(MPI_BOTTOM, 0, data_type, MPI_INFO_NULL, MPI_COMM_WORLD, &win); correct?
Thanks a lot!
-- Best Regards, Sufeng Niu ECASP lab, ECE department, Illinois Institute of Technology Tel: 312-731-7219
participants (1)
Jeff Hammond
