Re: [petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
On 10 March 2011 21:45, Barry Smith <[email protected]> wrote:
On Mar 10, 2011, at 6:22 PM, Lisandro Dalcin wrote:
On 10 March 2011 20:57, Ethan Coon <[email protected]> wrote:
Attached patch makes this change, and updates the website with the API change.
Also it fixes a few stray 'DAPeriodicType's in conf/adic*.init, which I'm guessing was just missed in the previous change to DMDAPeriodicType?
Do we really need backward compatibility DMDA_XYZPERIODIC and friends?
Is the | business all fine and dandy for Fortran? If so then I agree we should remove the "noise".
Well, you can use '+' (with a bit care) in any Fortran, right?. This is the way the MPI standard does things for some enumerations (file modes, RMA assertions). However, if DMDA_XYZPERIODIC and friends do no go away because of Fortran issues, then we should definitely define DMDA_{XY|XZ|YZ}GHOSTED. -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
