Here is the (ARM) build with gnu-10 compilers https://gitlab.com/petsc/petsc/-/jobs/636087963 Compilers: C Compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O Version: gcc (GCC) 10.1.1 20200507 (Red Hat 10.1.1-1) C++ Compiler: mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O Version: g++ (GCC) 10.1.1 20200507 (Red Hat 10.1.1-1) Fortran Compiler: mpif90 -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O Version: GNU Fortran (GCC) 10.1.1 20200507 (Red Hat 10.1.1-1) Satish On Mon, 13 Jul 2020, Satish Balay via petsc-dev wrote:
Yeah - we fixed PETSc [maint] to not require -fallow-argument-mismatch - and use it only with externalpacakges that need it
And we do have one test box with gfortran-10 - but the test coverage with it is minimal. [mostly no externalpacakges]
Satish
On Mon, 13 Jul 2020, Jed Brown wrote:
You want this for PETSc or for external packages? We add it for a bunch of external packages. I've been building PETSc with gcc/gfortran-10 for months now.
Matthew Knepley <[email protected]> writes:
Do we have gfortran from gcc 10 running anywhere? We need a check to enable
from configure. Should be as simple as compiling Fortran which has PetscObjectSetName() in it.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Satish Balay
