Re: [petsc-maint #37691] problem with petsc4py
On Mon, Nov 16, 2009 at 4:16 PM, Barry Smith <[email protected]> wrote:
On Nov 16, 2009, at 9:37 AM, Lisandro Dalcin wrote:
On Sat, Nov 14, 2009 at 12:36 AM, Barry Smith <[email protected]> wrote:
petsc-dev should be setup to always use the appropriate petsc4py so this shit works automatically.
However, please note that I cannot guarantee that petsc4py-dev will be in sync with latest changes in petsc-dev. Sometimes, a delay of a week or so should be expected.
This we understand.
So the only thing holding us up is having Matt add support for using hg to download in BuildSystem. There was support for bk but hg was never added.
Matt, can you add this?
IIRC, there were issues about that a URL like "http://petsc.cs.iit.edu/petsc4py/petsc4py-dev" provides no clue about the repo being a Mercurial one. However, I want to mention a "convention" it is being used elsewere (see for example: http://pip.openplans.org/#requirements-files)... Basically, you have to prefix the URL like this: "hg+http://petsc.cs.iit.edu/petsc4py/petsc4py-dev".. then the hg+ svn+ git+ bzr+ prefix provides the required clue. -- Lisandro Dalcín --------------- Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC) Instituto de Desarrollo Tecnológico para la Industria Química (INTEC) Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET) PTLC - Güemes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Lisandro Dalcin
