Re: [petsc-dev] [petsc-maint #80119] Re: make install broken on unix?
On Jul 21, 2011, at 4:39 PM, Jed Brown wrote:
On Thu, Jul 21, 2011 at 14:37, Barry Smith <[email protected]> wrote: Maybe pythonscripts?
Seems to me it should be installed like a proper python package, using a suitable setup.py. This usually puts it in $prefix/lib/python2.x/site-packages/.
I disagree with this completely. There's a tendency to think of everything python as a package -- this is NOT a package. It has no __init__.py, it has no __all__, it has no submodules, and it doesn't need any of that. It simply does a one-off task -- it's bits of code to be used in a script. Putting this sort of code in site-packages is what makes site-packages the nightmare of ignored dependencies and overlapping versions it is today. If you want to make it into a package, you're welcome to do so. With that includes registration with the cheeseshop to make sure the namespace is unique, placing the single file within a folder that includes an __init__ (and then likely just gets imported within that __init__), writing a setup.py, etc etc. It's just complete overkill. Ethan -- ------------------------------------ Ethan Coon Post-Doctoral Researcher Applied Mathematics - T-5 Los Alamos National Laboratory 505-665-8289 http://www.ldeo.columbia.edu/~ecoon/ ------------------------------------
participants (1)
Ethan Coon
