Re: [petsc-dev] Strange behaviour from TSARKIMEX
On 11/14/16 1:17 PM, Stefano Zampini wrote:
I do have pasted the output for ts_monitor for the first three steps.
I meant -ts_adapt_monitor, I wanted to see what TS solvers are used: The first step is probably an Euler method, that's why you have 10 SNES solves in place of 7 for the later ones.
The entry you are referring to in Table 11 actually breaks the TS assumption that the ODE can be written F(u,udot,t) = G(u,t) (I was thinking it was a typo)
It works for certain forms as listed in the table. I'm not aware of any RK method that handles this case with G(u,t) treated explicitly.
In your case, you would either use the setup corresponding to "stiff ODE w/ mass matrix" or "nonstiff ODE w/ mass matrix�.
I�m not interested in solving this specific advection problem with arkimex. I came across this problem when writing a general interface to TS from a FEM library.
Normally, I do that by solving udot=M^-1 f(u) + M^-1 g(u)
It is difficult to create a decision tree for every way of writing the splittings. Do you find Table 11 not clear about what splitting to use? I would welcome any kind of feedback for improving it.
If the entry in Table 11 is correct, please add a comment on the manual stating that ARKIMEX does not fully support the F(u,udot,t) = G(u,t) interface.
I see how the first statement in the caption can be confusing; The last statement in the caption states: "General cases such as F(t;y;y')=G(t;y) are not amenable to IMEX Runge-Kutta, but can be solved by using fully implicit methods." A line in the table may be more clear. I'll go for that. Emil
participants (1)
Emil Constantinescu
