Re: [mpich-discuss] discuss Digest, Vol 9, Issue 5
Thanks a lot for your guys reply. I should initial b array, I figure out the MPI_Win_fence should be called by all processes, which will solve the assertion failed issue. it seems that MPI_Win_fence is very similar to MPI_Barrier, Can I say MPI_Win_fence is the RMA version of MPI_Barrier? sorry about so many questions. Can I use MPI window as thread level? let's say I have 4 processes, each process has 8 threads. if only one thread is used to create mem access window, other process copy it and internal 8 threads use shared memory to perform some operations. Is that ok? Thanks a lot! On Wed, Jul 3, 2013 at 1:28 PM, <[email protected]> wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. beginner for remote mem access (Sufeng Niu) 2. Re: beginner for remote mem access (Yi Gu) 3. Re: beginner for remote mem access (Yi Gu) 4. Re: beginner for remote mem access (Jeff Hammond)
Message: 1 Date: Wed, 3 Jul 2013 13:12:46 -0500 From: Sufeng Niu <[email protected]> To: [email protected] Subject: [mpich-discuss] beginner for remote mem access Message-ID: <CAFNNHkwxqXUB_+b8_tZ= [email protected]> Content-Type: text/plain; charset="iso-8859-1"
I am a beginner and just try to use remote memory access, and I wrote a simple program to test it:
#include "mpi.h" #include <stdio.h> #define SIZE 8
int main(int argc, char *argv[]) { int numtasks, rank, source=0, dest, tag=1, i; float a[64] = { 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, }; float b[SIZE];
MPI_Status stat;
MPI_Init(&argc,&argv); MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &numtasks);
MPI_Win win;
// check processor rank char processor_name[MPI_MAX_PROCESSOR_NAME]; int name_len; MPI_Get_processor_name(processor_name, &name_len); printf("-- processor %s, rank %d out of %d processors\n", processor_name, rank, numtasks);
MPI_Barrier(MPI_COMM_WORLD);
if (numtasks == 4) { if (rank == 0) { printf("create window \n"); MPI_Win_create(a, 8*sizeof(float), sizeof(float), MPI_INFO_NULL, MPI_COMM_WORLD, &win);
} else { MPI_Win_create(MPI_BOTTOM, 0, sizeof(float), MPI_INFO_NULL, MPI_COMM_WORLD, &win); }
MPI_Win_fence(0, win);
if (rank == 1){ MPI_Get(b, SIZE, MPI_FLOAT, 0, 8, SIZE, MPI_FLOAT, win);
MPI_Win_fence(0, win); }
printf("rank= %d b= %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f %3.1f\n", rank,b[0],b[1],b[2],b[3],b[4],b[5],b[6],b[7]); } else printf("Must specify %d processors. Terminating.\n",SIZE);
MPI_Win_free(&win); MPI_Finalize(); }
However the terminal gives some odd results: rank= 0 b= 0.0 0.0 0.0 0.0 0.0 0.0 -71847793475452928.0 0.0 rank= 2 b= 0.0 0.0 0.0 0.0 0.0 0.0 222086852849451401216.0 0.0 rank= 3 b= 0.0 0.0 0.0 0.0 0.0 0.0 -74882.4 0.0 rank= 1 b= 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 the rank 1 is correct results, but others should be all zero. terminal also give some comments: "Assertion failed in file src/mpid/ch3/src/ch3u_rma_sync.c at line 5061: win_ptr->my_counter >= 0 internal ABORT - process 0"
another question is if I use remote memory access. all process which does not create window for share must add additional line: MPI_Win_create(MPI_BOTTOM, 0, data_type, MPI_INFO_NULL, MPI_COMM_WORLD, &win); correct?
Thanks a lot!
-- Best Regards, Sufeng Niu ECASP lab, ECE department, Illinois Institute of Technology Tel: 312-731-7219
participants (1)
Sufeng Niu
