Yeah - we fixed PETSc [maint] to not require -fallow-argument-mismatch - and use it only with externalpacakges that need it And we do have one test box with gfortran-10 - but the test coverage with it is minimal. [mostly no externalpacakges] Satish On Mon, 13 Jul 2020, Jed Brown wrote:
You want this for PETSc or for external packages? We add it for a bunch of external packages. I've been building PETSc with gcc/gfortran-10 for months now.
Matthew Knepley <[email protected]> writes:
Do we have gfortran from gcc 10 running anywhere? We need a check to enable
from configure. Should be as simple as compiling Fortran which has PetscObjectSetName() in it.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Satish Balay
