Re: [mpich-discuss] Problem with "sock"-channel
If you are running on a single machine, Nemesis will use shared memory, so no TCP connection issues. ch3:sock will always use TCP and try to set up a socket connection. Rajeev On Jul 8, 2014, at 9:16 AM, Klaus Philip <[email protected]> wrote:
Hi Ken, The firewall has already been disabled and with the Nemesis channel it worked out of problems.... Do you maybe know another reason for this issue ?
Greetings, Philip ________________________________________ Von: [email protected] [[email protected]]" im Auftrag von "Kenneth Raffenetti [[email protected]] Gesendet: Dienstag, 8. Juli 2014 14:46 An: [email protected] Betreff: Re: [mpich-discuss] Problem with "sock"-channel
It looks like there may be a firewall blocking connections between machines. Try disabling it on your hosts and running again.
Ken
On 07/08/2014 04:31 AM, Klaus Philip wrote:
Sorry the pictures where not inserted correctly….
1)Error at my self written MPI program:
2)Error at the Intel MPI Benchmark:
Greetings,
Philip
*Von:*[email protected] [mailto:[email protected]] *Im Auftrag von *Klaus Philip *Gesendet:* Dienstag, 8. Juli 2014 11:26 *An:* [email protected] *Betreff:* [mpich-discuss] Problem with "sock"-channel
After reconfiguring, recompiling and reinstalling mpich2 with the sock-channel flag (--with-device=ch3:sock) to avoid active polling, every MPI program (Self written programs, and also the Intel MPI Benchmark too) breaks when it calls a MPI function:
1) Error at my self written MPI program:
2) Error at the Intel MPI Benchmark:
So I hope someone of you knows what issue is causing these errors. Greetings from Austria, Philip
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Thakur, Rajeev
