Re: [petsc-dev] MatCreateVecs from Fortran problem
On Tue, Mar 17, 2020 at 1:34 PM Mark Adams <[email protected]> wrote:
Our code broke in moving from v3.7 to current. The problem seems to be in MatCreateVecs
Our code has:
Vec::XVec Vec::BVec
this%xVec2 = PETSC_NULL_VEC this%bVec2 = PETSC_NULL_VEC
Passing NULL to MatCreateVecs() means that you do not want a vector out: https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateVe... I am guessing that this was broken in 3.7 so that it ignored NULL input, but we fixed that. Thanks, Matt
call MatCreateVecs(solver%KKTmat,solver%xVec2,solver%bVec2,ierr)
Petsc code: PETSC_EXTERN void PETSC_STDCALL matcreatevecs_(Mat *mat,Vec *right,Vec *left, int *ierr) { PetscPrintf(PETSC_COMM_SELF,"ZZZ 1) matcreatevecs_ start right=%p left=%p\n",right,left); CHKFORTRANNULLOBJECT(right); CHKFORTRANNULLOBJECT(left); PetscPrintf(PETSC_COMM_SELF,"ZZZ 2) matcreatevecs_ start right=%p left=%p\n",right,left); *ierr = MatCreateVecs(*mat,right,left); }
produces this:
ZZZ 1) matcreatevecs_ start right=0x7fffffff3758 left=0x7fffffff3760 ZZZ 2) matcreatevecs_ start right=(nil) left=(nil)
Shouldn't this be?
PETSC_EXTERN void PETSC_STDCALL matcreatevecs_(Mat *mat,Vec *right,Vec *left, int *ierr) { *ierr = MatCreateVecs(*mat,right,left); }
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
