Re: [mpich-discuss] Installation problem
Let's stick to the original problem for now. Is the libifcoremt.so library found in your Intel install directory? If you LD_PRELOAD it, will your tests run? Ken On 05/24/2015 07:28 AM, Eong Sheng Goh wrote:
I have found an even more serious problem regarding libmpi.so.12:
Unexpected output in exscanf: forrtl: severe (174): SIGSEGV, segmentation fault occurred Unexpected output in exscanf: Image PC Routine Line Source Unexpected output in exscanf: libmpi.so.12 00002ADB339C6F2C Unknown Unknown Unknown Unexpected output in exscanf: libmpi.so.12 00002ADB3394DA84 Unknown Unknown Unknown Unexpected output in exscanf: libmpi.so.12 00002ADB33925B33 Unknown Unknown Unknown Unexpected output in exscanf: libmpi.so.12 00002ADB338E9819 Unknown Unknown Unknown Unexpected output in exscanf: libmpifort.so.12 00002ADB3361D830 Unknown Unknown Unknown Unexpected output in exscanf: exscanf 00000000004087F6 Unknown Unknown Unknown Unexpected output in exscanf: exscanf 0000000000407824 Unknown Unknown Unknown Unexpected output in exscanf: exscanf 00000000004077AC Unknown Unknown Unknown Unexpected output in exscanf: libc.so.6 0000003050E1ED1D Unknown Unknown Unknown Unexpected output in exscanf: exscanf 00000000004076A9 Unknown Unknown Unknown Unexpected output in exscanf: Unexpected output in exscanf: =================================================================================== Unexpected output in exscanf: = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES Unexpected output in exscanf: = PID 31438 RUNNING AT comsics.usm.my Unexpected output in exscanf: = EXIT CODE: 174 Unexpected output in exscanf: = CLEANING UP REMAINING PROCESSES Unexpected output in exscanf: = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES Unexpected output in exscanf: ===================================================================================
All the required library path should be included already. I will appreciate any help. thank you.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
