Hi all, I've run some experiments for the MPICH2 threading overhead on BG/P and Breadboard (test program is attached). I don't remember if IBM reported that the performance stays constant with increasing threads or if it degrades, but I'm noticing a drop in performance (results below). On BG/P, this is slight yet noticeable, but on breadboard it's drastic. Note that 1 thread refers to "no extra threads" -- the main process does a self send/recv. This is not the fairest comparison since MPICH2-BG/P is based on MPICH2-1.0.4p1, while the breadboard runs are on MPICH2-trunk. I'll try out MPICH2-1.0.4p1 on breadboard as well. But as a longer term solution I'm trying to get MPICH2-BG/P ported to MPICH2-trunk so that I can easily try out any threading enhancements that might go in to trunk from here on. Thanks. -- Pavan ------------------------------------------------------------------------- BG/P: ---- # MPI Message Rate Test with 1 Threads # Size Latency (us) Message Rate (MMPS) 0 1.38 0.725 # MPI Message Rate Test with 2 Threads # Size Latency (us) Message Rate (MMPS) 0 3.59 0.557 # MPI Message Rate Test with 3 Threads # Size Latency (us) Message Rate (MMPS) 0 5.75 0.522 # MPI Message Rate Test with 4 Threads # Size Latency (us) Message Rate (MMPS) 0 7.93 0.504 Breadboard: ---------- # MPI Message Rate Test with 1 Threads # Size Latency (us) Message Rate (MMPS) 0 0.17 5.774 # MPI Message Rate Test with 2 Threads # Size Latency (us) Message Rate (MMPS) 0 1.69 1.180 # MPI Message Rate Test with 3 Threads # Size Latency (us) Message Rate (MMPS) 0 7.54 0.398 # MPI Message Rate Test with 4 Threads # Size Latency (us) Message Rate (MMPS) 0 2.04 1.963 -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Thanks for running the tests. I guess the next step, as we discussed at UIUC, would be to use a lock per vc instead of lock per process and see if that improves the message rate. (This simple change may not even work because some other data structures may need to be protected, but it is worth a try.) Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Tuesday, January 29, 2008 3:53 PM To: [email protected] Subject: [mpich2-core] MPICH2 Threading Overhead
Hi all,
Thanks.
-- Pavan
It would be great to run these tests. As we discussed, we should ignore for now that fact that a simple lock on each of the VCs is probably not entirely correct - however, it will give us some information on how much this approach might improve performance, at least on Breadboard. Bill On Jan 29, 2008, at 11:34 PM, Rajeev Thakur wrote:
Rajeev
Hi all,
Thanks.
-- Pavan
William Gropp Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
Cool, this is great! This means that there's lots of room for improvements :) Is the one-thread case exploiting the "skip locks/nesting count through thread-specific storage" optimization? It would be good to run the 1-thread case with this optimization both on and off in any case, just to get a measure of the overhead. Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote:
Hi all,
Thanks.
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji #include "mpi.h" #include <stdio.h> #include <stdlib.h> #include <math.h> #include <unistd.h> #include <pthread.h> #include <assert.h> #include <string.h>
#define REQUESTS 16 #define SKIP 100 #define LOOPS 1000000 #define MAX_THREADS 100
typedef struct { int nthreads; int size; } params_t;
char * s_buf, * r_buf; int skip = 10; int loop = 10000; double t_start = 0.0, t_end = 0.0; pthread_barrier_t pbarrier; params_t params;
void usage(char * progname) { fprintf(stderr, "Usage: %s -t [num_threads] -s [msg_size]\n", progname); MPI_Abort(MPI_COMM_WORLD, -1); }
void get_parameters(int orig_argc, char ** orig_argv) { int argc = orig_argc; char ** argv = orig_argv;
params.nthreads = -1; params.size = -1;
while (--argc && ++argv) { if (!strcmp(*argv, "-t")) { --argc; ++argv; params.nthreads = atoi(*argv); continue; } if (!strcmp(*argv, "-s")) { --argc; ++argv; params.size = atoi(*argv); continue; }
usage(orig_argv[0]); }
if ((params.nthreads <= 0) || (params.size < 0)) usage(orig_argv[0]); }
void * pingping_timed (void * arg) { int i, j; MPI_Request request[REQUESTS*2]; MPI_Status reqstat[REQUESTS*2];
pthread_barrier_wait(&pbarrier); for (i = 0; i < loop + skip; i++) { if (i == skip) t_start = MPI_Wtime();
for (j = 0; j < REQUESTS; j++) MPI_Irecv(r_buf, params.size, MPI_CHAR, 0, 0, MPI_COMM_WORLD, &request[j+REQUESTS]);
for (j = 0; j < REQUESTS; j++) MPI_Isend(s_buf, params.size, MPI_CHAR, 0, 0, MPI_COMM_WORLD, &request[j]);
MPI_Waitall(REQUESTS*2, request, reqstat); } pthread_barrier_wait(&pbarrier);
t_end = MPI_Wtime();
return NULL; }
int main(int argc, char ** argv) { int procs, i, pmode; pthread_t thread[MAX_THREADS]; void * retval[MAX_THREADS]; double latency, mrate;
MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &pmode); if (pmode != MPI_THREAD_MULTIPLE) { fprintf(stderr, "Thread Multiple not supported by the MPI implementation\n"); MPI_Abort(MPI_COMM_WORLD, -1); }
get_parameters(argc, argv); pthread_barrier_init(&pbarrier, NULL, params.nthreads);
if (params.size) { s_buf = (void *) malloc(params.size); r_buf = (void *) malloc(params.size); for (i = 0; i < params.size; i++) { s_buf[i] = '0'; r_buf[i] = '0'; } }
MPI_Comm_size(MPI_COMM_WORLD, &procs); if (procs != 1) { fprintf(stderr, "This is a 1 process test\n"); MPI_Abort(MPI_COMM_WORLD, -1); } MPI_Barrier(MPI_COMM_WORLD);
for (i = 1; i < params.nthreads; i++) pthread_create(&thread[i], NULL, (void*) pingping_timed, (void *) &i);
pingping_timed(NULL);
for (i = 1; i < params.nthreads; i++) pthread_join(thread[i], &retval[i]);
printf("# MPI Message Rate Test with %d Threads\n", params.nthreads); printf("# Size\t\tLatency (us)\tMessage Rate (MMPS) \n");
/* Latency is the time to send and recieve a message divided by two. */ latency = (t_end - t_start) * 1.0e6 / (2*loop*REQUESTS); mrate = params.nthreads / latency; printf("%d\t\t%0.2f\t\t%0.3f\n", params.size, latency, mrate);
MPI_Finalize();
return 0; }
What is the switch to turn on/off this optimization? Rajeev _____ From: [email protected] [mailto:[email protected]] On Behalf Of William Gropp Sent: Wednesday, January 30, 2008 8:30 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead Cool, this is great! This means that there's lots of room for improvements :) Is the one-thread case exploiting the "skip locks/nesting count through thread-specific storage" optimization? It would be good to run the 1-thread case with this optimization both on and off in any case, just to get a measure of the overhead. Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote: Hi all, I've run some experiments for the MPICH2 threading overhead on BG/P and Breadboard (test program is attached). I don't remember if IBM reported that the performance stays constant with increasing threads or if it degrades, but I'm noticing a drop in performance (results below). On BG/P, this is slight yet noticeable, but on breadboard it's drastic. Note that 1 thread refers to "no extra threads" -- the main process does a self send/recv. This is not the fairest comparison since MPICH2-BG/P is based on MPICH2-1.0.4p1, while the breadboard runs are on MPICH2-trunk. I'll try out MPICH2-1.0.4p1 on breadboard as well. But as a longer term solution I'm trying to get MPICH2-BG/P ported to MPICH2-trunk so that I can easily try out any threading enhancements that might go in to trunk from here on. Thanks. -- Pavan ------------------------------------------------------------------------- BG/P: ---- # MPI Message Rate Test with 1 Threads # Size Latency (us) Message Rate (MMPS) 0 1.38 0.725 # MPI Message Rate Test with 2 Threads # Size Latency (us) Message Rate (MMPS) 0 3.59 0.557 # MPI Message Rate Test with 3 Threads # Size Latency (us) Message Rate (MMPS) 0 5.75 0.522 # MPI Message Rate Test with 4 Threads # Size Latency (us) Message Rate (MMPS) 0 7.93 0.504 Breadboard: ---------- # MPI Message Rate Test with 1 Threads # Size Latency (us) Message Rate (MMPS) 0 0.17 5.774 # MPI Message Rate Test with 2 Threads # Size Latency (us) Message Rate (MMPS) 0 1.69 1.180 # MPI Message Rate Test with 3 Threads # Size Latency (us) Message Rate (MMPS) 0 7.54 0.398 # MPI Message Rate Test with 4 Threads # Size Latency (us) Message Rate (MMPS) 0 2.04 1.963 -- Pavan Balaji http://www.mcs.anl.gov/~balaji #include "mpi.h" #include <stdio.h> #include <stdlib.h> #include <math.h> #include <unistd.h> #include <pthread.h> #include <assert.h> #include <string.h> #define REQUESTS 16 #define SKIP 100 #define LOOPS 1000000 #define MAX_THREADS 100 typedef struct { int nthreads; int size; } params_t; char * s_buf, * r_buf; int skip = 10; int loop = 10000; double t_start = 0.0, t_end = 0.0; pthread_barrier_t pbarrier; params_t params; void usage(char * progname) { fprintf(stderr, "Usage: %s -t [num_threads] -s [msg_size]\n", progname); MPI_Abort(MPI_COMM_WORLD, -1); } void get_parameters(int orig_argc, char ** orig_argv) { int argc = orig_argc; char ** argv = orig_argv; params.nthreads = -1; params.size = -1; while (--argc && ++argv) { if (!strcmp(*argv, "-t")) { --argc; ++argv; params.nthreads = atoi(*argv); continue; } if (!strcmp(*argv, "-s")) { --argc; ++argv; params.size = atoi(*argv); continue; } usage(orig_argv[0]); } if ((params.nthreads <= 0) || (params.size < 0)) usage(orig_argv[0]); } void * pingping_timed (void * arg) { int i, j; MPI_Request request[REQUESTS*2]; MPI_Status reqstat[REQUESTS*2]; pthread_barrier_wait(&pbarrier); for (i = 0; i < loop + skip; i++) { if (i == skip) t_start = MPI_Wtime(); for (j = 0; j < REQUESTS; j++) MPI_Irecv(r_buf, params.size, MPI_CHAR, 0, 0, MPI_COMM_WORLD, &request[j+REQUESTS]); for (j = 0; j < REQUESTS; j++) MPI_Isend(s_buf, params.size, MPI_CHAR, 0, 0, MPI_COMM_WORLD, &request[j]); MPI_Waitall(REQUESTS*2, request, reqstat); } pthread_barrier_wait(&pbarrier); t_end = MPI_Wtime(); return NULL; } int main(int argc, char ** argv) { int procs, i, pmode; pthread_t thread[MAX_THREADS]; void * retval[MAX_THREADS]; double latency, mrate; MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &pmode); if (pmode != MPI_THREAD_MULTIPLE) { fprintf(stderr, "Thread Multiple not supported by the MPI implementation\n"); MPI_Abort(MPI_COMM_WORLD, -1); } get_parameters(argc, argv); pthread_barrier_init(&pbarrier, NULL, params.nthreads); if (params.size) { s_buf = (void *) malloc(params.size); r_buf = (void *) malloc(params.size); for (i = 0; i < params.size; i++) { s_buf[i] = '0'; r_buf[i] = '0'; } } MPI_Comm_size(MPI_COMM_WORLD, &procs); if (procs != 1) { fprintf(stderr, "This is a 1 process test\n"); MPI_Abort(MPI_COMM_WORLD, -1); } MPI_Barrier(MPI_COMM_WORLD); for (i = 1; i < params.nthreads; i++) pthread_create(&thread[i], NULL, (void*) pingping_timed, (void *) &i); pingping_timed(NULL); for (i = 1; i < params.nthreads; i++) pthread_join(thread[i], &retval[i]); printf("# MPI Message Rate Test with %d Threads\n", params.nthreads); printf("# Size\t\tLatency (us)\tMessage Rate (MMPS) \n"); /* Latency is the time to send and recieve a message divided by two. */ latency = (t_end - t_start) * 1.0e6 / (2*loop*REQUESTS); mrate = params.nthreads / latency; printf("%d\t\t%0.2f\t\t%0.3f\n", params.size, latency, mrate); MPI_Finalize(); return 0; } William Gropp Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
Don't you just NOT call MPI_thread_init? -d On 01/30/2008 10:43 AM, Rajeev Thakur wrote:
Rajeev
------------------------------------------------------------------------ *From:* [email protected] [mailto:[email protected]] *On Behalf Of *William Gropp *Sent:* Wednesday, January 30, 2008 8:30 AM *To:* [email protected] *Subject:* Re: [mpich2-core] MPICH2 Threading Overhead
Bill
Hi all,
Thanks.
-- Pavan
return NULL; }
MPI_Finalize();
return 0; }
That should be enough - if the single thread case is started with MPI_THREAD_FUNNELED instead of MPI_THREAD_MULTIPLE, the code *should* use the runtime test to see if it needs to use thread locks and thread-private storage or not. Though it isn't pure MPI, moving the get_parameters call ahead of MPI_Init_thread and using MPI_THREAD_FUNNELED if the number of threads is 1 would work; it would be even better to have an option to use thread_multiple in that case, just to make it easier to run all versions of the test. Bill On Jan 30, 2008, at 10:44 AM, Darius Buntinas wrote:
-d
--------------------------------------------------------------------- --- *From:* [email protected] [mailto:[email protected]] *On Behalf Of *William Gropp *Sent:* Wednesday, January 30, 2008 8:30 AM *To:* [email protected] *Subject:* Re: [mpich2-core] MPICH2 Threading Overhead Cool, this is great! This means that there's lots of room for improvements :) Is the one-thread case exploiting the "skip locks/nesting count through thread-specific storage" optimization? It would be good to run the 1-thread case with this optimization both on and off in any case, just to get a measure of the overhead. Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote:
Hi all,
This is not the fairest comparison since MPICH2-BG/P is based on MPICH2-1.0.4p1, while the breadboard runs are on MPICH2-trunk. I'll try out MPICH2-1.0.4p1 on breadboard as well. But as a longer term solution I'm trying to get MPICH2-BG/P ported to MPICH2- trunk so that I can easily try out any threading enhancements that might go in to trunk from here on.
Thanks.
-- Pavan
return NULL; }
MPI_Finalize();
return 0; }
I tried it on BG/P, and the performance does seem to improve a little bit -- from 0.725 MMPS to 0.795 MMPS. -- Pavan On 01/30/2008 10:52 AM, William Gropp wrote:
Bill
-d
------------------------------------------------------------------------ *From:* [email protected] <mailto:[email protected]> [mailto:[email protected]] *On Behalf Of *William Gropp *Sent:* Wednesday, January 30, 2008 8:30 AM *To:* [email protected] <mailto:[email protected]> *Subject:* Re: [mpich2-core] MPICH2 Threading Overhead Cool, this is great! This means that there's lots of room for improvements :) Is the one-thread case exploiting the "skip locks/nesting count through thread-specific storage" optimization? It would be good to run the 1-thread case with this optimization both on and off in any case, just to get a measure of the overhead. Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote:
Hi all,
Thanks.
-- Pavan
return NULL; }
MPI_Finalize();
return 0; }
It should be more visible with MPICH2 on breadboard than IBM's MPI. Don't know what they do. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Wednesday, January 30, 2008 11:09 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Bill
-d
*William Gropp
locks/nesting count
would be good to
and off in any
Hi all,
overhead on
don't remember
noticing a drop in
breadboard it's
threads" -- the
is based on
MPICH2-trunk.
But as a longer
to MPICH2-trunk
Thanks.
-- Pavan
return NULL; }
*) &i);
MPI_Finalize();
Pavan, Where did you get this threads.c test? The messaging rate benchmark that Sameer had sent is different. See attached mail. Rajeev
Hi all,
Thanks.
-- Pavan
Rajeev, It's the same test. I just cleaned out some stuff and made it easier to pass command line options. Do you see any major difference? -- Pavan On 01/30/2008 11:14 AM, Rajeev Thakur wrote:
Rajeev
Hi all,
Thanks.
-- Pavan
Subject: Messaging rate benchmark From: "Sameer Kumar" <[email protected]> Date: Tue, 25 Sep 2007 12:46:39 -0600 To: "Rajeev Thakur" <[email protected]>
To: "Rajeev Thakur" <[email protected]> CC: "'Pete Beckman'" <[email protected]>, "Craig Stunkel" <[email protected]>, "'William Gropp'" <[email protected]>, "Robert Wisniewski" <[email protected]>, "Gabor Dozsa" <[email protected]>
Hi, The message rate benchmark is attached. To compile
mpicc -o mrate-smp mrate-smp.c -lpthread
Please let me know if you have any problems running it. The number of threads to simulteneous inject messages is a runtime commandline parameter to the program. It seems to work fine on BG/P.
(See attached file: mrate-smp.c)
No I didn't study it. It just looked different. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Wednesday, January 30, 2008 11:17 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
Rajeev,
-- Pavan
Rajeev
Hi all,
Thanks.
-- Pavan
BTW, the Breadboard results suggest that the timing program is too simple in this environment. It would be good for the timing program to run the same test multiple times and at least report the spread in the results. Do we even believe the 170ns latency time for the 1- thread case? If so, is that the new record? (Note also that the test violates the same-send/recv-buffer rule :) ) Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote:
Hi all,
Thanks.
-- Pavan
The 170ns number is probably due to a race we found. Each thread writes to start_time and end_time. We'll fix the program and try again. -d On 01/30/2008 11:50 AM, William Gropp wrote:
BTW, the Breadboard results suggest that the timing program is too simple in this environment. It would be good for the timing program to run the same test multiple times and at least report the spread in the results. Do we even believe the 170ns latency time for the 1-thread case? If so, is that the new record?
Bill
Hi all,
Thanks.
-- Pavan
Ah! Of course. I hate thread programming :) All variables should be thread private unless otherwise annotated. Bill PS - It would still be good to run the test a few times - if the results are consistent, then all is well, if not, further upgrades are possible. On Jan 30, 2008, at 12:31 PM, Darius Buntinas wrote:
-d
BTW, the Breadboard results suggest that the timing program is too simple in this environment. It would be good for the timing program to run the same test multiple times and at least report the spread in the results. Do we even believe the 170ns latency time for the 1-thread case? If so, is that the new record? (Note also that the test violates the same-send/recv-buffer rule :) ) Bill On Jan 29, 2008, at 3:53 PM, Pavan Balaji wrote:
Hi all,
I've run some experiments for the MPICH2 threading overhead on BG/ P and Breadboard (test program is attached). I don't remember if IBM reported that the performance stays constant with increasing threads or if it degrades, but I'm noticing a drop in performance (results below).
Thanks.
-- Pavan
I just want to check what the benchmark should do. My understanding from the conference calls and Sameer's slides is that they're interested in the case where multiple threads of a process are sending/receiving to/from different processes. This allows the process to use multiple DMAs concurrently. Right now, we've been testing the case where one process is sending/receiving with itself. So moving the locks around VCs may decrease the size of the CS, but will still serialize. So what's the test we want to run? I imagine something like P processes each with P-1 threads where each thread is communicating with a different process. But then we need a machine with P(P-1) cores. On the 8-core nodes we have, we can run 3 processes with 2 threads each. But I think we need more threads to really stress things. It seems that what we can see from the one or two processes is the just the effect of the size of the CS. Comments? -d
I think we should worry about the locking overhead alone and not dilute the benchmark by adding network communication in it. So, each process sending to itself would be better, IMO. Btw, there was a suggestion earlier that we should try to place one lock per VC to see if the performance improves. However, I think we are jumping too far ahead with that. Even with a global lock, I would expect that the performance would stay constant (note that ideal behavior is linear increase in messaging rate with number of threads). However, it's dropping currently. I feel that the priority order should be: 1. Instrument the code for overheads with the global lock that is causing the performance to drop. 2. Instrument the hardware -- we never ran SMP mode BG/P with 4 processes (not threads) doing the messaging rate test separately. 3. Port MPICH2/BG to trunk so that we can try out new enhancements on both breadboard and BG/P. Thoughts? -- Pavan On 01/30/2008 01:07 PM, Darius Buntinas wrote:
Comments?
-d
Thoughts?
-- Pavan
I think we want to know how much is the locking overhead in the presence of network communication because that is what happens in reality.
Why would the performance stay constant with the global lock?
I think Sameer would like us to hack IBM's MPI implementation directly. That would save us the porting time as well (for now). Rajeev
Yeah, but if DCMF or the DMA engines have some overhead in threading, shouldn't we try to avoid it? I was trying to avoid the amount of code in non-MPICH2 part of the stack that is utilized. Once we fix the MPICH2 part, it of course makes sense to measure the overall stack. But for the time being, I think we should not dilute the test too much.
If only one thread is allowed to compute at any point of time, the performance should be the same as just having one thread, isn't it? This is the ideal case -- we might not achieve it if the locks are too expensive, for example. But we should know what is causing the overhead and see if we can avoid it.
Maintaining two stacks is a pain. Also, IBM's MPI implementation is MPICH2. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
May be we should run both versions of the test then.
Well, there is a lot more communication going on in the multithreaded case, and that is not being accounted for in the average time calculation.
In the long run yes, but in the very short run we want to show that we are touching their code, and that their effort in opening it was worthwhile. Their purpose in opening it is that they will get contributions back from the community. (There has been some separate discussion about them wanting the community to tune the collective communication routines that they haven't, e.g. the scatter/bcast performance problem I told them about.) Rajeev
Hmm.. You lost me. Are you saying that the multi-threaded case with 4 threads has more than 4X communication as compared to the single threaded case?
Got it. Agree, in that case. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Each thread calls Isend-Irecv 160,000 times. With 4 threads, there will be 640,000 calls. There is a barrier across the entire set. But there is no division by 4 in the time calculation. Rajeev
So the latency will increase by 4 times, but why will the messaging rate decrease? -- Pavan On 01/30/2008 03:45 PM, Rajeev Thakur wrote:
Rajeev
Ah, it's taken care of in the message rate calculation. I missed that. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Wednesday, January 30, 2008 3:47 PM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Rajeev
Below are the numbers while using MPI_PROC_NULL. The trend is the same. I guess the next step is to start instrumenting the code. BG/P: ---- # MPI Message Rate Test with 4 Threads # nthreads Size Latency (us) Message Rate (MMPS) 1 0 1.02 0.981 2 0 1.21 0.825 3 0 2.48 0.403 4 0 3.78 0.265 Breadboard: ---------- # MPI Message Rate Test with 4 Threads # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.39 2.589 2 0 0.85 1.183 3 0 4.68 0.213 4 0 4.36 0.229 Thanks. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Much as I'd love the instrumentation, at least some of the tests can be done with just a few changes. Currently, most of the code looks like this (in the proc-null mode): get global lock get thread-private storage, increment nest count ... do stuff (which assumes that the global lock is held) decrement nest count from thread-private storage release global lock We know that holding the global lock serializes the MPI code. The only other questions are (1) how much does the nest count cost, (2) how much would fine grain locking/atomic updates cost (e.g., for the communicator reference count update in an uncompleted Irecv), and (3) how narrow could a global lock be for the necessary updates instead of fine-grain? We can answer (1) by temporarily changing the definition of the nest count macros and rerunning these tests. We can answer a version of (2) by changing the increment/decrement macros to acquire/release the global lock. (3) will require inspection (and reorganization) of the code, following the work that Rajeev and I did. Bill On Jan 31, 2008, at 8:00 AM, Pavan Balaji wrote:
Thanks.
-- Pavan
I'll try out (1) and (2) and see if it works. Given that the lock contention in our test program is so high, there is a high likelihood that it might not work at all. -- Pavan On 01/31/2008 08:38 AM, William Gropp wrote:
Bill
Thanks.
-- Pavan
Thanks. Note that in (2), the idea is to not acquire the global lock in the func enter/exit; just as needed for the atomic updates (these aren't the only places that a local atomic op would be needed; the object allocator is another one and that isn't fine-grain ready). But for the proc-null test, it may be ok. My hypothesis is that (1) is a relatively small cost compared to the big lock and that (2) will give some improvement but at the cost of increased latency. As another goal (unrelated to threads), we should try to get the proc- null latency well under 1us on BG/P. Is the 1 thread case with THREAD_MULTIPLE or THREAD_FUNNELED? Bill On Jan 31, 2008, at 9:00 AM, Pavan Balaji wrote:
-- Pavan
Thanks.
-- Pavan
Bill,
As another goal (unrelated to threads), we should try to get the proc-null latency well under 1us on BG/P.
Note that the latency I sent is not regular ping-pong latency. The test does 16 Isends and 16 Irecvs, and a waitall. This is the way Sameer's original test was written, so I didn't want to modify that.
The single thread case doesn't use MPI_Init_thread at all. Thanks. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Ah, I had missed the fact that it didn't scale the results. So is the cost of the MPI call stack to the top of the ch3 code (where the proc-null test is) about 25ns on Breadboard and 60ns on BG/P? Bill On Jan 31, 2008, at 9:25 AM, Pavan Balaji wrote:
Bill,
Thanks.
-- Pavan
No. The latency number is already total_time / (LOOPS * 16), so you can't divide the latency number by 16 again. Sorry for the confusion. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Ok, so the latencies for the MPI call stack, even without the thread locks, is greater than we'd like. To get the desired message rate, we'll also need to improve that. Do these tests turn off the error checking? Would it be possible to run the tests with a return instead of a function call at various levels? Since the operations are basically no-ops, we (ie, Pavan) could then easily measure the contribution of each layer, without worrying about the cost of instrumentation. (This is less important than getting some more thread results, but it will be helpful in guiding any more substantive code changes). Bill On Jan 31, 2008, at 9:36 AM, Pavan Balaji wrote:
-- Pavan
No, they don't. Will do that.
Good idea. I'll try this out. Thanks. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Bill,
How will acquiring a global lock in the increment and releasing it in the decrement be different from the current global lock? These are anyway done at the same time currently for embedded MPI calls. Or did I misunderstand what you meant? -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
What I meant is narrowing the global lock to just the accesses to the shared data. In the current model, the global lock is held more or less for the duration of any MPI call. Many of these instructions are not on shared data, and can be safely executed concurrently by different threads. That is, currently the increment and decrement ops are just ++ and -- , because they are within the global lock. Instead, (2) looks at what it would cost to just grab and release the lock when needed (note that in many cases, we can use special instructions to eliminate the need for the lock entirely). Bill On Jan 31, 2008, at 6:01 PM, Pavan Balaji wrote:
Bill,
Thanks. Note that in (2), the idea is to not acquire the global lock in the func enter/exit; just as needed for the atomic updates (these aren't the only places that a local atomic op would be needed; the object allocator is another one and that isn't fine- grain ready). But for the proc-null test, it may be ok.
-- Pavan
Bill,
Do you mean acquire the global lock in the nest count increment? -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
No, something simpler. Just ignore the nest count code entirely; we only use it for error handling and perhaps for choosing whether to get the lock in nested MPI calls, of which these examples have none (or maybe one, if there's a Barrier somewhere). That will tell us how much the get thread specific etc costs. Its probably not much, though it might be a non-trivial part of the overall latency. Bill On Jan 31, 2008, at 1:03 PM, Pavan Balaji wrote:
Bill,
-- Pavan
Bill, The nesting functionality is just regular increment (not even atomic increment). So, do we expect it to have too much performance impact? I tried this on breadboard and the performance difference was within the variation due to noise. I'm trying it on BG/P now. -- Pavan On 01/31/2008 01:17 PM, William Gropp wrote:
Bill
Bill,
-- Pavan
The nesting functionality makes use of thread-private storage, which involves potentially a routine call (for the thread-private storage). I agree that it shouldn't cost much. But it is something that's needed only if MPI routines call MPI routines in the implementation; if instead MPI routines only called internal routines, the entire nesting block could be eliminated. Bill On Jan 31, 2008, at 2:49 PM, Pavan Balaji wrote:
Bill,
-- Pavan
Bill,
-- Pavan
For MPICH2 over BG/P, there is no way to control the nesting counters from within MPI. The DCMF layer is handling this. -- Pavan On 01/31/2008 02:55 PM, William Gropp wrote:
Bill
Bill,
-- Pavan
Bill,
-- Pavan
I removed the locks and nesting code (i.e., defined CS_ENTER/EXIT to nothing). I then changed the test to use MPI_Send and MPI_Recv (instead of isend and irecv), so I wouldn't have to use a lock when allocating a request. I then ran it on intel-loaner1 (dual quadcore) sending and receiving to MPI_PROC_NULL. Below are the results (first with locking intact, then with the locking removed). There's an improvement in message rate, but we still see message rate decrease as we add additional threads. What's interesting, is that even the single threaded case (that doesn't call MPI_Init_thread) shows improvement with locks removed. I can't explain that, since it's not using locks (or at least shouldn't). I'll look into this further. -d CONTROL CASE WITH LOCKING INTACT: # MPI Message Rate Test (10000 iterations 1 process(es) using MPI_PROC_NULL) # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.15 6.774 2 0 0.57 1.755 3 0 1.29 0.773 4 0 2.07 0.483 5 0 2.73 0.366 6 0 3.12 0.321 7 0 3.45 0.290 8 0 3.69 0.271 LOCKING REMOVED: % ./threads-2 -t 8 -l 10000 -pn # MPI Message Rate Test (10000 iterations 1 process(es) using MPI_PROC_NULL) # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.09 11.709 2 0 0.11 9.128 3 0 0.20 5.032 4 0 0.26 3.779 5 0 0.32 3.158 6 0 0.38 2.635 7 0 0.45 2.243 8 0 0.50 1.989 On 01/31/2008 02:55 PM, William Gropp wrote:
Bill
Bill,
-- Pavan
Bill,
-- Pavan
I removed the send and receive calls from the timing loop and replaced them with statements that increment and decrement a volatile variable. The volatile variable is in an array, so each thread accesses its own variable. The array elements are also padded so each is in its own cache line. So there should be no contention between threads on the variable. It looks like the test program is affecting the results. :-) # MPI Message Rate Test (10000000 iterations 1 process(es)) # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.00 306.547 2 0 0.00 483.213 3 0 0.01 184.908 4 0 0.01 114.825 5 0 0.01 78.911 6 0 0.02 59.759 7 0 0.02 47.333 8 0 0.03 38.067 -d On 01/31/2008 06:02 PM, Darius Buntinas wrote:
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Very weird. Can you send me your test program? I'd like to poke into it a bit. -- Pavan On 01/31/2008 06:21 PM, Darius Buntinas wrote:
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Sure, it's on bblogin ~buntinas/ng-mpich/mrate/test/threads-2.c . It's based on your threads.c that I grabbed from your directory around 4:00. I moved the pthread_barriers outside the timing loop and ran it again. The "message rate" improved, but still decreased as the number of threads increased. -d On 01/31/2008 06:24 PM, Pavan Balaji wrote:
-- Pavan
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
At what point does the OS decide to schedule these threads on different cores? In the classic multithreaded GUI application, the best strategy is to schedule all threads on the same core. Bill On Jan 31, 2008, at 6:58 PM, Darius Buntinas wrote:
-d
-d
I removed the locks and nesting code (i.e., defined CS_ENTER/ EXIT to nothing). I then changed the test to use MPI_Send and MPI_Recv (instead of isend and irecv), so I wouldn't have to use a lock when allocating a request. I then ran it on intel-loaner1 (dual quadcore) sending and receiving to MPI_PROC_NULL. Below are the results (first with locking intact, then with the locking removed).
-d
The nesting functionality makes use of thread-private storage, which involves potentially a routine call (for the thread- private storage). I agree that it shouldn't cost much. But it is something that's needed only if MPI routines call MPI routines in the implementation; if instead MPI routines only called internal routines, the entire nesting block could be eliminated.
Bill
Bill,
-- Pavan
Bill,
We know that holding the global lock serializes the MPI code. The only other questions are (1) how much does the nest count cost, (2) how much would fine grain locking/ atomic updates cost (e.g., for the communicator reference count update in an uncompleted Irecv), and (3) how narrow could a global lock be for the necessary updates instead of fine-grain? We can answer (1) by temporarily changing the definition of the nest count macros and rerunning these tests.
-- Pavan
Holy googly moogly! The OS schedules each process on a different core. I forced it to schedule everything on one core and the performance suddenly shot up. Here are the numbers: /* Round robin scheduling of processes to cores */ #bb09# /home/balaji> mpiexec -n 1 ./threads -t 4 -l 100000 -r # MPI Message Rate Test with 4 Threads # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.13 7.899 2 0 1.12 1.780 3 0 3.14 0.955 4 0 4.59 0.871 /* Scheduling all processes on one core */ #bb09# /home/balaji> mpiexec -n 1 ./threads -t 4 -l 100000 # MPI Message Rate Test with 4 Threads # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.13 7.855 2 0 0.26 7.819 3 0 0.38 7.826 4 0 0.51 7.768 -- Pavan On 01/31/2008 07:17 PM, William Gropp wrote:
Bill
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Ok, we can't do this kind of scheduling on the BG/P (can't have more than one process on a processor). So, I don't have those numbers. Given this new insight on the impact of process-to-core mappings, we'll need to take step back on what exactly our approach should be. It looks like the problem is not the locks alone. It is probably shared variables that are thrashing in cache. Does this mean we have to rethink how we allocate shared buffers and other objects shared between the different threads? -- Pavan On 01/31/2008 09:00 PM, Pavan Balaji wrote:
-- Pavan
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
These are very interesting. Is there a chance that the large latency on different cores is because of some occasional scheduling jitter - if one thread is occasionally not running when the others start, there will be one huge latency which will get averaged out in the test. That's less likely if they're all on one core. To test the other issue wrt shared data, can you put together a program that (a) reads from some shared data (like the MPIR_Process structure) and (b) updates some shared data (just a counter, e.g.,), and run a similar test? Other than access the MPIR_Process and PerThread structures, there shouldn't be much shared access in the MPI_PROC_NULL case (if this has the nesting count stuff enabled, that's another test - using pthread_get_specific (or whatever it is called) in the two cases. Bill On Feb 1, 2008, at 12:47 AM, Pavan Balaji wrote:
-- Pavan
Sure, it's on bblogin ~buntinas/ng-mpich/mrate/test/ threads-2.c . It's based on your threads.c that I grabbed from your directory around 4:00.
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
It's unlikely that there's any scheduling jitter. There are exactly the same number of processes as cores in the round-robin case (worse performance case), so there should not be any contention. Also, if there was some jitter, it would show up as noise. The drop in performance with increasing threads is *very* consistent. There could be scheduling jitter in the single core case since all processes are scheduled on the same core. But this is the case with the higher performance. Also, since the lock anyway serializes the code, it should not matter that the processes are sharing the same core. I agree that this is not the ideal behavior. But it'll let us narrow down the non-lock-related issues.
Ok, I can try this.
Is there a way to find out what data is thrashing across the different cores without analyzing the entire source code? The PerThread stuff should *not* be shared, right? Each thread allocates this individually and access it individually. Also, I think MPIR_Process will only be written to at the start of the program and only read after that. So, that should not cause any cache thrashing either. I think PAPI is my friend here. Let me try that. Btw, the nesting count stuff was not disabled in the tests I ran. But that's a thread private field too. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
There's always some other processes running (demons etc.), so you do need to be careful about what the OS is doing. The code was designed to minimize the updates of shared structures, so it is odd that the threads on separate cores are showing such bad performance. On the perthread case, I don't know if any special effort was made to ensure that the perthread data structures were on separate cache lines. The accesses to the MPIR_Process structure will also depend on the cache policy on loads - we're hoping that read access is shared, but if it isn't, we'd see something like this. Bill On Feb 1, 2008, at 10:32 AM, Pavan Balaji wrote:
Ok, I can try this.
-- Pavan
Yeah, but they are all sleeping or awake very rarely. On a 1-node benchmark, I don't know if that would add too much overhead.
Yeah, I was looking through the code and couldn't find any obvious problematic spots. This will require more digging into the code.
I know that AMD allows for shared read. So on breadboard at least this should not be a problem. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
It looks like the global_mutex within MPIR_ThreadInfo is causing most of the cache misses. But since this is used to get the global lock, we can't really avoid this in a straight forward manner. Anyway, here are some results showing the cache misses too: #bb01# /home/balaji/projects/mpi/threads> ./threads -t 4 # MPI Message Rate Test with 4 threads # nthreads Size Latency (us) Message Rate (MMPS) L2_DCM 1 0 0.35 2.830 17 2 0 0.29 6.875 7 3 0 0.38 7.908 32 4 0 0.51 7.886 29 #bb01# /home/balaji/projects/mpi/threads> ./threads -t 4 -r # MPI Message Rate Test with 4 threads # nthreads Size Latency (us) Message Rate (MMPS) L2_DCM 1 0 0.36 2.785 17 2 0 1.13 1.778 17820628 3 0 2.65 1.134 53253060 4 0 4.20 0.952 93324287 The base case performance (with just one thread) is not the same as what I reported earlier because of some overheads in the FC6 stack. The earlier numbers were on Ubuntu Feisty which was achieving the peak messaging rate for one thread itself. FC6 is taking 3 threads to do the same. But the main focus of these results are the L2 data cache misses. Notice that the cache misses have gone up from nearly zero to tens of millions. Fine-grained locks might improve this overhead as well. I'll work on that next. -- Pavan On 02/01/2008 09:37 AM, William Gropp wrote:
Bill
-- Pavan
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Are the majority of the cache misses due to the global lock (i.e., MPIU_THREAD_SINGLE_CS_ENTER/_EXIT)? Try commenting that macro out then run the test with blocking communication and proc_null (to avoid the need for a lock). Another thing to check is to instrument MPICH2 to read only the L2 cache misses around the lock/unlock operations, then read the total L2 cache misses for the MPI calls. I'm just interested in seeing how bad the rest of the code is wrt L2 cache misses. I'm out of town next week, but I'll try to work on installing PAPI on the intel-loaner machines and running some of these tests. -d On 02/03/2008 04:05 AM, Pavan Balaji wrote:
-- Pavan
Bill
-- Pavan
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
I agree with Darius's suggestions - an easy test using proc_null is to remove the global mutex from the cs_enter/exit to see if that's the dominant source of the cost. (I'm also not exactly sure how the - r changes the test). With the global mutex in place, if the threads that don't have the lock are busy waiting on it, that traffic might look like a L2 miss. With the global lock in place, at any time, all but one thread will be trying to acquire the lock, I'd expect a lot of memory traffic. The fine grain locks should eliminate that contention. As Darius notes, it would be interesting to know what other sources of L2 misses there might be (e.g., reading from the shared MPIR_Process structure). Bill On Feb 3, 2008, at 9:17 AM, Darius Buntinas wrote:
-d
Bill
-- Pavan
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
I agree with Darius's suggestions - an easy test using proc_null is to remove the global mutex from the cs_enter/exit to see if that's the dominant source of the cost. (I'm also not exactly sure how the -r changes the test).
I tried removing the global mutex last night, but the test segfaults. I'll need to dig in more to figure out how exactly I can trick the "no-lock" case. Btw, "-r" is the round-robin allocation of processes, i.e., each core gets a different process. The default run (without -r) is for all processes on one core.
I think pthread lock waits are blocking for events, not polling. I'll check.
From my tests with blocking send, it looks like that's the only source. The non-blocking isend model is a lot more complicated to find the cache misses, but given that the number of cache misses is high for the blocking version as well, the lock seems to be a major, if not the only, contributor to the cache misses. That's not to say that I'll not try out the non-blocking version, but that'll take some more time. Are we having the telecon with IBM this Tuesday? -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
Btw, the code has grown out of a single file. I've added it into a temporary SVN repository. You can check it out using: $ svn co svn+ssh://shakey/sandbox/balaji/svn/projects/threads/trunk threads Thanks. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
The results make sense if thread_lock polls on a memory location - when the threads are on different cores, they (may) have to take the L2 misses. If the thread_lock is waiting for an event, the cost of a lock will be very large (compared to a cache miss), as an event manager will be involved (such as the OS). So I hope that the mutex is implemented to poll (and possibly yield); that's what you'd want for threads that should run concurrently. I'd guess that the thread yields after a few tries; that would let the other threads on the same core run efficiently. Yet another reason to try some of the finer-grain approaches. And we need a better term (we don't want to imply that we must use locks) for the fine-grain approach. Bill On Feb 3, 2008, at 1:34 PM, Pavan Balaji wrote:
-- Pavan
Bill,
I verified online that AMD Opterons do have a shared state for their caches (they use MOESI coherency). So, we should not see L2 cache misses till someone updates the lock, i.e., either locks or unlocks. Empty polls should just change the cache to the shared state. Of course, it is possible (and likely?) that the lock keeps getting acquired and released if all threads call blocking calls, since when a thread blocks it releases the lock and tries to get it back once it receives an event.
This seems logical. However, I wrote a simple program with two threads, where the first thread acquires the lock and sleeps for 10 seconds, while the second thread waits for the lock to get released. In this case, if the wait was polling, I should notice 100% usage on one core. But, I don't see that. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
On the polling, what I would expect is for the lock to attempt to acquire the lock for some number of cycles, then for it to execute yield. That's a good compromise between performance in the expected case (lock is not held) and load management. Of course, this is all speculation. Thanks for running all of these examples. It might be useful to have a simple program that does not use the pthread mutex but tries one of the following. Let v be the lock (int volatile v). Version 1: while (fetch_and_incr(v) != 0) decr(v); Version 2: do { if (v==0) { w = fetch_and_incr(v); if (w==0) return; decr(v); } spin_delay; while (1); Version 3: do { ntry=1000; while( ntry-- && (w=fetch_and_incr(v)) != 0) decr(v); if (w == 0) return; decr(v); yield_thread(); } while (1); (Version 4 could enqueue this thread on a list of waiting threads and suspend, waiting for an event. Etc.). Note that Version 1 is the fastest in the case that the lock is not held. It would be interesting to see what the L2 behavior of these is like. I did some quick googling, and one implementation of pthread_mutex eventually calls this: static __inline int __cpu_simple_lock_try(__cpu_simple_lock_t *lockp) { int r = (x86_atomic_testset_i(lockp, __SIMPLELOCK_LOCKED) == __SIMPLELOCK_UNLOCKED); __lockbarrier(); return (r); } And here is the atomic_testset: static __inline int x86_atomic_testset_i(volatile int *, int); static __inline int x86_atomic_testset_i(volatile int *__ptr, int __val) { __asm volatile ("xchgl %0,(% 2)" :"=r" (__val):"0" (__val),"r" (__ptr)); return __val; } I believe that the RMW operations like xchgl will cause a cache flush of the affected line. Bill On Feb 3, 2008, at 11:17 PM, Pavan Balaji wrote:
Bill,
-- Pavan
Darius, I ran a bunch of tests last night. I didn't send out the details in the previous email, as they were too many cases. Here are the details for the ones you asked for:
Note that the blocking send call also calls the lock. The lock is released only when the call actually blocks for an event. So there are some cache misses even in this case, though lesser than in the non-blocking version. I also tried getting rid of the lock and running (an incorrect version of) the test. But that seg faults.
Yup, tried that too. Well, in the blocking case I got MPI_Send to return immediately after the lock/unlock and there was not much change in the cache misses. So, it looks like the lock/unlock is the major contributor to the cache misses. For the MPI_Isend case, that's more difficult to figure out. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
If you remove the lock, you need to use blocking calls and use proc_null to avoid a segfault. -d On 02/03/2008 01:27 PM, Pavan Balaji wrote:
OK I fixed a bug in the test program that calculated the message rate. I then kept the number of threads created constant and kept the extra ones idle (waiting in a pthread barrier). This should normalize differences in scheduling, barrier times, etc. Now when I run the dummy test (no MPI calls) I get expected results: % ./threads-2 -t 8 -l 10000000 # MPI Message Rate Test (10000000 iterations 1 process(es)) # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.00 452.149 2 0 0.00 444.716 3 0 0.00 442.400 4 0 0.00 444.068 5 0 0.00 441.870 6 0 0.00 442.154 7 0 0.00 442.156 8 0 0.00 442.810 Running on a single core shows "message rate" decreasing as the number of active threads increase, as expected. % taskset -c 1 ./threads-2 -t 8 -l 10000000 # MPI Message Rate Test (10000000 iterations 1 process(es)) # nthreads Size Latency (us) Message Rate (MMPS) 1 0 0.00 454.413 2 0 0.00 226.710 3 0 0.01 150.964 4 0 0.01 113.207 5 0 0.01 90.535 6 0 0.01 75.443 7 0 0.02 64.649 8 0 0.02 56.562 I'll run some non-dummy tests and see what happens. -d On 01/31/2008 06:21 PM, Darius Buntinas wrote:
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Darius, What exactly is the pthread_barrier problem? Can you point it out in the code? -- Pavan On 02/01/2008 11:08 AM, Darius Buntinas wrote:
-d
-d
-d
Bill
Bill,
-- Pavan
Bill,
-- Pavan
Did you fix the t_start, t_end problem, i.e. make them thread private or have only the main thread measure the time. Anyhow only the main thread is printing the time. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Thursday, January 31, 2008 8:00 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
Thanks.
-- Pavan
Yes, Darius and I made a bunch of modifications to the code to fix the shared variables problem, get aggregate timings from all threads, etc. The latest version of the code is attached. -- Pavan On 01/31/2008 10:31 AM, Rajeev Thakur wrote:
Rajeev
Thanks.
-- Pavan
In the code I have, the message rate is calculated as nthreads/latency. However, the numbers below seem to be calculated as 1/latency. Which is right? Rajeev
Thanks.
-- Pavan
Oh, good catch. I think it should be nthreads/latency. My bad. -- Pavan On 01/31/2008 10:36 AM, Rajeev Thakur wrote:
Rajeev
Thanks.
-- Pavan
No, I think it's taken care of in your new code because you are dividing latency by the number of threads. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Thursday, January 31, 2008 10:44 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Rajeev
Thanks.
-- Pavan
Actually that's what I thought when I wrote the code, but the latency number is also being aggregated. That means we have to multiply by nt^2. That is, average latency = total_latency / nt (this is already there). But total messaging rate = nt / average_latency. I'm missing the second nt. -- Pavan On 01/31/2008 10:45 AM, Rajeev Thakur wrote:
Rajeev
-- Pavan
Rajeev
Thanks.
-- Pavan
Ah yes.
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Thursday, January 31, 2008 10:48 AM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Rajeev
-- Pavan
Rajeev
Thanks.
-- Pavan
(Sorry for the null message) We know that one source of the performance drop in this example is that there is a common lock. Further, instrumentation is tricky, because in some cases, the cost of the lock operations themselves should be relatively small (if the lock doesn't wait) and timing short durations accurately can be tricky. An alternative, at least as a first step, is to disable to thread-safe version of the operation and measure the difference (this has its own sources of errors, of course). For example, it might be possible to turn off the handling of the nesting count - that would tell us whether we need to switch to a strategy that doesn't use a thread-specific nest count. We could also move the global lock into the communication device - again, this would introduce a race, but if the code ran, we'd know something about the cost of serializing the rest of the code. One of the reasons for using the single global lock was that the hope was that most of the overhead (for real messages, not zero-byte messages) was in the actual communications, and the one big lock wouldn't be the dominant term. Doing the test with one lock per VC helps test that hypothesis, and may give real applications more of a performance boost than eliminating the global lock. For that test, we should send reasonable-sized messages. Bill On Jan 30, 2008, at 1:17 PM, Pavan Balaji wrote:
Thoughts?
-- Pavan
Actually, you can do something like the halo test I've added to mpptest to check that a single process can use multiple links concurrently. In that case, you really need a system with 2t cores, where t processes can run 1 thread and 1 process runs t threads; each of those t threads communicates with a uniquely chosen process. That will test sending on t different VCs; you only time the process with t threads. Along the lines of the experiments that Rajeev and I did, users will expect the overhead to be small, so in the current test, the messaging rate should stay relatively constant (actually increasing slightly as the non-communication part can be run concurrently, assuming we avoid the one big lock - that, by the way, is anther test - just use the per VC lock, and disable to global lock. This is also wrong, but does help set a limit on the potential performance with the current code. A harder question is can the lock on the VC also be narrowed so that threads communicating on the same VC spend as little time as possible coordinating access to the VC. Eg, if there was a separate thread performing at actions on the VC, then the only time involved for the compute/user threads would be enqueueing or dequeueing an operation. Bill On Jan 30, 2008, at 1:07 PM, Darius Buntinas wrote:
Right now, we've been testing the case where one process is sending/ receiving with itself. So moving the locks around VCs may decrease the size of the CS, but will still serialize.
Comments?
-d
Well the original code IBM sent does not have this 1 process limitation. See attached. The threads of a process communicate with the threads of another process. I think that is a better test. Why did we change it? Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Darius Buntinas Sent: Wednesday, January 30, 2008 1:07 PM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
Comments?
-d
Yeah, I misunderstood the code. Darius pointed it out too. However, it again comes back to what exactly we want to measure -- threading overhead in MPICH2 or threading overhead in the overall communication and networking stack? -- Pavan On 01/30/2008 01:57 PM, Rajeev Thakur wrote:
Rajeev
Comments?
-d
I would say threading overhead as might be seen by an application. The tests in www.mcs.anl.gov/~thakur/thread-tests also try to measure that. I will point Sameer at those. Rajeev
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Wednesday, January 30, 2008 2:57 PM To: [email protected] Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Rajeev
Comments?
-d
Because of how MPICH2 is implemented, there's one test that we could use to measure the impact of the global lock. Have t threads send to/receive from MPI_PROC_NULL . The test for this destination is, IIRC, deep in the ch3 code. This will avoid *all* of the communication device while measuring most of the MPICH2 stack. Bill On Jan 30, 2008, at 3:03 PM, Rajeev Thakur wrote:
Rajeev
-- Pavan
Rajeev
Comments?
-d
Ah, perfect. This was what I was looking for. I'm working on some tests to figure out the overhead in SMP and VN modes; once I do that I'll get to this. -- Pavan On 01/30/2008 03:13 PM, William Gropp wrote:
Bill
I would say threading overhead as might be seen by an application. The tests in www.mcs.anl.gov/~thakur/thread-tests <http://www.mcs.anl.gov/~thakur/thread-tests> also try to measure that. I will point Sameer at those.
Rajeev
-----Original Message----- From: [email protected] <mailto:[email protected]> [mailto:[email protected]] On Behalf Of Pavan Balaji Sent: Wednesday, January 30, 2008 2:57 PM To: [email protected] <mailto:[email protected]> Subject: Re: [mpich2-core] MPICH2 Threading Overhead
-- Pavan
Rajeev
-----Original Message----- From: [email protected] <mailto:[email protected]> [mailto:[email protected]] On Behalf Of Darius Buntinas Sent: Wednesday, January 30, 2008 1:07 PM To: [email protected] <mailto:[email protected]> Subject: Re: [mpich2-core] MPICH2 Threading Overhead
Comments?
-d
participants (4)
Darius Buntinas -
Pavan Balaji -
Rajeev Thakur -
William Gropp
