Getting nodal coordinates from a FEM computation
Hello, Good Morning. My name is Abisheik Panneerselvam and I am presently working in Max-Planck Düsseldorf. I am working on a FE software development project. The FE computation code is already written in Fortran (using Petsc for solving) few years ago. I am currently working on post-processing the results of the computation (nodal displacements, integration point displacements etc.). I am facing problems in getting the coordinates of vertices. I tried the following call SNESGetDM(mechanical_snes,dm_local,ierr); CHKERRQ(ierr) !Gets the local DM from the SNES solve call DMGetLocalVector(dm_local,x_local,ierr); CHKERRQ(ierr) !Gets the local vector from the DM This functions successfully gets the coordinates of all the nodes. This works fine for linear elements as there are only nodes on cell vertices. But for higher order elements, the local vector (x_local) contains additional nodal points (I think its called ghost points in Petsc) on the edges. In this case how do I get the coordinates of only the cell vertices? I tried the below code for getting the vertex coordinates but its giving random values. call DMPlexGetDepthStratum(dm_local, 0, vStart, vEnd,ierr); CHKERRQ(ierr) !Get the vertices call VecGetArrayF90(x_local, node_coords_local,ierr) v_count=1 do v=vStart, vEnd-1 call DMPlexGetPointLocal(dm_local, v, x, y, ierr); CHKERRQ(ierr) !Get the position of the vertice in the local DM d_count=1 do d=x,y-1 node_coords(d_count,v_count)=node_coords_local(d) d_count=d_count+1 end do v_count = v_count+1 end do It will be really helpful if you could advise me on this. Best regards Abisheik ------------------------------------------------- Max-Planck-Institut für Eisenforschung GmbH Max-Planck-Straße 1 D-40237 Düsseldorf Handelsregister B 2533 Amtsgericht Düsseldorf Geschäftsführung Prof. Dr. Gerhard Dehm Prof. Dr. Jörg Neugebauer Prof. Dr. Dierk Raabe Dr. Kai de Weldige Ust.-Id.-Nr.: DE 11 93 58 514 Steuernummer: 105 5891 1000 Please consider that invitations and e-mails of our institute are only valid if they end with …@mpie.de. If you are not sure of the validity please contact [email protected] Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails aus unserem Haus nur mit der Endung …@mpie.de gültig sind. In Zweifelsfällen wenden Sie sich bitte an [email protected] -------------------------------------------------
On Thu, Jun 24, 2021 at 10:34 AM Abisheik Panneerselvam < [email protected]> wrote:
Hello,
v_count=1
do v=vStart, vEnd-1
d_count=1
do d=x,y-1
d_count=d_count+1
end do
v_count = v_count+1
end do
Hi Abisheik, One question to start off. Are you using DMPlex to describe the grid? It sounded like your FEM code was in Fortran. If you are only using PETSc for solving the equations, it will not know the difference between unknowns on vertices and edges. Thanks, Matt
Best regards
Abisheik
------------------------------ ------------------------------------------------- Max-Planck-Institut für Eisenforschung GmbH Max-Planck-Straße 1 D-40237 Düsseldorf
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (2)
Abisheik Panneerselvam -
Matthew Knepley
