Re: [petsc-dev] memory leaks in BCGSL when using KSPReset()
On 12 April 2011 10:26, Barry Smith <[email protected]> wrote:
On Apr 11, 2011, at 10:02 PM, Lisandro Dalcin wrote:
After adding this test in petsc4py-dev/test/test_ksp.py :
def testResetAndSolve(self): self.ksp.reset() self.testSolve() self.ksp.reset() self.testSolve() self.ksp.reset()
it seems there is some memory bleeding:
[0]Total space allocated 256 bytes [ 0]80 bytes KSPSetUp_BCGSL() line 476 in /home/devel/petsc/dev/src/ksp/ksp/impls/bcgsl/bcgsl.c [0] KSPSetUp() line 184 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c [0] KSPSolve() line 332 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c
These are workspace arrays that are re-allocated at every KSPSetup_BCGSL call.
Not sure about the proper way to fix this, but I would deallocate the arrays at KSPReset_BCGSL. Can anyone help me with this?
This could be a problem in many places: for example if eigenvalue computing is done with CG then I think those arrays will be reallocated.
Indeed. I'm not testing eigenvalue computing. I could try to add the options to my testsuite and see what happens.
Previously I guess KSPSetUp_XXX() never had a reason to be called more than once, with reset now it is. So that means that all arrays allocated in KSPSetUp_XXX() should be freed in KSPReset_XXX()? If this is correct then it is easily fixed by moving them from KSPDestroy_XXX().
Well, In my latest push I was lazy enough as to not remove the PetscFree() call to Reset_XXX. After all, PetscFree() nullifies the pointer, so we are safe. If you want me to fix this, let me know. PS: Barry, could you check BCGLS for a few "ksp->setupstage = KSP_SETUP_NEW;" lines? This really smells, such approach forces a full KSPSetup(), not just the subype. -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
