Tracking a NaN in FVM gradient computation
Hi there PETSc, I am working my way through ex11.c and have encountered a problem. On the first pass through mesh adaption, the gradient computation in PETSc triggers a NaN, even though none of the input data are NaN. To reproduce: PETSc v3.15 with latest MPICH, no external libraries, debugging on Compile ex11.c using GCC 9.3 on Ubuntu 20.04 Run as: ./ex11 -ufv_use_amr -fp_trap Running under GDB shows that the offending line is: src/dm/impls/plex/plexfvm.c:111 This originates from the call to DMPlexReconstructGradientsFVM. I only noticed this because I was trying to resolve a discontinuity in my own initial condition for a Sod shock tube problem, but then I found that it occurs in the example without any modification, too. Is this somehow intended? If not, what steps can one take to make sure the gradients are actual numeric values? It doesn't make sense to me that they would be undefined on the first step when nothing else is NaN. Or is it that AMR in ex11 doesn't quite work yet? Thanks, Ellen Price
Looks like this is the relevant code. for (d = 0; d < dim; ++d) { if (cgrad[0]) cgrad[0][pd*dim+d] += fg->grad[0][d] * delta; if (cgrad[1]) cgrad[1][pd*dim+d] -= fg->grad[1][d] * delta; } I ran in a debugger and found there was already nan here: Thread 1 "ex11" received signal SIGFPE, Arithmetic exception. 0x00007ffff6c88e31 in DMPlexReconstructGradients_Internal (dm=0x555555b21230, fvm=0x5555558cc4b0, fStart=25, fEnd=41, faceGeometry=0x555555e3b3a0, cellGeometry=0x555555e54560, locX=0x555555edb7f0, grad =0x555555ee6ce0) at src/dm/impls/plex/plexfvm.c:111 111 if (cgrad[0]) cgrad[0][pd*dim+d] += fg->grad[0][d] * delta; (gdb) p fg->grad[0][d] $1 = nan(0x000000002) (gdb) p d $2 = 0 That indicates memory corruption because if the nan had been computed in an earlier step, we would have trapped there. Indeed, I see Valgrind errors. I'm adding Toby, who developed much of this and might be able to debug more efficiently. It would be useful to file an issue on GitLab. $ valgrind mpich-clang/tests/ts/tutorials/ex11 -ufv_use_amr -fp_trap ==599057== Memcheck, a memory error detector ==599057== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al. ==599057== Using Valgrind-3.17.0 and LibVEX; rerun with -h for copyright info ==599057== Command: mpich-clang/tests/ts/tutorials/ex11 -ufv_use_amr -fp_trap ==599057== ==599057== Conditional jump or move depends on uninitialised value(s) ==599057== at 0x122A31: adaptToleranceFVM (ex11.c:1608) ==599057== by 0x11A89B: main (ex11.c:1927) ==599057== ==599057== Conditional jump or move depends on uninitialised value(s) ==599057== at 0x122A77: adaptToleranceFVM (ex11.c:1609) ==599057== by 0x11A89B: main (ex11.c:1927) ==599057== ==599057== Conditional jump or move depends on uninitialised value(s) ==599057== at 0x4F3B293: VecTaggerComputeIS_FromBoxes (tagger.c:465) ==599057== by 0x4F3AB34: VecTaggerComputeIS (tagger.c:422) ==599057== by 0x122E91: adaptToleranceFVM (ex11.c:1619) ==599057== by 0x11A89B: main (ex11.c:1927) ==599057== ==599057== Conditional jump or move depends on uninitialised value(s) ==599057== at 0x4F3B293: VecTaggerComputeIS_FromBoxes (tagger.c:465) ==599057== by 0x4F3AB34: VecTaggerComputeIS (tagger.c:422) ==599057== by 0x122F23: adaptToleranceFVM (ex11.c:1620) ==599057== by 0x11A89B: main (ex11.c:1927) ==599057== ==599057== Conditional jump or move depends on uninitialised value(s) ==599057== at 0x4F3B2CB: VecTaggerComputeIS_FromBoxes (tagger.c:472) ==599057== by 0x4F3AB34: VecTaggerComputeIS (tagger.c:422) ==599057== by 0x122F23: adaptToleranceFVM (ex11.c:1620) ==599057== by 0x11A89B: main (ex11.c:1927) "Ellen M. Price" <[email protected]> writes:
Hi there PETSc,
To reproduce:
Thanks, Ellen Price
participants (2)
Ellen M. Price -
Jed Brown
