Installation problem Ubuntu 14.04 LTS
CAN NOT FIND -lblcr,... I have blcr version 0.8.6_b4 and it compiles whitout problem's whit version 3.0.4,... 3.1.3 ./config options have changes,... I assume options have changed,... Here is error message at end of make: make[2]: Poistutaan hakemistosta "/mpi3/S4/mpich-3.1.3/src/pm/hydra" Making install in . make[2]: Siirrytään hakemistoon "/mpi3/S4/mpich-3.1.3" GEN lib/libmpi.la /usr/bin/ld: cannot find -lblcr collect2: error: ld returned 1 exit status make[2]: *** [lib/libmpi.la] Virhe 1 make[2]: Poistutaan hakemistosta "/mpi3/S4/mpich-3.1.3" make[1]: *** [install-recursive] Virhe 1 make[1]: Poistutaan hakemistosta "/mpi3/S4/mpich-3.1.3" make: *** [install] Virhe 2 joni@mpi1:~$ ========= build script used: export JPK_THREADS="-L/usr/lib/x86_64-linux-gnu/libevent_pthreads-2.0.so.5 -L/usr/lib/x86_64-linux-gnu/libevent_core-2.0.so.5" export LD_FLAGS="$JPK_THREADS" export CFLAGS="-Wl,--no-as-needed -fPIC -m64 -pthread -O3 -fopenmp -lgomp -L$JPK_BLCR/lib/libcr.so" export CC=gcc export CXX=g++ export FC=gfortran export F77=gfortran export MPICH2LIB_CFLAGS="$CFLAGS $JPK_THREADS" export MPICH2LIB_CXXFLAGS="$CFLAGS $JPK_THREADS" export MPICH2LIB_CPPFLAGS="$CFLAGS $JPK_THREADS" export CXXFLAGS=$CFLAGS export FCFLAGS="$CFLAGS" # -fdefault-real-8 -fdefault-double-8" export FFLAGS="$CFLAGS" # -fdefault-real-8 -fdefault-double-8" export F90FLAGS="" export F77FLAGS="" if [ "$1" == "c" ]; then cd $JPK_MPICH2_S make distclean fi cd $JPK_MPICH2_S ./configure --prefix=$JPK_MPICH2 --enable-fast=all,O3 --with-thread-package=pthreads --with-device=ch3:nemesis --with-gnu-ld --enable-checkpointing --with-blcr=$JPK_BLCR --with-blcr-include= $JPK_BLCR/include --with-blcr-lib=$JPK_BLCR/lib --with-pm=hydra --with-hydrabss=rsh --enable-threads=runtime --disable-smpcoll --enable-static --enable-shared 2>&1 | tee $JPK_MPI_DIR/$JPK_VER_B/mes/mpich2.config make -j$JPK_JOBS 2>&1 | tee $JPK_MPI_DIR/$JPK_VER_B/mes/mpich2.make sudo make install 2>&1 | tee $JPK_MPI_DIR/$JPK_VER_B/mes/mpich2.install _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Joni-Pekka Kurronen
