Re: [petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
In your configure.log, I see --with-mpi=0, so I’m surprised this is even running, and even more surprised that you are encountering OpenMPI errors. Is this from a different build? Thanks, Pierre
On 12 Sep 2021, at 7:18 PM, Antonio T. sagitter <[email protected]> wrote:
Okay. I will try to set correctly the DATAFILESPATH options.
I see even this error:
not ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create # Error code: 68
# PetscSF Object: 4 MPI processes
# type: window
# [0] Number of roots=3, leaves=2, remote ranks=2
# [0] 0 <- (3,1)
# [0] 1 <- (1,0)
# [1] Number of roots=2, leaves=3, remote ranks=2
# [1] 0 <- (0,1)
# [1] 1 <- (2,0)
# [1] 2 <- (0,2)
# [2] Number of roots=2, leaves=3, remote ranks=3
# [2] 0 <- (1,1)
# [2] 1 <- (3,0)
# [2] 2 <- (0,2)
# [3] Number of roots=2, leaves=3, remote ranks=2
# [3] 0 <- (2,1)
# [3] 1 <- (0,0)
# [3] 2 <- (0,2)
# [0] Roots referenced by my leaves, by rank
# [0] 1: 1 edges
# [0] 1 <- 0
# [0] 3: 1 edges
# [0] 0 <- 1
# [1] Roots referenced by my leaves, by rank
# [1] 0: 2 edges
# [1] 0 <- 1
# [1] 2 <- 2
# [1] 2: 1 edges
# [1] 1 <- 0
# [2] Roots referenced by my leaves, by rank
# [2] 0: 1 edges
# [2] 2 <- 2
# [2] 1: 1 edges
# [2] 0 <- 1
# [2] 3: 1 edges
# [2] 1 <- 0
# [3] Roots referenced by my leaves, by rank
# [3] 0: 2 edges
# [3] 1 <- 0
# [3] 2 <- 2
# [3] 2: 1 edges
# [3] 0 <- 1
# current flavor=CREATE synchronization=FENCE MultiSF sort=rank-order
# current info=MPI_INFO_NULL
# [buildhw-x86-09:1135574] *** An error occurred in MPI_Accumulate
# [buildhw-x86-09:1135574] *** reported by process [3562602497,3]
# [buildhw-x86-09:1135574] *** on win rdma window 4
# [buildhw-x86-09:1135574] *** MPI_ERR_RMA_RANGE: invalid RMA address range
# [buildhw-x86-09:1135574] *** MPI_ERRORS_ARE_FATAL (processes in this win will now abort,
# [buildhw-x86-09:1135574] *** and potentially your MPI job)
# [buildhw-x86-09.iad2.fedoraproject.org:1135567] 3 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal
# [buildhw-x86-09.iad2.fedoraproject.org:1135567] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Looks like an error related to OpenMPI-4*: https://github.com/open-mpi/ompi/issues/6374
Thank you.
On 9/12/21 18:09, Pierre Jolivet wrote:
Hello, Did you copy the files from https://gitlab.com/petsc/datafiles <https://gitlab.com/petsc/datafiles> before the make check? cfd.1.10 is not part of https://gitlab.com/petsc/petsc <https://gitlab.com/petsc/petsc>, so you either need to copy the files from the datafiles repository, or remove the --DATAFILESPATH=/home/sagitter/rpmbuild/BUILD/petsc-3.15.4/petsc-3.15.4/share/petsc/datafiles configure option. Thanks, Pierre
On 12 Sep 2021, at 6:02 PM, Antonio T. sagitter <[email protected] <mailto:[email protected]>> wrote:
Hi all.
This error is repeated when the tests are compiled in PETSc-3.15.4 compilation: https://paste.in/MhdNjf <https://paste.in/MhdNjf>
This happens in Fedora 34 x86_64 with gcc-11.2.1
make.log and configure.log are attached -- --- Antonio Trande Fedora Project mailto: [email protected] GPG key: 0x29FBC85D7A51CC2F GPG key server: https://keyserver1.pgp.com/ <make_configure.zip><OpenPGP_0x29FBC85D7A51CC2F.asc>
participants (1)
Pierre Jolivet
