Re: [petsc-dev] problem with TSIRM in PETSc
On Nov 14, 2016, at 10:53 AM, Raphaël Couturier <[email protected]> wrote:
This version is the correct version https://bitbucket.org/petsc/petsc/history-node/1f2c6fc4275e/src/ksp/ksp/impl...
The petsc-3.7.4.tar.gz is different. Line 68 there is a, for example: ierr = PetscMalloc(tsirm->Iend-tsirm->Istart,&ind_row);CHKERRQ(ierr);
This is incorrect. And will result in memory corruption, the one below is correct.
In the bitbucket version Line 64 it is ierr = PetscMalloc1(tsirm->Iend-tsirm->Istart,&ind_row);CHKERRQ(ierr);
There are other differences
Likely we found these bugs and fixed them in master but not in maint. Barry
So we wonder whether it is normal or not. Thank you
Raphaël
And you an see the history of the tsirm.c file (in the master branch) on bitbucket, which might make that easier:
On Mon, Nov 14, 2016 at 5:31 PM, Matthew Knepley <[email protected]> wrote:
On Mon, Nov 14, 2016 at 2:29 AM, Raphaël Couturier
Hello all,
We have submitted a code for TSIRM a new method to solve linear systems in PETSc, approximately one year ago, and we have a question. The code is different between the petsc version in bitbucket and in the last PETSc archive. In fact everything is working fine in the petsc version but not in the petsc-3.7.4. When we submitted the first version, it seemed that everything was fine for this part of the code. What could we do? Resubmit a new version? Wait the next PETSc release?
It would really help if you could give the SHA1 for the two versions you are talking about.
Matt
Thank you in advance for your answer.
Raphaël
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Barry Smith
