Re: [mpich-discuss] osu_latency test: why 8KB takes less time than 4KB and 2KB takes less time than 1KB?
Hi Abu, I think Jeff means that you should run your experiment with more iterations in order to get a stable results. - Increase the iteration of for loop in each execution (I think osu benchmark allows you to set it) - Run the experiments 10 or 100 times, and take the average and standard deviation. If you see a very small standard deviation (e.g., <=5%), then the trend is stable and you might not see such gaps. Best regards, Min On 2018/06/20 12:14, Abu Naser wrote:
Hello Jeff,
Yes, I am using a switch and other machines�are also connected with that switch.
If I remove other machines and just use my two node with the switch, then will it improve the performance by 200 ~ 400 iterations?
Meanwhile I will give a try with a single dedicated cable.
Thank you.
Best Regards,
Abu Naser
------------------------------------------------------------------------ *From:* Jeff Hammond <[email protected]> *Sent:* Wednesday, June 20, 2018 12:52:06 PM *To:* MPICH *Subject:* Re: [mpich-discuss] osu_latency test: why 8KB takes less time than 4KB and 2KB takes less time than 1KB? Is the ethernet connection a single dedicated cable between the two machines or are you running through a switch that handles other traffic?
My best guess is that this is noise and that you may be able to avoid it by running a very long time, e.g. 10000 iterations.
Jeff
On Wed, Jun 20, 2018 at 6:53 AM, Abu Naser <[email protected] <mailto:[email protected]>> wrote:
Good day to all,
I had run point to point osu_latency test in two nodes for 200 times.� Followings are the average time in microsecond for various size of the messages -
1KB�� �84.8514 us 2KB�� �73.52535 us 4KB�� �272.55275 us 8KB�� �234.86385 us 16KB�� �288.88 us 32KB�� �523.3725 us 64KB�� �910.4025 us
From the above looks like, 2KB message has less latency than 1 KB and 8KB has less latency than 4KB.
I was looking for explanation of this behavior� but did not get any.
1. MPIR_CVAR_CH3_EAGER_MAX_MSG_SIZEis set to 128KB. So none of the above message size is using Rendezvous protocol. Is there any partition inside eager protocol (e.g. 0 - 512 bytes, 1KB - 8KB, 16KB - 64KB)? If yes then what are the boundaries for them? Can I log them with debug-event-logging?
Setup I am using:
- two nodes has intel core i7, one with 16gb memory another one 8gb
- mpich 3.2.1, configured and build to use nemesis tcp
- 1gb Ethernet connection
- NFS is using for sharing
- osu_latency : uses MPI_Send and MPI_Recv
- MPIR_CVAR_CH3_EAGER_MAX_MSG_SIZE= 131072 (128KB)
Can anyone help me on that? Thanks in advance.
Best Regards,
Abu Naser
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Min Si
