Re: [petsc-dev] [petsc-maint #80119] Re: make install broken on unix?
I disagree with this completely. There's a tendency to think of everything python as a package -- this is NOT a package. It has no __init__.py, it has no __all__, it has no submodules, and it doesn't need any of that. It simply does a one-off task -- it's bits of code to be used in a script. Putting this sort of code in site-packages is what makes site-packages the nightmare of ignored dependencies and overlapping versions it is today.
If you want to make it into a package, you're welcome to do so. With that includes registration with the cheeseshop to make sure the namespace is unique, placing the single file within a folder that includes an __init__ (and then likely just gets imported within that __init__), writing a setup.py, etc etc. It's just complete overkill.
Then why put it in bin/python at all? Just drop the .py extension and put it in bin (with a 'correct' [whatever that may be] python hashbang)? Sean
participants (1)
Sean Farley
