How to find the map between the high order coordinates of DMPlex and vertex numbering?
Hi, if I load a `gmsh` file with second-order elements, the coordinates will be stored in a DG-P2 space. After obtaining the coordinates of a cell, how can I map the coordinates to vertex and edge? Below is some code load the gmsh file, I want to know the relation between `cl` and `cell_coords`. ``` import firedrake as fd import numpy as np # Load gmsh file (2rd) plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh') cs, ce = plex.getHeightStratum(0) cdm = plex.getCoordinateDM() csec = dm.getCoordinateSection() coords_gvec = dm.getCoordinates() for i in range(cs, ce): cell_coords = cdm.getVecClosure(csec, coords_gvec, i) print(f'coordinates for cell {i} :\n{cell_coords.reshape([-1, 3])}') cl = dm.getTransitiveClosure(i) print('closure:', cl) break ``` Best wishes, Zongze
By default, they are stored as P2, not DG. You can ask for the coordinates of a vertex or an edge directly using https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/ by giving the vertex or edge point. You can get all the coordinates on a cell, in the closure order, using https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/ Thanks, Matt
Best wishes, Zongze
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
在 2022年6月16日,23:22,Matthew Knepley <[email protected]> 写道:
I checked the coordinates vector, and found the dogs only defined on cell other than vertex and edge, so I said they are stored as DG. Then the function DMPlexVecGetClosure seems return the coordinates in lex order. Some code in reading gmsh file reads that 1756: if (isSimplex) continuity = PETSC_FALSE; /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */ 1758: GmshCreateFE(comm, NULL, isSimplex, continuity, nodeType, dim, coordDim, order, &fe) The continuity is set to false for simplex. Thanks, Zongze
Matt
Best wishes, Zongze
I checked the coordinates vector, and found the dogs only defined on cell other than vertex and edge, so I said they are stored as DG. Then the function DMPlexVecGetClosure <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return the coordinates in lex order.
1756: if (isSimplex) continuity = PETSC_FALSE <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>; /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
Oh, yes. That needs to be fixed. For now, you can just project it to P2 if you want using https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/ Thanks, Matt
Thanks, Zongze
Matt
Best wishes, Zongze
I tried the projection operation. However, it seems that the projection gives the wrong solution. After projection, the bounding box is changed! See logs below. First, I patch the petsc4py by adding `DMProjectCoordinates`: ``` diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx b/src/binding/petsc4py/src/PETSc/DM.pyx index d8a58d183a..dbcdb280f1 100644 --- a/src/binding/petsc4py/src/PETSc/DM.pyx +++ b/src/binding/petsc4py/src/PETSc/DM.pyx @@ -307,6 +307,12 @@ cdef class DM(Object): PetscINCREF(c.obj) return c + def projectCoordinates(self, FE fe=None): + if fe is None: + CHKERR( DMProjectCoordinates(self.dm, NULL) ) + else: + CHKERR( DMProjectCoordinates(self.dm, fe.fe) ) + def getBoundingBox(self): cdef PetscInt i,dim=0 CHKERR( DMGetCoordinateDim(self.dm, &dim) ) diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi b/src/binding/petsc4py/src/PETSc/petscdm.pxi index 514b6fa472..c778e39884 100644 --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi @@ -90,6 +90,7 @@ cdef extern from * nogil: int DMGetCoordinateDim(PetscDM,PetscInt*) int DMSetCoordinateDim(PetscDM,PetscInt) int DMLocalizeCoordinates(PetscDM) + int DMProjectCoordinates(PetscDM, PetscFE) int DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*) int DMCreateInjection(PetscDM,PetscDM,PetscMat*) ``` Then in python, I load a mesh and project the coordinates to P2: ``` import firedrake as fd from firedrake.petsc import PETSc # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh') plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh') print('old bbox:', plex.getBoundingBox()) dim = plex.getDimension() # (dim, nc, isSimplex, k, qorder, comm=None) fe_new = PETSc.FE().createLagrange(dim, dim, True, 2, PETSc.DETERMINE) plex.projectCoordinates(fe_new) fe_new.view() print('new bbox:', plex.getBoundingBox()) ``` The output is (The bounding box is changed!) ``` old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0)) PetscFE Object: P2 1 MPI processes type: basic Basic Finite Element in 3 dimensions with 3 components PetscSpace Object: P2 1 MPI processes type: sum Space in 3 variables with 3 components, size 30 Sum space of 3 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 1 MPI processes type: poly Space in 3 variables with 1 components, size 10 Polynomial space of degree 2 PetscDualSpace Object: P2 1 MPI processes type: lagrange Dual space with 3 components, size 30 Continuous Lagrange dual space Quadrature of order 5 on 27 points (dim 3) new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224)) ``` By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell? Thanks! Zongze Matthew Knepley <[email protected]> 于2022年6月17日周五 01:11写道:
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
In order to check if I made mistakes in the python code, I try to use c code to show the issue on DMProjectCoordinates. The code and mesh file is attached. If the code is correct, there must be something wrong with `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh. The command and the output are listed below: (Obviously the bounding box is changed.) ``` $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view -new_fe_view Old Bounding Box: 0: lo = 0. hi = 1. 1: lo = 0. hi = 1. 2: lo = 0. hi = 1. PetscFE Object: OldCoordinatesFE 1 MPI processes type: basic Basic Finite Element in 3 dimensions with 3 components PetscSpace Object: P2 1 MPI processes type: sum Space in 3 variables with 3 components, size 30 Sum space of 3 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 1 MPI processes type: poly Space in 3 variables with 1 components, size 10 Polynomial space of degree 2 PetscDualSpace Object: P2 1 MPI processes type: lagrange Dual space with 3 components, size 30 Discontinuous Lagrange dual space Quadrature of order 5 on 27 points (dim 3) PetscFE Object: NewCoordinatesFE 1 MPI processes type: basic Basic Finite Element in 3 dimensions with 3 components PetscSpace Object: P2 1 MPI processes type: sum Space in 3 variables with 3 components, size 30 Sum space of 3 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 1 MPI processes type: poly Space in 3 variables with 1 components, size 10 Polynomial space of degree 2 PetscDualSpace Object: P2 1 MPI processes type: lagrange Dual space with 3 components, size 30 Continuous Lagrange dual space Quadrature of order 5 on 27 points (dim 3) New Bounding Box: 0: lo = 2.5624e-17 hi = 8. 1: lo = -9.23372e-17 hi = 7. 2: lo = 2.72091e-17 hi = 8.5 ``` Thanks, Zongze Zongze Yang <[email protected]> 于2022年6月17日周五 14:54写道:
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Something is definitely wrong with high order, periodic simplices from Gmsh. We had not tested that case. I am at a conference and cannot look at it for a week. My suspicion is that the space we make when reading in the Gmsh coordinates does not match the values (wrong order). Thanks, Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Thank you for your reply. May I ask for some references on the order of the dofs on PETSc's FE Space (especially high order elements)? Thanks, Zongze Matthew Knepley <[email protected]> 于2022年6月18日周六 20:02写道:
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Hi, Matt, There seem to be ongoing issues with projecting high-order coordinates from a gmsh file to other spaces. I would like to inquire whether there are any plans to resolve this problem. Thank you for your attention to this matter. Best wishes, Zongze On Sat, 18 Jun 2022 at 20:31, Zongze Yang <[email protected]> wrote:
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
On Sat, May 13, 2023 at 6:08 AM Zongze Yang <[email protected]> wrote:
Hi, Matt,
Yes, I will look at it. The important thing is to have a good test. Here are the higher order geometry tests https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c I take shapes with known volume, mesh them with higher order geometry, and look at the convergence to the true volume. Could you add a GMsh test, meaning the .msh file and known volume, and I will fix it? Thanks, Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Hi, Matt, The issue has been resolved while testing on the latest version of PETSc. It seems that the problem has been fixed in the following merge request: https://gitlab.com/petsc/petsc/-/merge_requests/5970 I sincerely apologize for any inconvenience caused by my previous message. However, I would like to provide you with additional information regarding the test files. Attached to this email, you will find two Gmsh files: "square_2rd.msh" and "square_3rd.msh." These files contain high-order triangulated mesh data for the unit square. ``` $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh -dm_plex_gmsh_project -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true -dm_plex_gmsh_project_fe_view -volume 1 PetscFE Object: P2 1 MPI process type: basic Basic Finite Element in 2 dimensions with 2 components PetscSpace Object: P2 1 MPI process type: sum Space in 2 variables with 2 components, size 12 Sum space of 2 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 1 MPI process type: poly Space in 2 variables with 1 components, size 6 Polynomial space of degree 2 PetscDualSpace Object: P2 1 MPI process type: lagrange Dual space with 2 components, size 12 Continuous Lagrange dual space Quadrature on a triangle of order 5 on 9 points (dim 2) Volume: 1. $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh -dm_plex_gmsh_project -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true -dm_plex_gmsh_project_fe_view -volume 1 PetscFE Object: P3 1 MPI process type: basic Basic Finite Element in 2 dimensions with 2 components PetscSpace Object: P3 1 MPI process type: sum Space in 2 variables with 2 components, size 20 Sum space of 2 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 1 MPI process type: poly Space in 2 variables with 1 components, size 10 Polynomial space of degree 3 PetscDualSpace Object: P3 1 MPI process type: lagrange Dual space with 2 components, size 20 Continuous Lagrange dual space Quadrature on a triangle of order 7 on 16 points (dim 2) Volume: 1. ``` Thank you for your attention and understanding. I apologize once again for my previous oversight. Best wishes, Zongze On Sun, 14 May 2023 at 16:44, Matthew Knepley <[email protected]> wrote:
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Good to hear this works for you. I believe there is still a problem with high order tetrahedral elements (we've been coping with it for months and someone asked last week) and plan to look at it as soon as possible now that my semester finished. Zongze Yang <[email protected]> writes:
Hi, Matt,
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Yes, you are correct. I have conducted tests using high-order 3D meshes of a unit cube, and regrettably, the tests have failed. I have attached the files for your reference. Kindly review the output provided below: ( The volume should be 1) ``` $ mpiexec -n 3 ./ex33 -coord_space 0 -dm_plex_filename cube_2rd.msh -dm_plex_gmsh_project -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true -dm_plex_gmsh_project_fe_view PetscFE Object: P2 3 MPI processes type: basic Basic Finite Element in 3 dimensions with 3 components PetscSpace Object: P2 3 MPI processes type: sum Space in 3 variables with 3 components, size 30 Sum space of 3 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 3 MPI processes type: poly Space in 3 variables with 1 components, size 10 Polynomial space of degree 2 PetscDualSpace Object: P2 3 MPI processes type: lagrange Dual space with 3 components, size 30 Continuous Lagrange dual space Quadrature on a tetrahedron of order 5 on 27 points (dim 3) Volume: 0.46875 $ mpiexec -n 3 ./ex33 -coord_space 0 -dm_plex_filename cube_3rd.msh -dm_plex_gmsh_project -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true -dm_plex_gmsh_project_fe_view PetscFE Object: P3 3 MPI processes type: basic Basic Finite Element in 3 dimensions with 3 components PetscSpace Object: P3 3 MPI processes type: sum Space in 3 variables with 3 components, size 60 Sum space of 3 concatenated subspaces (all identical) PetscSpace Object: sum component (sumcomp_) 3 MPI processes type: poly Space in 3 variables with 1 components, size 20 Polynomial space of degree 3 PetscDualSpace Object: P3 3 MPI processes type: lagrange Dual space with 3 components, size 60 Continuous Lagrange dual space Quadrature on a tetrahedron of order 7 on 64 points (dim 3) Volume: 0.536855 ``` Best wishes, Zongze On Sun, 14 May 2023 at 22:36, Jed Brown <[email protected]> wrote:
Hi, Matt,
Best wishes, Zongze
Hi, Matt,
and
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
I checked the coordinates vector, and found the dogs only defined on cell other than vertex and edge, so I said they are stored as DG. Then the function DMPlexVecGetClosure < https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return the coordinates in lex order.
Matt
Thanks, Zongze
coordinates
Matt
relation
Best wishes, Zongze
On Sun, May 14, 2023 at 9:21 AM Zongze Yang <[email protected]> wrote:
Hi, Matt,
No problem. Glad it is working.
Great! If you make an MR for this, you will be included on the next list of PETSc contributors. Otherwise, I can do it. Thanks, Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
I appreciate your offer to handle the MR. Please go ahead and take care of it. Thank you! Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
I have created the MR with your tests. They are working for me: https://gitlab.com/petsc/petsc/-/merge_requests/6463 Thanks, Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Could you try to project the coordinates into the continuity space by enabling the option `-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true`? Best wishes, Zongze On Mon, 15 May 2023 at 04:24, Matthew Knepley <[email protected]> wrote:
Hi, Matt,
Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
There is a comment in the code about that: /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */ So what is currently done is you project into the discontinuous space from the GMsh coordinates, and then we get the continuous coordinates from those later. This is why we get the right answer. Thanks, Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Sorry, I'm having difficulty understanding the comment and fully understanding your intended meaning. Are you saying that we can only project the space to a discontinuous space? Additionally, should we always set `dm_plex_gmsh_project_petscdualspace_lagrange_continuity` to false for high-order gmsh files? With the option set to `true`, I got the following error: ``` $ $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/runex33_gmsh_3d_q2.sh -e "-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true" not ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # Error code: 77 # Volume: 0.46875 # [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [0]PETSC ERROR: Petsc has generated inconsistent data # [0]PETSC ERROR: Calculated volume 0.46875 != 1. actual volume (error 0.53125 > 1e-06 tol) # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting. # [0]PETSC ERROR: Petsc Development GIT revision: v3.19.1-294-g9cc24bc9b93 GIT Date: 2023-05-15 12:07:10 +0000 # [0]PETSC ERROR: ../ex33 on a arch-linux-c-debug named AMA-PC-RA18 by yzz Mon May 15 21:53:43 2023 # [0]PETSC ERROR: Configure options --CFLAGS=-I/opt/intel/oneapi/mkl/latest/include --CXXFLAGS=-I/opt/intel/oneapi/mkl/latest/include --LDFLAGS="-Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64 -L/opt/intel/oneapi/mkl/latest/lib/intel64" --download-bison --download-chaco --download-cmake --download-eigen="/home/yzz/firedrake/complex-int32-mkl-X-debug/src/eigen-3.3.3.tgz " --download-fftw --download-hdf5 --download-hpddm --download-hwloc --download-libpng --download-metis --download-mmg --download-mpich --download-mumps --download-netcdf --download-p4est --download-parmmg --download-pastix --download-pnetcdf --download-ptscotch --download-scalapack --download-slepc --download-suitesparse --download-superlu_dist --download-tetgen --download-triangle --with-blaslapack-dir=/opt/intel/oneapi/mkl/latest --with-c2html=0 --with-debugging=1 --with-fortran-bindings=0 --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/latest --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/latest --with-scalar-type=complex --with-shared-libraries=1 --with-x=1 --with-zlib PETSC_ARCH=arch-linux-c-debug # [0]PETSC ERROR: #1 CheckVolume() at /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:246 # [0]PETSC ERROR: #2 main() at /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:261 # [0]PETSC ERROR: PETSc Option Table entries: # [0]PETSC ERROR: -coord_space 0 (source: command line) # [0]PETSC ERROR: -dm_plex_filename /home/yzz/opt/petsc/share/petsc/datafiles/meshes/cube_q2.msh (source: command line) # [0]PETSC ERROR: -dm_plex_gmsh_project (source: command line) # [0]PETSC ERROR: -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true (source: command line) # [0]PETSC ERROR: -tol 1e-6 (source: command line) # [0]PETSC ERROR: -volume 1.0 (source: command line) # [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # application called MPI_Abort(MPI_COMM_SELF, 77) - process 0 ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # SKIP Command failed so no diff ``` Best wishes, Zongze Thanks,
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
For higher order simplices, because we do not have the mapping to the GMsh order yet.
This is done automatically if you do not override it.
Yes, do not do that. Thanks, Matt
Best wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
Got it. Thank you for your explanation! Best wishes, Zongze On Mon, 15 May 2023 at 23:28, Matthew Knepley <[email protected]> wrote:
Matt
Best wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best Wishes, Zongze
Matt
Best wishes, Zongze
Hi, Matt,
Matt
Best wishes, Zongze
Zongze
Matt
Thanks, Zongze
Thanks!
Zongze
Matt
Thanks, Zongze
Matt
Best wishes, Zongze
participants (3)
Jed Brown -
Matthew Knepley -
Zongze Yang
