Re: [petsc-dev] memory leaks in BCGSL when using KSPReset()
On 12 April 2011 00:50, Satish Balay <[email protected]> wrote:
On Tue, 12 Apr 2011, Lisandro Dalcin wrote:
After adding this test in petsc4py-dev/test/test_ksp.py :
def testResetAndSolve(self): self.ksp.reset() self.testSolve() self.ksp.reset() self.testSolve() self.ksp.reset()
it seems there is some memory bleeding:
[0]Total space allocated 256 bytes [ 0]80 bytes KSPSetUp_BCGSL() line 476 in /home/devel/petsc/dev/src/ksp/ksp/impls/bcgsl/bcgsl.c [0] KSPSetUp() line 184 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c [0] KSPSolve() line 332 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c
These are workspace arrays that are re-allocated at every KSPSetup_BCGSL call.
Not sure about the proper way to fix this, but I would deallocate the arrays at KSPReset_BCGSL. Can anyone help me with this?
Never mind, I've pushed the fix I proposed above.
PS: Will we ever have petsc4py in the nightly builds? Is there something to be done from my side?
Sorry - will check on adding one..
I was not complaining. But I think petsc4py do help to catch bugs in core PETSc. BTW, take a look here: http://code.google.com/p/petsc4py/source/browse/misc/makefile.dev . Ideally, you should test many PETSC_ARCH's as possible. PS: Could you add mpiuni+single+complex to the nighties? I recently fixed an mpiuni issue for this case. -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
