Re: [mpich-discuss] How to make a non-MPI process to become a MPI process of MPI_COMM_WORLD?
Thank you very much. At 2015-01-27 07:25:28, "Kenneth Raffenetti" <[email protected]> wrote:
I've found the source of this error and have a fix pending review. It should make it into the git master repo and nightly tarballs later this week.
Ken
On 01/25/2015 07:22 PM, haozi wrote:
Now, I run the hydra_nameserver, and tell mpiexec where the nameserver. BUT, the same error happen, too.
At 2015-01-26 08:35:13, "Balaji, Pavan" <[email protected]> wrote:
Yes, you can use these on different nodes as well, but you need to run the hydra_nameserver somewhere and tell mpiexec where the nameserver is using the -nameserver option. Use mpiexec -nameserver -help for more information.
-- Pavan
On Jan 25, 2015, at 6:14 PM, haozi <[email protected]> wrote:
Also, I run server at node1, and run client at node2, and run client at node3, and ... These nodes have different IP. Can MPI publish/loopup work ???
At 2015-01-26 08:07:19, "haozi" <[email protected]> wrote: Yes, I run the example with mpiexec.
At 2015-01-26 03:26:21, "Balaji, Pavan" <[email protected]
wrote:
Using dynamic processes is not supported in MPICH for singleton init. Can you try running it with mpiexec?
Also, note that you should be using MPI publish/lookup functions instead of writing to a file yourself.
-- Pavan
On Jan 25, 2015, at 5:26 AM, haozi < [email protected] wrote:
Thanks, Balaji.
server_port_name.txt is built by the example, not by user.
At 2015-01-25 19:24:28, "Balaji, Pavan" < [email protected] wrote:
On Jan 25, 2015, at 5:04 AM, haozi <
Hello, Balaji.
The example from OpenMPI is attached.
server_port_name.txt is missing.
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
_______________________________________________ discuss mailing list [email protected]
To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
haozi
