I configured PETSc 2.3.3-p3 on Red Hat Linux. I did not see any new makefiles generated. I came to know about this after checking the time and date of the makefiles present in the all the subfolders. Do temporary makefiles get generated? I took the log of configure script also. It is doing some testing. Can you tell me what testing is it? Waiting for your reply, Sumit We do generate makefiles, just not all of them. Automake is an unreadable, inpenetrable mess that should never be used by anyone. Thus, we don't use it. Thanks, Matt On 7/17/07, Sumit Vaidya <[email protected]> wrote:
I have downloaded the version 2.3.3-p3.
There is one file under "config" folder viz "configure.py". I am building the library on Red Hat Linux 9.
I saw some makefiles already there in the downloaded package.
Then what is the use of "configure.py" script? I have no idea about python code, But I redirected the output of configure and came to know it is testing some folders.
As per my knowledge, configure script is used to generate makefiles.
What is the use of configure script in PETSc 2.3.3-p3 version?
Sumit
DISCLAIMER ========== This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
participants (1)
Sumit Vaidya
