Re: [petsc-dev] Question about MPICH device we use
On Wed, Jul 22, 2020 at 2:34 PM Satish Balay <[email protected]> wrote:
BTW: Last we compared performance [many years ago] the difference was not a factor of 2 - but a few percentage points.
Which petsc example can we re-run to compare?
Not sure. Scott I think was running his new MHD stuff. His post is on the #general channel on the Firedrake slack. Thanks, Matt
Satish
On Wed, 22 Jul 2020, Satish Balay via petsc-dev wrote:
Primarily because ch3:sock performance does not degrade in oversubscribe mode - which is developer friendly - i.e on your laptop.
And folks doing optimized runs should use a properly tuned MPI for their setup anyway.
In this case --download-mpich-device=ch3:nemesis is likely appropriate if using --download-mpich [and not using a separate/optimized MPI]
Having defaults that satisfy all use cases is not practical.
Satish
On Wed, 22 Jul 2020, Matthew Knepley wrote:
We default to ch3:sock. Scott MacLachlan just had a long thread on the Firedrake list where it ended up that reconfiguring using ch3:nemesis had a 2x performance boost on his 16-core proc, and noticeable effect on the 4 core speedup.
Why do we default to sock?
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
