hello group I know that no-one like newbie questions, but... unfortunetly I have one Sorry but I cant find in google or manual the clear example how to use PETSC from C++. If there are such, please just point me to them. Initaially I have started with ./config/configure.py --download-f-blas-lapack=1 I have sucessfully compiled a few examples and run in parallel mode. Now I want to implement PETSC for solwing my linear models. I need to switch to C++ because whole code for data manipulation (reading,renumbering) and model manipulation (representation, building) I have written in C++. Maybe it is strange that I'm writing c/c++ code and have such problems but (i'm geneticst not informaticst) compiling and linking ,static and shared libs building it is just night mare for me. So, I have configured PETSC with such options Configure Options: --with-clanguage=C++ --download-f-blas-lapack=1 --with-shared=0 -configModules=PETSc.Configure and can't compile even such code ------------------------------------------- #include <string> #include "petscksp.h" #undef __FUNCT__ #define __FUNCT__ "main" int main(int argc,char **args) { PetscErrorCode ierr; PetscInitialize(argc,args,PETSC_NULL,PETSC_NULL); ierr = PetscFinalize(); CHKERRQ(ierr); return 0; } ---------------------------------------- When I try to compile it I obtain this: mpiCC -c -Wall -g3 -I/home/work/petsc-2.3.0 -I/home/work/petsc-2.3.0/bmake/linux-gnu -I/home/work/petsc-2.3.0/include -I/usr/local/include -D__SDIR__="/home/work/blup_pcg" ex4.C mpiCC -Wall -g3 -o ex4 ex4.o -Wl,-rpath,/home/work/petsc-2.3.0/lib/linux-gnu -L/home/work/petsc-2.3.0/lib/linux-gnu -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc -lnsl -lrt -Wl,-rpath,/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -L/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu-lflapack -Wl,-rpath,/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -L/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -lfblas -lm -L/usr/local/lib -llammpio -llamf77mpi -lmpi -llam -lutil -ldl -lg2c -lm -L/usr/lib/gcc-lib/i486-linux/3.3.5 -L/usr/lib/gcc-lib/i486-linux/3.3.5/../../.. -lm -lgcc_s -lpthread -L/usr/local/lib -L/usr/lib/gcc-lib/i486-linux/3.3.5 -L/usr/lib/gcc-lib/i486-linux/3.3.5/../../.. -llammpio -llammpi++ -llamf77mpi -lmpi -llam -lutil -ldl -lstdc++ -lgcc_s -lpthread ex4.o(.text+0x2e): In function `main': /usr/local/include/mpi2cxx/datatype_inln.h:174: undefined reference to `PetscInitialize(int*, char***, char const*, char const*)' ex4.o(.text+0x33):/usr/local/include/mpi2cxx/datatype_inln.h:213: undefined reference to `PetscFinalize()' collect2: ld returned 1 exit status mpiCC: No such file or directory make: [ex4] B³±d 1 (zignorowany) ######################################################## # [email protected] # # jay.au.poznan.pl/~tomjan/ # ########################################################
Tomasz Jankowski <[email protected]> writes: The easiest way to use PETSc from C++ is to reconfigure with -with-clanguage=C++ and rebuild. You could even put this in a different arch directory using -PETSC_ARCH=<another name>. Thanks, Matt
hello group
So,
-- "Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
Please download and install PETSc 2.3.1 (just released). Regardless of whether you run with --with-clanguage=c++ or not, what you want to do SHOULD work! If the problem persists with 2.3.1 please send configure.log make_log*** and the output from linking your example to [email protected] so we can determine what has gone wrong. Barry On Tue, 7 Feb 2006, Tomasz Jankowski wrote:
hello group
So,
mpiCC -c -Wall -g3 -I/home/work/petsc-2.3.0 -I/home/work/petsc-2.3.0/bmake/linux-gnu -I/home/work/petsc-2.3.0/include -I/usr/local/include -D__SDIR__="/home/work/blup_pcg" ex4.C mpiCC -Wall -g3 -o ex4 ex4.o -Wl,-rpath,/home/work/petsc-2.3.0/lib/linux-gnu -L/home/work/petsc-2.3.0/lib/linux-gnu -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc -lnsl -lrt -Wl,-rpath,/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -L/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu-lflapack -Wl,-rpath,/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -L/home/work/petsc-2.3.0/externalpackages/fblaslapack/linux-gnu -lfblas -lm -L/usr/local/lib -llammpio -llamf77mpi -lmpi -llam -lutil -ldl -lg2c -lm -L/usr/lib/gcc-lib/i486-linux/3.3.5 -L/usr/lib/gcc-lib/i486-linux/3.3.5/../../.. -lm -lgcc_s -lpthread -L/usr/local/lib -L/usr/lib/gcc-lib/i486-linux/3.3.5 -L/usr/lib/gcc-lib/i486-linux/3.3.5/../../.. -llammpio -llammpi++ -llamf77mpi -lmpi -llam -lutil -ldl -lstdc++ -lgcc_s -lpthread ex4.o(.text+0x2e): In function `main': /usr/local/include/mpi2cxx/datatype_inln.h:174: undefined reference to `PetscInitialize(int*, char***, char const*, char const*)' ex4.o(.text+0x33):/usr/local/include/mpi2cxx/datatype_inln.h:213: undefined reference to `PetscFinalize()' collect2: ld returned 1 exit status mpiCC: No such file or directory make: [ex4] B��d 1 (zignorowany)
Ewerything has gone smooth. Thank you, mister. tom ######################################################## # [email protected] # # jay.au.poznan.pl/~tomjan/ # ########################################################
participants (3)
Barry Smith -
Matthew Knepley -
Tomasz Jankowski
