Re: [mpich-discuss] Isend and Recv
I think it is because MPICH just crosses over the eager to rendezvous mode threshold, when n goes from 9999 to 99999. OpenMPI certainly uses a different threshold than MPICH. When you install MPICH, a utility program mpivars is also installed. Type 'mpivars | grep EAGER', you will get default values for various eager thresholds. In your case, export MPIR_CVAR_CH3_EAGER_MAX_MSG_SIZE=5000000 and you will get the same result as OpenMPI. --Junchao Zhang On Wed, Nov 5, 2014 at 11:20 AM, Zhen Wang <[email protected]> wrote:
Hi MPIers,
I have some questions regarding MPI_Isend() and MPI_Recv(). MPICH-3.1.3 is used to compile and run the attached code on Red Hat Enterprise Linux 6.3 (a shared memory machine). While n = 9999, the MPI_Recv() finishes immediately after MPI_Isend(): (This is what I understand and expect)
MPI 1: Recv started at 09:53:53. MPI 0: Isend started at 09:53:53. MPI 1: Recv finished at 09:53:53. MPI 0: Isend finished at 09:53:58.
When n = 99999, I get the following. The MPI_Recv() finishes after MPI_Wait():
MPI 1: Recv started at 09:47:56. MPI 0: Isend started at 09:47:56. MPI 0: Isend finished at 09:48:01. MPI 1: Recv finished at 09:48:01.
But with OpenMPI 1.8 and n = 99999, MPI_Recv() finishes immediately after MPI_Isend():
MPI 0: Isend started at 09:55:28. MPI 1: Recv started at 09:55:28. MPI 1: Recv finished at 09:55:28. MPI 0: Isend finished at 09:55:33.
Am I misunderstanding something here? In case the attached code is dropped, the code is included. Thanks in advance.
#include "mpi.h" #include <unistd.h> #include <stdio.h> #include "vector" #include <time.h>
int main(int argc, char* argv[]) { MPI_Init(&argc, &argv);
int rank; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
int n = 9999; std::vector<int> vec(n); MPI_Request mpiRequest; MPI_Status mpiStatus; char tt[9] = {0};
MPI_Barrier(MPI_COMM_WORLD);
if (rank == 0) { MPI_Isend(&vec[0], n, MPI_INT, 1, 0, MPI_COMM_WORLD, &mpiRequest); time_t t = time(0); strftime(tt, 9, "%H:%M:%S", localtime(&t)); printf("MPI %d: Isend started at %s.\n", rank, tt);
//int done = 0; //while (done == 0) //{ // MPI_Test(&mpiRequest, &done, &mpiStatus); //} sleep(5); MPI_Wait(&mpiRequest, &mpiStatus);
t = time(0); strftime(tt, 9, "%H:%M:%S", localtime(&t)); printf("MPI %d: Isend finished at %s.\n", rank, tt); } else { time_t t = time(0); strftime(tt, 9, "%H:%M:%S", localtime(&t)); printf("MPI %d: Recv started at %s.\n", rank, tt);
MPI_Recv(&vec[0], n, MPI_INT, 0, 0, MPI_COMM_WORLD, &mpiStatus);
t = time(0); strftime(tt, 9, "%H:%M:%S", localtime(&t)); printf("MPI %d: Recv finished at %s.\n", rank, tt); }
MPI_Finalize();
return 0; }
Best regards, Zhen
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
