Re: [petsc-dev] Compiling C code with C compiler
On Mon, 4 Apr 2011, Lisandro Dalcin wrote:
On 4 April 2011 22:48, Satish Balay <[email protected]> wrote:
There is clang and clang++ - but still they insist on throwing this warning.
When I invoke clang++ - I want c++. So I'm not sure whats so ambiguous that they should throw this warning.
And what does this depricate mean? That ᅵ'clang++ foo.c' will create C code?
Then why have both clang and clang++?
$ file /usr/bin/clang++ /usr/bin/clang++: symbolic link to `clang'
They should use argv[0] to dispatch C/C++, but it seems this is not the case.
They do that - but use it to print the warning. [and goes ahead and generates c++ code]
asterix:/home/balay/junk>clang sizeof.c asterix:/home/balay/junk>clang++ sizeof.c clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated asterix:/home/balay/junk> <<<<<<
participants (1)
Satish Balay
