Compiling PETSC with Intel OneAPI compilers and OpenMPI
Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos
On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users < [email protected]> wrote:
I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt
CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 *# Error code: 139* *# [excess:98681] *** Process received signal **** *# [excess:98681] Signal: Segmentation fault: 11 (11)* *# [excess:98681] Signal code: Address not mapped (1)* *# [excess:98681] Failing at address: 0x7f* *# [excess:98681] *** End of error message **** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff
Marcos
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) < [email protected]> wrote:
------------------------------ *From:* Vanella, Marcos (Fed) <[email protected]> *Sent:* Monday, May 15, 2023 12:20 PM *To:* Matthew Knepley <[email protected]> *Cc:* [email protected] <[email protected]> *Subject:* Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI
Thank you Matt I'll try this and let you know. Marcos ------------------------------ *From:* Matthew Knepley <[email protected]> *Sent:* Monday, May 15, 2023 12:08 PM *To:* Vanella, Marcos (Fed) <[email protected]> *Cc:* [email protected] <[email protected]> *Subject:* Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI
--with-debugging=0
Matt
Marcos
Hi Matt, attached is the file. Thanks! Marcos ________________________________ From: Matthew Knepley <[email protected]> Sent: Monday, May 15, 2023 12:53 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> wrote: Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
On Mon, May 15, 2023 at 1:04 PM Vanella, Marcos (Fed) < [email protected]> wrote:
Okay, you are failing in this function PetscErrorCode PetscGetArchType(char str[], size_t slen) { PetscFunctionBegin; #if defined(PETSC_ARCH) PetscCall(PetscStrncpy(str, PETSC_ARCH, slen - 1)); #else #error "$PETSC_ARCH/include/petscconf.h is missing PETSC_ARCH" #endif PetscFunctionReturn(PETSC_SUCCESS); } How PETSC_ARCH is defined in the header you sent, so it is likely that some other header is being picked up by mistake from some other, broken build. I would completely clean out your PETSc installation and start from scratch. Thanks, Matt
Thanks! Marcos ------------------------------ *From:* Matthew Knepley <[email protected]> *Sent:* Monday, May 15, 2023 12:53 PM *To:* Vanella, Marcos (Fed) <[email protected]> *Cc:* [email protected] <[email protected]> *Subject:* Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI
Send us
Matt
--with-debugging=0
Matt
Marcos
Hi, for what it’s worth, clang + ifort from OneAPI 2023 update 1 works fine for me on both Intel and M2 Macs. So it might just be a matter of upgrading. Samar On May 15, 2023, at 5:53 PM, Matthew Knepley <[email protected]> wrote: Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> wrote: Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Hi Samar, what MPI library do you use? Did you compile it with clang instead of icc? Thanks, Marcos ________________________________ From: Samar Khatiwala <[email protected]> Sent: Monday, May 15, 2023 1:05 PM To: Matthew Knepley <[email protected]> Cc: Vanella, Marcos (Fed) <[email protected]>; [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Hi, for what it’s worth, clang + ifort from OneAPI 2023 update 1 works fine for me on both Intel and M2 Macs. So it might just be a matter of upgrading. Samar On May 15, 2023, at 5:53 PM, Matthew Knepley <[email protected]> wrote: Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> wrote: Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Hi Marcos, Yes, I compiled with clang instead of icc (no particular reason for this; I tend to use gcc/clang). I use mpich4.1.1, which I first built with clang and ifort: FC=ifort ./configure --prefix=/usr/local/mpich4 --enable-two-level-namespace Samar On May 15, 2023, at 6:07 PM, Vanella, Marcos (Fed) <[email protected]> wrote: Hi Samar, what MPI library do you use? Did you compile it with clang instead of icc? Thanks, Marcos ________________________________ From: Samar Khatiwala <[email protected]> Sent: Monday, May 15, 2023 1:05 PM To: Matthew Knepley <[email protected]> Cc: Vanella, Marcos (Fed) <[email protected]>; [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Hi, for what it’s worth, clang + ifort from OneAPI 2023 update 1 works fine for me on both Intel and M2 Macs. So it might just be a matter of upgrading. Samar On May 15, 2023, at 5:53 PM, Matthew Knepley <[email protected]> wrote: Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> wrote: Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Thank you Matt and Samar, Seems the segfaults I see are related to icc, which is not being updated anymore. The recommended intel C compiler is icx which is not released for Macs. I compiled the lib with gcc 13 + openmpi from homebrew and the tests are passing just fine in optimized mode. I will follow Samars comment and build openmpi with clang + ifort and check PETSc works fine with it. Might be time to get rid of icc in our bundle building process for Macs, I keep getting this warning: icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Thanks for the help! Marcos ________________________________ From: Samar Khatiwala <[email protected]> Sent: Monday, May 15, 2023 1:22 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: Matthew Knepley <[email protected]>; [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Hi Marcos, Yes, I compiled with clang instead of icc (no particular reason for this; I tend to use gcc/clang). I use mpich4.1.1, which I first built with clang and ifort: FC=ifort ./configure --prefix=/usr/local/mpich4 --enable-two-level-namespace Samar On May 15, 2023, at 6:07 PM, Vanella, Marcos (Fed) <[email protected]> wrote: Hi Samar, what MPI library do you use? Did you compile it with clang instead of icc? Thanks, Marcos ________________________________ From: Samar Khatiwala <[email protected]> Sent: Monday, May 15, 2023 1:05 PM To: Matthew Knepley <[email protected]> Cc: Vanella, Marcos (Fed) <[email protected]>; [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Hi, for what it’s worth, clang + ifort from OneAPI 2023 update 1 works fine for me on both Intel and M2 Macs. So it might just be a matter of upgrading. Samar On May 15, 2023, at 5:53 PM, Matthew Knepley <[email protected]> wrote: Send us $PETSC_ARCH/include/petscconf.h Thanks, Matt On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> wrote: Hi Matt, I configured the lib like this: $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 --with-debugging=0 --with-shared-libraries=0 --download-make and compiled. I still get some check segfault error. See below: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt check Running check examples to verify correct installation Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and PETSC_ARCH=arch-darwin-c-opt *******************Error detected during compile or link!******************* See https://petsc.org/release/faq/ /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19 ********************************************************************************* mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -wd1572 -Wno-unknown-pragmas -g -O3 -I/Users/mnv/Documents/Software/petsc-3.19.1/include -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include -I/opt/X11/include -std=c99 ex19.c -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -L/opt/openmpi414_oneapi22u3/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib -L/opt/intel/oneapi/ipp/2021.6.2/lib -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib -L/opt/intel/oneapi/dal/2021.7.1/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11 -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o ex19 icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated and will be removed from product release in the second half of 2023. The Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving forward. Please transition to use this compiler. Use '-diag-disable=10441' to disable this message. In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7), from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7), from ex19.c(68): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process See https://petsc.org/release/faq/ [excess:37807] *** Process received signal *** [excess:37807] Signal: Segmentation fault: 11 (11) [excess:37807] Signal code: Address not mapped (1) [excess:37807] Failing at address: 0x7f [excess:37807] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes See https://petsc.org/release/faq/ [excess:37831] *** Process received signal *** [excess:37831] Signal: Segmentation fault: 11 (11) [excess:37831] Signal code: Address not mapped (1) [excess:37831] Failing at address: 0x7f [excess:37831] *** End of error message *** [excess:37832] *** Process received signal *** [excess:37832] Signal: Segmentation fault: 11 (11) [excess:37832] Signal code: Address not mapped (1) [excess:37832] Failing at address: 0x7f [excess:37832] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). -------------------------------------------------------------------------- Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process See https://petsc.org/release/faq/ forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source libifcoremt.dylib 000000010B7F7FE4 for__signal_handl Unknown Unknown libsystem_platfor 00007FF8024C25ED _sigtramp Unknown Unknown ex5f 00000001087AFA38 PetscGetArchType Unknown Unknown ex5f 000000010887913B PetscErrorPrintfI Unknown Unknown ex5f 000000010878D227 PetscInitialize_C Unknown Unknown ex5f 000000010879D289 petscinitializef_ Unknown Unknown ex5f 0000000108713C09 petscsys_mp_petsc Unknown Unknown ex5f 0000000108710B5D MAIN__ Unknown Unknown ex5f 0000000108710AEE main Unknown Unknown dyld 00007FF80213B41F start Unknown Unknown -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[48108,1],0] Exit code: 174 -------------------------------------------------------------------------- Completed test examples Error while running make check make[1]: *** [check] Error 1 make: *** [check] Error 2 ________________________________ From: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:20 PM To: Matthew Knepley <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Thank you Matt I'll try this and let you know. Marcos ________________________________ From: Matthew Knepley <[email protected]<mailto:[email protected]>> Sent: Monday, May 15, 2023 12:08 PM To: Vanella, Marcos (Fed) <[email protected]<mailto:[email protected]>> Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <[email protected]<mailto:[email protected]>> wrote: Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX Ventura 13.3.1. I can compile PETSc in debug mode with this configure and make lines. I can run the PETSC tests, which seem fine. When I compile the library in optimized mode, either using -O3 or O1, for example configuring with: I hate to yell "compiler bug" when this happens, but it sure seems like one. Can you just use --with-debugging=0 without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is almost certainly a compiler bug. If not, then we can go in the debugger and see what is failing. Thanks, Matt $ ./configure --prefix=/opt/petsc-oneapi22u3 --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441' FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0 --with-shared-libraries=0 --download-make and using mpicc (icc), mpif90 (ifort) from Open MPI, the static lib compiles. Yet, I see right off the bat this segfault error in the first PETSc example: $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 PETSC_ARCH=arch-darwin-c-opt test /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make --no-print-directory -f /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test /opt/intel/oneapi/intelpython/latest/bin/python3 /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1 --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o In file included from /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44), from /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4): /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68): warning #2621: attribute "warn_unused_result" does not apply here PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD { ^ CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1 TEST arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts not ok sys_classes_draw_tests-ex1_1 # Error code: 139 # [excess:98681] *** Process received signal *** # [excess:98681] Signal: Segmentation fault: 11 (11) # [excess:98681] Signal code: Address not mapped (1) # [excess:98681] Failing at address: 0x7f # [excess:98681] *** End of error message *** # -------------------------------------------------------------------------- # Primary job terminated normally, but 1 process returned # a non-zero exit code. Per user-direction, the job has been aborted. # -------------------------------------------------------------------------- # -------------------------------------------------------------------------- # mpiexec noticed that process rank 0 with PID 0 on node excess exited on signal 11 (Segmentation fault: 11). # -------------------------------------------------------------------------- ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff I see the same segfault error in all PETSc examples. Any help is mostly appreciated, I'm starting to work with PETSc. Our plan is to use the linear solver from PETSc for the Poisson equation on our numerical scheme and test this on a GPU cluster. So also, any guideline on how to interface PETSc with a fortran code and personal experience is also most appreciated! Marcos -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
I see Intel compilers here are building x86_64 binaries - that get run on the Arm M1 CPU - perhaps there are issues here with this mode of usage..
What does intel compilers provide you for this use case? Why not use xcode/clang with gfortran here - i.e native ARM binaries? Satish On Mon, 15 May 2023, Vanella, Marcos (Fed) via petsc-users wrote:
Marcos
Hi Satish, well turns out this is not an M1 Mac, it is an older Intel Mac (2019). I'm trying to get a local computer to do development and tests, but I also have access to linux clusters with GPU which we plan to go to next. Thanks for the suggestion, I might also try compiling a gcc/gfortran version of the lib on this computer. Marcos ________________________________ From: Satish Balay <[email protected]> Sent: Monday, May 15, 2023 12:10 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI I see Intel compilers here are building x86_64 binaries - that get run on the Arm M1 CPU - perhaps there are issues here with this mode of usage..
Marcos
Ops - for some reason I assumed this build is on Mac M1. [likely due to the usage of '-m64' - that was strange].. But yeah - our general usage on Mac is with xcode/clang and brew gfortran (on both Intel and ARM CPUs) - and unless you need Intel compilers for specific needs - clang/gfortran should work better for this development work. Satish On Mon, 15 May 2023, Vanella, Marcos (Fed) via petsc-users wrote:
Satish
Marcos
Hi Satish, yes the -m64 flag tells the compilers the target cpu is intel 64. The only reason I'm trying to get PETSc working with intel is that the bundles for the software we release use Intel compilers for Linux, Mac and Windows (OneAPI intelMPI for linux and Windows, OpenMPI compiled with intel for MacOS). I'm just trying to get PETSc compiled with intel to maintain the scheme we have and keep these compilers, which would be handy if we are to release an alternative Poisson solver using PETSc in the future. For our research projects I'm thinking we'll use gcc/openmpi in linux clusters. Marcos ________________________________ From: Satish Balay <[email protected]> Sent: Monday, May 15, 2023 12:48 PM To: Vanella, Marcos (Fed) <[email protected]> Cc: petsc-users <[email protected]> Subject: Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI Ops - for some reason I assumed this build is on Mac M1. [likely due to the usage of '-m64' - that was strange].. But yeah - our general usage on Mac is with xcode/clang and brew gfortran (on both Intel and ARM CPUs) - and unless you need Intel compilers for specific needs - clang/gfortran should work better for this development work. Satish On Mon, 15 May 2023, Vanella, Marcos (Fed) via petsc-users wrote:
Satish
Marcos
participants (4)
Matthew Knepley -
Samar Khatiwala -
Satish Balay -
