Re: [petsc-dev] git repo branches housekeeping
On Mon, 25 Apr 2016, Satish Balay wrote:
For more housekeeping - look at the remaining local and remote branches and figure-out what to do. [perhaps some of them are intermediate branches during rebase - or abandoned features that should be deleted]. For my branches - I would do:
For reference - current list of remote branches Satish ----------- $ git branch -r |wc -l 196 $ git branch -r origin/HEAD -> origin/master origin/PICell origin/adams/zeroDSOR origin/balay/atpesc-tutorial-2014-bgq origin/balay/atpesc-tutorial-2015-bgq origin/balay/fix-cxx-cmplx-single origin/balay/fix-uninstall origin/balay/giturl-fixes origin/balay/to-maint-switch-hdf5-build-to-cmake origin/balay/update-cmake-3.3 origin/balay/update-hdf5-netcdf origin/barry/check-no-autodetect-first origin/barry/cleanup-checkclibraries origin/barry/feature-enhanced-binary-viewers origin/barry/fix-petscviewer-attempt-1 origin/barry/fix-some-clang-warnings origin/barry/fix-threadsafety-mpi-key-value-create origin/barry/html origin/barry/more-tchem-work origin/barry/new-test-makefiles origin/barry/newhtml origin/barry/saws-profile origin/barry/superlu_mt origin/barry/utilize-hwloc origin/bueler/clean-ex9 origin/dalcinl/fix-xaij-spd origin/dalcinl/malloc-coalesced origin/dalcinl/ts-exactfinaltime origin/debo/mat-taij origin/debo/ts-fix-ex31 origin/debo/ts-irk origin/dmay/ksp-cvgtest-normtype-fix origin/emil/fix-ts-dae-rebased-v2 origin/emil/ts-glee origin/hongzh/ts-direct-sa origin/hongzh/ts-matshell-example origin/hzhang/dmnetwork-spJacobian3 origin/hzhang/fix-ptaptest origin/hzhang/ksp-fminres origin/hzhang/ksp-minresqlp origin/hzhang/superlu_dist-4.3-erroriffpe origin/irving/fe-scalars origin/irving/snes-ex12-cleanup origin/jed/assembly-perf origin/jed/cray-externc origin/jed/defined-nocpp origin/jed/elbueler-snes-ex5-fixes origin/jed/feature-dmda-section origin/jed/feature-sf-local origin/jed/fix-mat-convert-basic-bs origin/jed/fix-matnorm-log-flops origin/jed/ksp-plugin origin/jed/mat-eigenvalue-cache origin/jed/mat-taij origin/jed/mpi-2 origin/jed/next-seaice origin/jed/sr-driver origin/jed/sr-driver4 origin/jed/tao-status-string origin/jed/tap origin/jed/ts-ex11-union origin/jed/ts-heat-plex origin/jed/vecghostgetvalues origin/john-saws-webosocket-update origin/john/saws-webui-upgrade origin/jose/lapack-check origin/karlrupp/feature-optimize-opencl-petscfe origin/karlrupp/feature-pipelined-cg-viennacl origin/karlrupp/feature-viennacl-cuda origin/karlrupp/feature-viennacl-openmp origin/karlrupp/fix-viennacl-veccopy origin/karpeev/fix-pc-fieldsplit-reset origin/karpeev/mat-convert-nest-aij-test origin/karpeev/mat-reset origin/klaij/fieldsplit-simple-ex70 origin/knepley/feature-configure-kcomputer origin/knepley/feature-da-repartition origin/knepley/feature-fe-nonaffine origin/knepley/feature-optcontrol-mg origin/knepley/feature-parallel-mesh-load origin/knepley/feature-plex-example-nonconforming origin/knepley/feature-plex-nasm origin/knepley/feature-spectral-solutions origin/knepley/feature-ts-mass-matrix origin/knepley/fix-cohesive-orientation origin/knepley/fix-quadrature-order origin/knepley/pylith origin/knepley/swarm origin/madams/ex56params origin/madams/sor-residual origin/madams/sr-driver origin/madams/sr-driver2 origin/madams/sr-driver4 origin/madams/sr1 origin/maint origin/maint-3.2 origin/maint-3.3 origin/maint-3.4 origin/maint-3.5 origin/maint-3.6 origin/maint-tao-2.2 origin/mark/dmshell-ltogmap origin/mark/dmshell-test origin/mark/feature-picell origin/mark/feature-picell-iter origin/mark/gamg-coarse_ksp origin/mark/gamg-squarefix origin/mark/gamg-zerod origin/mark/ksp-zero-its origin/mark/schur-D origin/mark/tsex11 origin/master origin/master-tao origin/mlange/feature-plex-case origin/mlange/feature-plex-create-parallel origin/mlange/feature-plex-med origin/mlange/feature-plex-triangle origin/mlange/fix-adjacency-performance origin/mlange/fix-plex-cas-tests origin/mlange/fix-plex-hex-mesh origin/mlange/plex-create-parallel origin/mlange/plex-distributed-overlap origin/mlange/plex-hybrid-hdf5 origin/mlange/plex-redistribute origin/mlange/plex-sfc-reordering origin/mlange/plex-vertex-partitioning origin/mlange05/fix-gmsh-coordinates origin/next origin/next-apr-2016 origin/next-jun-2015 origin/next-oct-2014 origin/paulmullowney/aijcusp-ellpack-fix origin/peller/threadcomm origin/pr118/asmunder/DMDA-fortran-example/master origin/prbrune/matcoloring-creategraph origin/prbrune/matcoloring-minpack origin/prbrune/matcoloring-misimprovement origin/prbrune/matcoloring-zoltan origin/prbrune/pcgamg-bootstrap origin/prbrune/pcgamg-classicalbootstrap origin/prbrune/pcgamg-cr origin/prbrune/sf-examplefix origin/prbrune/snes-ex19vtkoutput origin/prbrune/snes-fasadditive origin/prbrune/zoltanupdate origin/psanan/ksp-tutorial-ex60-fixes origin/psanan/ts-bz-examples origin/psanan/ts-multiscale origin/psanan/ts-rhs-partitions origin/psanan/ts-tests origin/psanan/vec-mtdot-fix origin/sarich/configure-mira origin/sarich/feature-configure-chombo origin/sarich/feature-submatrixfree origin/sarich/feature-tao-pounders-jacobian origin/sarich/feature-tao-pounders-off-diagonal-terms origin/sarich/fix-tao-example-add-finalize origin/sarich/fix-tao-example-warning origin/sarich/mira origin/sarich/rnet-all origin/sarich/rnet-fix-rebase origin/sarich/rnet-import origin/sarich/snesvi-subvec-options origin/sarich/tao-docs-update origin/sarich/tao-lnks origin/sarich/tao-pounders-add-corr-test origin/sarich/tao-separate-state-design origin/sarich/vi/snes-aug-example origin/sarich/xsdk-add-test-arch origin/shri/FTRTDS-project origin/shri/ts-dae-semi-explicit origin/shri/ts-powergrid origin/stefano_zampini/dmplex-matis-support origin/stefano_zampini/feature-pcbddc-saddlepoint origin/stefano_zampini/fix-coherent-computation-constraints origin/stefano_zampini/hypre-ams-zerointerior-feature origin/stefano_zampini/new-elemental-interface origin/stefano_zampini/pcbddc-multilevel-extensions origin/tisaac/buildsystem-feature-parallel origin/tisaac/buildsystem-feature-subst-link-flags origin/tisaac/config-fix-petsc-py origin/tisaac/dmp4est-feature-mapped-coordinates origin/tisaac/dual-space-get-traces origin/tisaac/feature-gamg-compose-graph origin/tisaac/feature-plex-example-nonconforming origin/tisaac/feature-seqaij-get-submat-row-unordered origin/tisaac/feature-seqaij-submat-col-unsorted origin/tisaac/fix-ex3-coords origin/tisaac/fix-gamg-set-coordinates origin/tisaac/gamg-more-info origin/tisaac/knepley/feature-composable-callbacks origin/tisaac/ksp-fix-cheby-pc-handling origin/tisaac/pc-pbjacobi-vec-get-array-read origin/tisaac/petsc-next-upstream origin/tisaac/warn-next-upstream origin/vi/snes-newtonaugas
participants (1)
Satish Balay
