Re: [petsc-dev] PCApplyTranspose in BiCG
Thanks for the details, we should have identified the issue earlier. When VecDot changed from using custom code to BLAS xDOT, the conjugation definition was accidentally changed. If you pull after this patch, TFQMR will work for your problem again. http://petsc.cs.iit.edu/petsc/petsc-dev/rev/8f37c498b7b4 On Wed, Apr 11, 2012 at 00:38, Alexander Grayver <[email protected]>wrote:
** On 10.04.2012 14:19, Jed Brown wrote:
There is no space allocated at (44,44); note that counting is 0-based. This consistency check has been in PETSc for many years, so I don't know why you didn't trip it in earlier runs. Do you have some options in PETSC_OPTIONS or .petscrc?
Jed,
This is not possible:
A = PetscBinaryRead('A.dat','complex',true); find(diag(A)==0) ans = Empty matrix: 0-by-1
A(45,45) ans = (1,1) 7.999999999999997e+002 +6.316546778308559e-009i
Sorry, I forgot to mention that this is double complex matrix and vector. Have you read it as real double?
If it is of any help files are here: http://dl.dropbox.com/u/60982984/A.dat http://dl.dropbox.com/u/60982984/RHS.dat
Is this possible to look up changes in one file only?
$ hg log src/ksp/ksp/impls/tfqmr/
But the problem was clearly not in that file.
-- Regards, Alexander
participants (1)
Jed Brown
