Re: [petsc-dev] git repo branches housekeeping
http://stackoverflow.com/questions/12495756/why-doesnt-git-allow-me-to-safel... Ah - I think you've done the following (or equivalent)- so git is complaining. git checkout barry/download-mstk <edit/test> git commit [did not do 'git push'] git checkout master git merge barry/download-mstk Since these branches are already merged to 3.7 - and also deleted on remote/server - you can 'force delete' the local ones. git branch -D barry/download-mstk shri/add-tsevent-to-powergrid-examples [also 'git fetch -p'] Satish On Mon, 25 Apr 2016, Barry Smith wrote:
$ git log v3.7..shri/add-tsevent-to-powergrid-example fatal: ambiguous argument 'v3.7..shri/add-tsevent-to-powergrid-example': unknown revision or path not in the working tree. Use '--' to separate paths from revisions, like this: 'git <command> [<revision>...] -- [<file>...]' ~/Src/petsc (next=) $ git log v3.7..barry/download-mstk ~/Src/petsc (next=)
On Apr 25, 2016, at 1:12 PM, Satish Balay <[email protected]> wrote:
What do you have for
git fetch git log v3.7..barry/download-mstk got lpg v3.7..shri/add-tsevent-to-powergrid-examples
Satish
warning: not deleting branch 'barry/download-mstk' that is not yet merged to 'refs/remotes/origin/barry/download-mstk', even though it is merged to HEAD. error: The branch 'barry/download-mstk' is not fully merged. If you are sure you want to delete it, run 'git branch -D barry/download-mstk'.
warning: not deleting branch 'shri/add-tsevent-to-powergrid-examples' that is not yet merged to 'refs/remotes/origin/shri/add-tsevent-to-powergrid-examples', even though it is merged to HEAD. error: The branch 'shri/add-tsevent-to-powergrid-examples' is not fully merged. If you are sure you want to delete it, run 'git branch -D shri/add-tsevent-to-powergrid-examples'.
On Apr 25, 2016, at 12:01 PM, Satish Balay <[email protected]> wrote:
ref: http://lists.mcs.anl.gov/pipermail/petsc-dev/2015-June/017808.html
I've deleted all deveopment branches that are already merged into maint (v3.7) from https://bitbucket.org/petsc/petsc
However if you wish to remove these branches from your clone - it has to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.7 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remove branch list info - you can do:
git fetch -p
For more housekeeping - look at the remaining local and remote branches and figure-out what to do. [perhaps some of them are intermediate branches during rebase - or abandoned features that should be deleted]. For my branches - I would do:
git branch git branch -r |grep balay
Satish ---------------- reference for self: $ git branch -r --merged v3.7 |egrep -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% > remote_branches_to_delete $ git push -u origin `cat remote_branches_to_delete` To [email protected]:petsc/petsc.git - [deleted] Fande-Kong/moved-partitioning-to-pcgasmsetup - [deleted] balay-to-maint-fix-vs2015-vsnprintf - [deleted] balay/add-KSPComputeRitz-patch - [deleted] balay/add-clang-sa-build - [deleted] balay/add-fortran-DMRemoveLabel - [deleted] balay/configure-pkg-git-autoupdate - [deleted] balay/el-parmetis-check - [deleted] balay/el_AxpyInterface_removal - [deleted] balay/fix-externalpackage-build-shared - [deleted] balay/fix-fortran-unused_variables - [deleted] balay/fix-sowing-valgrind - [deleted] balay/fix-streams-npmax - [deleted] balay/fix-win-isnan - [deleted] balay/ftn-command_argument - [deleted] balay/git-externalpackage-update - [deleted] balay/improve-odpes - [deleted] balay/rm-tree - [deleted] balay/superlu_dist-4.3 - [deleted] balay/superlu_dist-4.3-p1 - [deleted] balay/to-maint-add-mpiuni_mpi_in_place - [deleted] balay/to-maint-add-urlretrieve-timeout - [deleted] balay/to-maint-fix-fortran-fflag-order - [deleted] balay/to-maint-fix-gfortran51-warnings - [deleted] balay/to-maint-fix-win64-long - [deleted] balay/to-maint-metis-parmetis-nocxx - [deleted] balay/to-maint-migrate-builds - [deleted] balay/to-maint/update-superlu_dist-4.1 - [deleted] balay/update-elemental-0.86-pre - [deleted] balay/update-gmake-check - [deleted] balay/update-gnumake-41 - [deleted] balay/update-metis-xcode-fix-to-maint - [deleted] balay/update-mpich-3.2 - [deleted] balay/update-sowing-svn - [deleted] balay/update-superlu_dist_mar-16-294e2d0 - [deleted] barry-allow-vecset-nan-3.6 - [deleted] barry/Sylvain-gmres-symmetric - [deleted] barry/add-concurrencykit - [deleted] barry/add-dmdavecgetarrayreadf90/maint - [deleted] barry/add-dmshellcreaterestriction - [deleted] barry/add-mpiu_allreduce - [deleted] barry/add-pcfieldsplit-logevent - [deleted] barry/add-pcreset-hypre - [deleted] barry/add-pcreset-hypre-for-master - [deleted] barry/all-petscoptionssetvalue-beforepetscinitialize - [deleted] barry/always-mark-floats - [deleted] barry/better-matsetoption-error - [deleted] barry/check-for-PetscInt-overflow - [deleted] barry/check-nullspace-properties - [deleted] barry/cleanup-pcsetupcalled - [deleted] barry/cleanup-petscsys - [deleted] barry/download-mstk - [deleted] barry/download-pflowtran - [deleted] barry/downloads - [deleted] barry/error-on-extern-c-of-petscincludes - [deleted] barry/feature-force-setting-exactfinaltime - [deleted] barry/feature-linesearch-monitor - [deleted] barry/feature-ts-monitor-binary - [deleted] barry/fix-dmnetworkcomponentalignment - [deleted] barry/fix-log-summary-format - [deleted] barry/fix-matgetlocalsubmatrix - [deleted] barry/fix-matheaderreplace - [deleted] barry/fix-matseqaijgetarrayf90 - [deleted] barry/fix-mg-coarse-ksp-defaults - [deleted] barry/fix-mg-coarse-redundant - [deleted] barry/fix-mpiuni - [deleted] barry/fix-mumps-destroy - [deleted] barry/fix-nonew-notcollective/maint - [deleted] barry/fix-petscviewer-attempt-2 - [deleted] barry/fix-private-functions - [deleted] barry/fix-stageevent-idtypes - [deleted] barry/fix-ts-matshift-error - [deleted] barry/fix-win-e-00 - [deleted] barry/fix-xsdktrilinos - [deleted] barry/fixes-for-release-1 - [deleted] barry/improve-git-download - [deleted] barry/improve-minres - [deleted] barry/improve-opt-handling - [deleted] barry/improve-ts-monitor-interpolation - [deleted] barry/list-downloads - [deleted] barry/maint/fix-snessetupdate-fortran - [deleted] barry/maint/mv-matnullspace-to-mat - [deleted] barry/make-nonstatic-petscviewerflowcontrol - [deleted] barry/master/fix-cuda-extern-c - [deleted] barry/monitor-fromoptions - [deleted] barry/not-single-precision - [deleted] barry/optimize-xolotl - [deleted] barry/petscoptions-object - [deleted] barry/remove-matmffdaddnullspace/master - [deleted] barry/remove-pc-nonzero-guess - [deleted] barry/remove-pcsetup-mg-changeofpreonly/master - [deleted] barry/remove-unneed-tao-tolerances - [deleted] barry/shell-update-vector-states - [deleted] barry/simplify-test-jobs - [deleted] barry/update-hypre - [deleted] barry/update-monitors - [deleted] barry/update-petscmemoryshowusage - [deleted] barry/update-superlu - [deleted] barry/update-superlu_dist - [deleted] barry/update-superlu_dist-again - [deleted] barry/various-fixes - [deleted] barry/xml-nested-logging - [deleted] dalcinl/ts-2nd-order-systems - [deleted] dalcinl/tsbdf - [deleted] dmay/PetscSubcommDestroy-manpage - [deleted] emil/doc-add-error-control - [deleted] emil/fix-arkimex-diverged-reason - [deleted] emil/fix-manual-typos-in-ts - [deleted] emil/fix-ts-euler-generate-error-if-non-rhsfunction - [deleted] emil/to-maint-fix-euler-interpolation - [deleted] emil/to-maint-fix-ts-reporting-nonembedded - [deleted] hongzh/add-checkpointing-support-for-adaptive-ts - [deleted] hongzh/add-ts-trajectory-statistics - [deleted] hongzh/checkpointing - [deleted] hongzh/checkpointing-update - [deleted] hongzh/fix-bug-for-cost-integral - [deleted] hongzh/update-revolve - [deleted] hongzh/update-ts-trajectory - [deleted] hzhang/dmnetwork-spJacobian - [deleted] hzhang/dmnetwork-spJacobian1 - [deleted] hzhang/dmnetwork-spJacobian2 - [deleted] hzhang/dmnetworkmonitor - [deleted] hzhang/fix-pcredundant - [deleted] hzhang/fix-ptapfill - [deleted] hzhang/fix-superlu_dist - [deleted] hzhang/inode-erroriffpe - [deleted] hzhang/matconvert-den2el - [deleted] hzhang/matgetsubmat_sbaij1 - [deleted] hzhang/matmatmult_crmax - [deleted] hzhang/matmatmult_dense - [deleted] hzhang/matpackage-erroriffpe - [deleted] hzhang/matpackage-type - [deleted] hzhang/mattransmatmult_dense - [deleted] hzhang/mumps-getseterrorflg - [deleted] hzhang/opt-ptap - [deleted] hzhang/superlu-5.1 - [deleted] hzhang/superlu_dist-4.3-ex17 - [deleted] hzhang/update-networkex - [deleted] hzhang/update-networkex-header - [deleted] jed/dmdarestoreelements-strict - [deleted] jed/fix-cuda-deps - [deleted] jed/fix-ksp-norm-none - [deleted] jed/fix-ml-visibility - [deleted] jed/mat-assembly-perf - [deleted] jed/process-options-handler - [deleted] jed/workaround-mpich-naughty-ibarrier - [deleted] jose/veccuda-complex - [deleted] karlrupp/feature-ViennaCL-1.7.x - [deleted] karlrupp/fix-matrixmarket-viewer - [deleted] karlrupp/fix-petscinitialize-cuda - [deleted] karpeev/fix-pcgasm-reuse - [deleted] karpeev/fix-snes-test-docs - [deleted] karpeev/maint-fix-gnupackage-ldflags - [deleted] knepley/dm-fix-header-docs - [deleted] knepley/doc-snes-ex1 - [deleted] knepley/feature-dmda-add-accessors - [deleted] knepley/feature-drand48-portable - [deleted] knepley/feature-ds-copy - [deleted] knepley/feature-ex5-mms - [deleted] knepley/feature-ex5-mms-params - [deleted] knepley/feature-label-empty-stratum - [deleted] knepley/feature-mpfr - [deleted] knepley/feature-patrick-control-problem - [deleted] knepley/feature-plex-add-time - [deleted] knepley/feature-plex-handle-func-failure - [deleted] knepley/feature-plex-jacp - [deleted] knepley/feature-plex-ordering-group - [deleted] knepley/feature-plex-point-location - [deleted] knepley/feature-snes-deflation - [deleted] knepley/feature-snes-setfunctionnorm - [deleted] knepley/fix-configure-HOME - [deleted] knepley/fix-configure-compiler-log - [deleted] knepley/fix-configure-dirs - [deleted] knepley/fix-configure-logging - [deleted] knepley/fix-configure-ml - [deleted] knepley/fix-configure-relative-installdir - [deleted] knepley/fix-configure-saving - [deleted] knepley/fix-dm-clone-coord-section - [deleted] knepley/fix-dm-clone-coordinates - [deleted] knepley/fix-dt-tanhsinh - [deleted] knepley/fix-error-messages - [deleted] knepley/fix-ex5-coords-empty - [deleted] knepley/fix-ex5-patchwise - [deleted] knepley/fix-examples-plex - [deleted] knepley/fix-is-fortran - [deleted] knepley/fix-msm-opt - [deleted] knepley/fix-pc-composite-dm - [deleted] knepley/fix-pc-msm - [deleted] knepley/fix-plex-blocksize - [deleted] knepley/fix-plex-c89 - [deleted] knepley/fix-plex-create-fortran - [deleted] knepley/fix-plex-distribute-label - [deleted] knepley/fix-plex-e12-3d - [deleted] knepley/fix-plex-ex1f90 - [deleted] knepley/fix-plex-examples - [deleted] knepley/fix-plex-general-interp - [deleted] knepley/fix-plex-hdf5-label - [deleted] knepley/fix-plex-l2diff - [deleted] knepley/fix-plex-natural-mem - [deleted] knepley/fix-plex-point-location - [deleted] knepley/fix-plex-pragmatic-marking - [deleted] knepley/fix-plex-regression - [deleted] knepley/fix-plex-test-partitions - [deleted] knepley/fix-quadrature-test - [deleted] knepley/fix-seterrq-doc - [deleted] knepley/fix-snes-ex5-mms - [deleted] knepley/fix-snesqn-fortran - [deleted] knepley/fix-solkx - [deleted] knepley/plex-filter - [deleted] knepley/remove-pbgl - [deleted] knepley/snes-ex5-mms - [deleted] knepley/test-asm-empty-subdomain - [deleted] mark/eigen-rand - [deleted] mark/gamg-crs - [deleted] mark/gamg-rand - [deleted] mesgarnejad/feature-plex-globaltonatural - [deleted] mlange/fix-plex-fluent-reader - [deleted] mlange/fix-plex-multi-level-overlap - [deleted] pefarrell/tao-set-riesz-map - [deleted] pr263/PierreBdR/ts-domain-error-in-stage/master - [deleted] pr330/knepley/dmshell-set-create-subdm/master - [deleted] pr332/master/Fande-Kong/mat-increaseoverlap-scalable - [deleted] pr345/anriseth/anriseth/ngmres-reset-xm-increase/master - [deleted] pr349/mapdes/extend_hypre_boomeramg_interface/master - [deleted] pr352/dmay/pctelescope/master - [deleted] pr353/dmeiser/fix-ex2_bjacobi-update/master - [deleted] pr353/dmeiser/fix-ex2_bjacobi/master - [deleted] pr358/buptphyphy/addmatcreatenormalhermitian/master - [deleted] pr361/master/Fande-Kong/pcgasm-increaseoverlap - [deleted] pr369/Fande-Kong/fixed-comment-space/master - [deleted] pr372/vijaysm/vijaysm/moab_ts_examples_fix/master - [deleted] pr380/semihozmen/semihozmen/ksp-eigen-comp-bugfix/master - [deleted] pr384/Fande-Kong/fix-pcgasm-reuse/master - [deleted] pr388/mapdes/fix-petscsf-create-section-sf/master - [deleted] pr391/zianekhodja/lilia/tsirm/master - [deleted] pr394/stevengcj/blassuffix/master - [deleted] pr395/dmeiser/fix-veccuspgetarraywrite/master - [deleted] pr401/tferma/virs-pcfieldsplit-fix/master - [deleted] pr403/pascgeopc/psanan/ksp-pipe-flex/master - [deleted] pr404/tferma/virs-divergedlinearsolve-fix-rebase/master - [deleted] pr408/psanan/psanan/pc-bddc-view/master - [deleted] pr412/psanan/psanan/ksp-cg-separate-singlereduction/master - [deleted] pr413/scools/siegfriedcools/pipecgrr/master - [deleted] pr417/adam_qc/fix-tao-ls-view-typo/master - [deleted] pr421/alex/feature-veccuda - [deleted] pr426/dmay/dmay/pctelescope-mods/master - [deleted] pr428/bug-fixes-for-viennaclseqaij - [deleted] psanan/benchmarks-cleanup - [deleted] psanan/ksp-fgmres-reduce-alloc - [deleted] sanderarens/fix-plex-neumann-bc - [deleted] sarich/check-fcflags-fflags - [deleted] sarich/feature-tao-pounders-add-correlations - [deleted] sarich/fix-tao-man-objgrad - [deleted] sarich/fix-vec-stepbound - [deleted] sarich/fix-xsdk-packages - [deleted] sarich/jenkins - [deleted] shri/add-tsevent-to-powergrid-examples - [deleted] stefano_zampini/enable-matcreatevecs-without-preallocation - [deleted] stefano_zampini/feature-fetidp-classes - [deleted] stefano_zampini/feature-pardiso-schur - [deleted] stefano_zampini/feature-ptap-seqdense - [deleted] stefano_zampini/feature-zerorowscolumns-seqdense - [deleted] stefano_zampini/fix-for-release - [deleted] stefano_zampini/fix-static-analyzer - [deleted] stefano_zampini/matis-feature-localtoglobalmap-handling - [deleted] stefano_zampini/matis-fix-create - [deleted] stefano_zampini/somefixes-matdense-lda - [deleted] tisaac/buildCheck-ignore-vc-moaning - [deleted] tisaac/buildsystem-fix-pic - [deleted] tisaac/dm-label-promote - [deleted] tisaac/dm-locate-points-sf - [deleted] tisaac/dmforest - [deleted] tisaac/dmp4est-feature-injection - [deleted] tisaac/dmplex-stable-tet-refinement - [deleted] tisaac/dt-fix-geom-punning - [deleted] tisaac/fix-static-analysis-warnings - [deleted] tisaac/plex-feature-tree-fv - [deleted] tisaac/plex-fix-ex3-const - [deleted] tisaac/plex-fix-ex3-failure-message - [deleted] tisaac/plex-fix-single-prec - [deleted] tisaac/sf-fix-multi-sf-leaves - [deleted] tomklotz/feature-tanh-sinh-quadrature
participants (1)
Satish Balay
