Hi, guys, I'm trying to solve a linear system with M equations and N unknowns (M >> N) using the LSQR method. I have a C parallel sparse matrix MxN with NZ nonzero elements stored in this way: double values[NZ]; // the nonzero values int idxn[NZ]; // the column indices int nz[M]; // the number of nonzero values for each row what is the best way to create a PETSc matrix? Do exists a statement like VecCreateMPIWithArray for already distributed vectors that could do all the work in one shot without copy? Just another detail. Initially M is unknown. All my structures are allocated dynamically because the number of rows M (and the number of nonzero NZ also) is determined just before to solve the system, so I think it's no feasible for me to call MatCreateMPIAIJ at the begin of my code and to perform the MatSetValues loop. Roberto ================================================================ | Roberto Gori CINECA | High Performance System Group Via Magnanelli 6/3 40033 | e-mail: [email protected] Casalecchio di Reno | Tel: 051/6171522 Bologna - ITALY | Fax: 051/6132198 http://www.cineca.it ================================================================
On Mon, 6 Feb 2006, Roberto Gori wrote:
Hi, guys,
This needs to be instead indices to start of each row in idxn and values instead of the length of each row.
MatMPIAIJSetPreallocationCSR()
Yes
There is nothing saying that you must "call MatCreateMPIAIJ at the beginning of your code", you can call it anytime that you have the needed information. Barry
Roberto
Many thanks Barry, MatMPIAIJSetPreallocationCSR could be a good solution for me. It seems that to satisfy the MatMPIAIJSetPreallocationCSR requirements I should convert the nz array from a relative to an absolute representation of the row offsets but ... I think this implies a not negligible drawback: my matrix is too large and offsets must be promoted to a long long int (64 bit) type. Moreover the idxn array type also must be promoted to be compliant with a 64 bit PetscInt type. This requires the double amount of memory for nz and idxn. What do you think about the opportunity to provide another version of MatMPIAIJSetPreallocationCSR based on relative offsets to save memory? Absolute offsets could be managed internally ... Finally I've look into the body of MatMPIAIJSetPreallocationCSR_MPIAIJ function ad I found this snippet of code for (i=0; i<m; i++) { ii = i + rstart; nnz = I[i+1]- I[i]; ierr = MatSetValues_MPIAIJ(B,1,&ii,nnz,J+I[i],values+(v ? I[i] : 0),INSERT_VALUES);CHKERRQ(ierr); } There's no way to avoid the copy of the values? This doubles one more time the memory for the values array and spend time into the loop. Morevover nnz corresponds exactly to my nz[i] ... ----- Original Message ----- From: Barry Smith To: Roberto Gori Cc: [email protected] Sent: Monday, February 06, 2006 4:15 PM Subject: Re: mat creation On Mon, 6 Feb 2006, Roberto Gori wrote:
Hi, guys,
Yes
Roberto
Many thanks Barry,
Your point is valid and noted but this would require writing another whole set of the AIJ routines that use the relative offsets. Maybe not so hard but a lot of code duplication.
The thing is PETSc does not just store the MPIAIJ matrices in a simple CSR format (the matrix is actually stored in two parts, see the MATMPIAIJ manual page). So the copy is needed. What we do. Is first count the number of nonzeros per row then preallocate the memory then compute the values in the matrix, see MatMPIAIJSetPreallocatio(). This may seem expensive but really is not, the counting is fast. You build the CSR matrix for your sparse matrix; using our approach is no harder and prevents the need for a copy. (In fact the reason PETSc has the Preallocation() and MatSetValues() stuff is so that users do not have to construct the CSR format directly. Barry
Hi, guys,
Yes
Barry
Roberto
Many thanks Barry,
These may be some confusing here; the idxn values are only relative to that process (i.e. idxn[0] == 0) this means there won't be a problem so long as you have less then about 2 billion nonzeros on a process (which would take > 28 gigabytes of memory). Barry
Barry
Hi, guys,
Yes
Barry
Roberto
participants (2)
Barry Smith -
Roberto Gori
