Re: [petsc-dev] MatCreateVecs from Fortran problem
Passing NULL to MatCreateVecs() means that you do not want a vector out:
Yes, I want both vectors out and we pass it Vec that have been initialized with PETSC_NULL_VEC
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateVe...
I am guessing that this was broken in 3.7 so that it ignored NULL input, but we fixed that.
v3.7 has these CHKFORTRANNULLOBJECT. Well the "fix" broke working code ex73f90t does not initialize the "x" vector that it gives to matcreatevecs_. Should we just remove initialization of our vectors to PETSC_NUILL_VEC? Is the PETSc model that you don't inialized PETSc object to NULL because you check that pointers are valid PETSc pointers instead of testing on NULL? So maybe we should remove all these initializations. Thanks, Mark
Matt
call MatCreateVecs(solver%KKTmat,solver%xVec2,solver%bVec2,ierr)
Petsc code: PETSC_EXTERN void PETSC_STDCALL matcreatevecs_(Mat *mat,Vec *right,Vec *left, int *ierr) { PetscPrintf(PETSC_COMM_SELF,"ZZZ 1) matcreatevecs_ start right=%p left=%p\n",right,left); CHKFORTRANNULLOBJECT(right); CHKFORTRANNULLOBJECT(left); PetscPrintf(PETSC_COMM_SELF,"ZZZ 2) matcreatevecs_ start right=%p left=%p\n",right,left); *ierr = MatCreateVecs(*mat,right,left); }
produces this:
ZZZ 1) matcreatevecs_ start right=0x7fffffff3758 left=0x7fffffff3760 ZZZ 2) matcreatevecs_ start right=(nil) left=(nil)
Shouldn't this be?
PETSC_EXTERN void PETSC_STDCALL matcreatevecs_(Mat *mat,Vec *right,Vec *left, int *ierr) { *ierr = MatCreateVecs(*mat,right,left); }
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Mark Adams
